Is there a way to get gnome terminal? I like gnome terminal more than konsole.
Thanks in advance for helping!
Yes, you just need to install it
sudo pacman -Syu gnome-terminal
sorry for the dumb question btw
you can use “Add/Remove Software” (Pamac GUI) as well you know
