Hi all,
I downloaded the pre2 ISO of 25.1
manjaro-kde-25.1-pre2-251215-linux618.iso
There is a newer ISO released?
If yes, where can I download from?
Hi all,
Take a look in the [Stable Update] 2025-12-22 - Kernels, Cinnamon, KDE Frameworks, Pacman
More changes to mhwd and nvidia-driver-assistant:
Anh-Linh 26.0-rc4 (2026-01-02)
Greetings
Tony
You don’t need to download and install a new ISO to have the latest version of Manjaro. Just update your existing installation.
Yes, I know.
The ISO is for creating new virtual machines.
It is faster to install an ISO that don’t need a massive update just after the installation.
BTW approximately every three years I feel better to wipe out my machine and have a clean configuration
You’d only have to do the downloading of updates once - for all the virtual machines.
Create a separate virtual disk and mount it to /var/cache/pacman/pkg in each of the VMs.
I do this locally with four Manjaro VM’s (Xfce4, Plasma, Gnome, Cinnamon) to avoid having to download all the updates separately for each VM.
Good idea
I’ll use this method next time
