Is there a command-line Apple podcast downloader?
I had a Perl script which I’d built from reverse-engineering the pages on the Apple podcasts page so I could easily run a batch job to download new episodes overnight. But since they changed the pages I can’t see an obvious way to extract the MP3s’ URLs so I can download them.
Looking through the repos, there are GUI clients such as gnome-podcasts that can get the files, but I can’t find anything I can incorporate into a batch job.
Has anyone found any software to do this?
It is possible the page requires javascript navigation - and if it does you can get away with it using python, beautiful soup and selenium web driver.
A couple of ideas from a quick search download apple podcast using python
yt-dlp seems to have the functionality. Probably need the latest commits as I see there is an open issue about it though.
That’s handy, as I already have that installed. Thanks.
The issue probably relates to the change they made to the layout which defeated me.
… and grabbing applepodcasts.py from github makes it work!
Worth a try, thanks.
