I am interested by the possibility to download the manjaro packages once and update my two computers on the same network. Apparently pacserve is a solution that I can manage. I do not want to invest that much time to save some downloads or enter into a complex procedure that will generate huge problems that I cannot solve.
While pacserve seems to be THE best recommended solution, I am surprised to see only an old AUR version on pamac - and the installation does not function due to some python3 error-.
Is pacserve still a solution? What would you suggest in my case?
OK, thanks, I think it’s more cautious to stay with a fully synced system as you say. I may fall in some weird situation otherwise.
I was indeed following the discussions on pacserve and/or local repo but this is not easy for me, at least if I want to save time!
Thank you
