This is a query as much as an issue.
After the most recent stable update, I saw that network-manager gave the option (in the settings gui) to import an ovpn file and setup an openvpn connection (on pinephone - manjaro phosh). I figured I’d give it a try - I downloaded the file (proton) and used it to create a connection, just as I would on the desktop. It seems that this has not worked, though. running ip address, I don’t see any vpn addresses pop up. But, running journalctl -b -u NetworkManager --no-hostname --no-pager, I see errors among the output that at least says there was an attempt:
Jun 29 17:34:52 NetworkManager[3735]: <error> [1624952092.5725] audit: failed to open auditd socket: Protocol not supported
Jun 29 17:34:52 NetworkManager[3735]: <info> [1624952092.5760] audit: op="connection-activate" uuid="c2a13904-6bab-4766-81ac-fe974aaa0d3d" name="hun" pid=4727 uid=1000 result="success"
Jun 29 17:34:52 NetworkManager[3735]: <info> [1624952092.6675] vpn-connection[0xaaaaf1318170,c2a13904-6bab-4766-81ac-fe974aaa0d3d,"hun",0]: Started the VPN service, PID 4742
Jun 29 17:34:52 NetworkManager[3735]: <info> [1624952092.7614] vpn-connection[0xaaaaf1318170,c2a13904-6bab-4766-81ac-fe974aaa0d3d,"hun",0]: Saw the service appear; activating connection
Jun 29 17:38:52 NetworkManager[3735]: <error> [1624952332.9984] vpn-connection[0xaaaaf1318170,c2a13904-6bab-4766-81ac-fe974aaa0d3d,"hun",0]: Failed to request VPN secrets #3: No agents were available for this request.
Jun 29 17:38:53 NetworkManager[3735]: <info> [1624952333.2419] vpn-connection[0xaaaaf1318170,c2a13904-6bab-4766-81ac-fe974aaa0d3d,"hun",0]: VPN service disappeared
Would anyone know if getting openvpn connections to work via network manager is possible in Manjaro ARM? If so, how would one begin to ameliorate these errors?
