Is my laptop hacked?
Hi,
When I open Dolphin file browser from terminal using command dolphin . , I get following logs in terminal
https @ 0x5d03bd7d6980] Protocol 'https' not on whitelist 'file,crypto,data'!
[hls @ 0x5d03bd6ef6c0] Failed to open segment 1 of playlist 0
[hls @ 0x5d03bd6ef6c0] Segment 1 of playlist 0 failed too many times, skipping
[hls @ 0x5d03bd6ef6c0] Opening 'https://fsc.thevideobee.to:444/hls/exfpgji77wfr4navd5s2lppz2ktvsevnihd6svkd52qs4tbr6d7ucgtgcycq/seg-2-v1-a1.ts' for reading
Last line has some web link. Is my system compromised ??
Thank you.
Use the dolphin.desktop launcher instead.
I’m simply guessing here; that you may have inadvertently launched what appears to have been a video playlist file.
Without actually following that link, it’s impossible to gauge whether it may be questionable in any way, or indeed that you’ve been hacked;
and I doubt many forum members would follow that link just to check on your behalf.
Cheers.
:man_shrugging:
If it is you have been places you shouldn’t but unless you have been rooting then it is only your user account.
Are you sure that’s the correct command, or was that a typo? Because I couldn’t find it:
$ dolphine .
zsh: correct 'dolphine' to 'dolphin' [nyae]? n
find-the-command: "dolphine" is not found locally, searching in repositories...
find-the-command: command not found: "dolphine"
Some playlist could not be opened because the site it refers to (where what appears to be a video stream was located) does no longer exist.
the url thevideobee.to is inactive
some site
https://urlscan.io/domain/thevideobee.to
says that this site has last been seen 3-4 years ago
It’s your playlist … it’s on your machine … you should know about it
not dangerous in itself
Apologies. My mistake it is dolphin. I have corrected it.
I have the same issue in all the folders.
My approach to this would be:
search the content (!) of the whole of ~/.config recursively for part of the expression
thevideobee
as an example
in order to find the file that contains it
~/.local
would be another candidate
remove ~/.cache - it will be rebuilt/recreated
Extend the search to all content in your $HOME - it has got to be/got to come from somewhere …
I don’t use KDE and am not familiar with where to look for what.
Something like, if not exactly:
grep --recursive thevideobee ~
rm -r ~/.cache
likely
I’d use mc for it - like for most everything else
No need to know commands … :grin:
Removing .cache resolved the issue.
Thank you.
mc is AWESOME. However, commands are…easier…more efficient for/on the forum.
