Hey, I don’t know where to put this but after an update I can no longer open the Minecraft Launcher, if i run it through the command line I get this, I’m pretty new to Linux and Programming, I found this thread on the Arch Linux forum but wondered if anyone else is having this problem, or knows how to fix it.
[Info: 2021-03-13 01:19:56.339360221: NetQueue.cpp(157)] NetQueue: Setting up.
[Info: 2021-03-13 01:19:56.339481181: NetQueue.cpp(575)] NetQueue: worker thread started.
[Info: 2021-03-13 01:19:56.339573271: mainLinux.cpp(250)] Running launcher bootstrap (version 915)
[Debug: 2021-03-13 01:19:56.339809821: PlatformLinux.cpp(44)] HOME dir (getpwuid): /home/dhilan
[Debug: 2021-03-13 01:19:56.339819811: PlatformLinux.cpp(49)] HOME dir (env): /home/dhilan
[Info: 2021-03-13 01:19:56.341564421: Common.cpp(32)] Native Launcher Version: 915
[Info: 2021-03-13 01:19:56.341580411: Common.cpp(33)] Operating System: Linux
[Info: 2021-03-13 01:19:56.341590671: Common.cpp(34)] Application Data directory: //.../.minecraft
[Info: 2021-03-13 01:19:56.341602511: Common.cpp(35)] Executable Path: /.../minecraft-launcher
[Info: 2021-03-13 01:19:56.341612011: Common.cpp(36)] App Directory dir: //.../bin
[Info: 2021-03-13 01:19:56.341620961: Common.cpp(37)] Game data directory: //.../.minecraft
[Info: 2021-03-13 01:19:56.341630151: Common.cpp(38)] Launcher dir: //.../launcher
[Info: 2021-03-13 01:19:56.341641631: Common.cpp(39)] Java dir: //.../jre-x64
[Info: 2021-03-13 01:19:56.341650821: Common.cpp(40)] TmpDir dir: //.../MinecraftLauncher.1000
[Info: 2021-03-13 01:19:56.341659891: Common.cpp(41)] x64: true
[Info: 2021-03-13 01:19:56.341822891: mainLinux.cpp(308)] relaunchedExe: /home/dhilan/.minecraft/launcher/minecraft-launcher selfExe: /usr/bin/minecraft-launcher
[Info: 2021-03-13 01:19:56.341834581: mainLinux.cpp(312)] Top level executable, forwarding signals.
[Debug: 2021-03-13 01:19:56.341876771: SentryAPI.cpp(314)] The string '/usr' was added to the logging blacklist
[Debug: 2021-03-13 01:19:56.341887921: SentryAPI.cpp(314)] The string '///usr' was added to the logging blacklist
[Debug: 2021-03-13 01:19:56.341897071: SentryAPI.cpp(314)] The string '/home/dhilan' was added to the logging blacklist
[Debug: 2021-03-13 01:19:56.341905411: SentryAPI.cpp(314)] The string '///home/dhilan' was added to the logging blacklist
[Debug: 2021-03-13 01:19:56.341915122: SentryAPI.cpp(314)] The string '/home/dhilan/.minecraft' was added to the logging blacklist
[Debug: 2021-03-13 01:19:56.341923882: SentryAPI.cpp(314)] The string '///home/dhilan/.minecraft' was added to the logging blacklist
[Debug: 2021-03-13 01:19:56.341933112: SentryAPI.cpp(314)] The string '/home/dhilan/.minecraft/runtime' was added to the logging blacklist
[Debug: 2021-03-13 01:19:56.341941742: SentryAPI.cpp(314)] The string '///home/dhilan/.minecraft/runtime' was added to the logging blacklist
[Debug: 2021-03-13 01:19:56.341950982: SentryAPI.cpp(314)] The string '/tmp' was added to the logging blacklist
[Debug: 2021-03-13 01:19:56.341959392: SentryAPI.cpp(314)] The string '///tmp' was added to the logging blacklist
[Info: 2021-03-13 01:19:56.341966742: Common.cpp(32)] Native Launcher Version: 915
[Info: 2021-03-13 01:19:56.341981792: Common.cpp(33)] Operating System: Linux
[Info: 2021-03-13 01:19:56.341996162: Common.cpp(34)] Application Data directory: .../.minecraft
[Info: 2021-03-13 01:19:56.342012232: Common.cpp(35)] Executable Path: /.../minecraft-launcher
[Info: 2021-03-13 01:19:56.342028042: Common.cpp(36)] App Directory dir: .../bin
[Info: 2021-03-13 01:19:56.342046192: Common.cpp(37)] Game data directory: .../.minecraft
[Info: 2021-03-13 01:19:56.342061512: Common.cpp(38)] Launcher dir: .../.minecraft/launcher
[Info: 2021-03-13 01:19:56.342077752: Common.cpp(39)] Java dir: .../.minecraft/runtime/jre-x64
[Info: 2021-03-13 01:19:56.342094182: Common.cpp(40)] TmpDir dir:.../MinecraftLauncher.1000
[Info: 2021-03-13 01:19:56.342109812: Common.cpp(41)] x64: true
[Info: 2021-03-13 01:19:56.344970783: mainLinux.cpp(416)] Current executable is not in game directory, update and run game directory version
[Info: 2021-03-13 01:19:56.344996713: mainLinux.cpp(430)] Attempting to start the launcher
[Info: 2021-03-13 01:19:56.345005773: mainLinux.cpp(118)] Window closing, exiting process
[Info: 2021-03-13 01:19:56.356322667: mainLinux.cpp(456)] Launcher finished.
