Is it the problem with my screen? This started happening 2 days after installing Manjaro KDE Plasma
Please take a look at this and tell me what’s wrong here.
Thanks!!
Here’s my system information
  Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=93b649c5-963f-417e-a057-8af15ff14e82 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 81NB v: Lenovo IdeaPad S340-14API
    serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S340-14API
  Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
    serial: <superuser required> UEFI: LENOVO v: AMCN29WW(V1.12)
    date: 01/27/2021
  ID-1: BAT1 charge: 45.8 Wh (86.4%) condition: 53.0/52.5 Wh (101.0%)
    volts: 12.1 min: 11.3 model: 0x4C 0x47 0x43 0x00 0x32 0x30 0x 0x4C 0x31
    0x38 0x33 0x50 0x5250 type: Li-ion serial: <filter> status: discharging
    cycles: 1254
  RAM: total: 9.66 GiB used: 2.71 GiB (28.1%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 built: 2019
    process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
    microcode: 0x8108109
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1234 high: 1281 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1222 2: 1221
    3: 1251 4: 1281 5: 1221 6: 1219 7: 1236 8: 1221 bogomips: 33551
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
    prctl and seccomp
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15d8
    class-ID: 0300
  Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:4
    chip-ID: 5986:2115 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
    display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x203d built: 2018
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
    diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.42
    5.15.60-1-MANJARO) v: 4.6 Mesa 22.1.6 direct render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
    bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,snd_pci_acp5x
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
    chip-ID: 0cf3:e500 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 1.03 TiB used: 134.65 GiB (12.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo O.E.M.
    model: RPFTJ128PDD2EWX size: 119.24 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
    rev: 11.9 temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
    type: HDD rpm: 5400 serial: <filter> rev: LCM2 scheme: GPT
  ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%) used: 42.76 GiB
    (36.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 93b649c5-963f-417e-a057-8af15ff14e82
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
    uuid: C83C-173F
  ID-3: /run/media/shivamm/135BFADC10BDF965 raw-size: 833.86 GiB size: 833.86
    GiB (100.00%) used: 91.89 GiB (11.0%) fs: ntfs dev: /dev/sda3 maj-min: 8:3
    label: N/A uuid: 135BFADC10BDF965
  ID-1: /dev/sda1 maj-min: 8:1 size: 1024 KiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-4:4 info: Acer Integrated Camera type: Video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:2115
    class-ID: 0e02
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 3-2:2 info: Qualcomm Atheros type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e500
    class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 47.5 C mobo: N/A gpu: amdgpu temp: 47.0 C
  Processes: 247 Uptime: 5m wakeups: 1 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: 1283
  pm: pacman pkgs: 1271 libs: 348 tools: pamac,yay pm: flatpak pkgs: 12
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
Things that I’ve tried so far. I did everything that @anon89812132 suggested. it didn’t worked. I tried another live booting Manjaro xfce also. still the same issue. then i installed windows and thought to update all the drivers and everything from the scratch using Lenovo website and Radeon software both. Still the same issue. Also if i open BIOS it still exists.
Is this a hardware issue or something? I don’t think it should be a hardware problem as the screen looks normal one sec and some flickering happens the next sec then it returns back to normal again. Please help if you can. Also the flickering has increased since the morning now.
Your screen is flickering … We need to narrow down the possible issues.
Please share information of your system as described here
I’ve added all the system info now, pls check. Thanks!!
There are BIOS updates for your laptop, might start with that BIOS Update for Windows 10 (64-bit) - S340-15API, S340-15API Touch, S340-14API - Lenovo Support RO
That is fine as is a LTS kernel, but you can install and test some newer one, and see if the issue persists.
There is also this part that should help in your case to fix that artifacts/flickering thing AMDGPU - ArchWiki
Unrelated to your issue, but maybe worth looking into it:
I would go by using either swapfile or use zram-generator from our repository.
Other than that, only after taking care of the above i would start looking elsewhere if the issue persists.
Ok thanks!! Let me try fixing all these and see if the problem still exists.
To summarize:
  • started to happen 2 days ago
  • happens in Windows too
  • happens in BIOS also even after update
Conclusion:
Somewhere between the GPU and the display is failing, hardware related for sure.
You could try an external display and see if the issue is reproducible that way. If not, then the GPU is fine, and only have to investigate what fails to provide the signal - bad connector at the pins in the back of the LCD, the cable to it … or could be the inverter board.
Would suggest a repair shop for more investigation, or if it still in warranty period to contact Lenovo.
