how i can use system binaries instead of the-ones provided by peazip in res file for archiving and extraction
How do you know it doesn’t? How did you install it?
peazip-qt5 in the AUR depends on 7-zip and optionally depends on unace and a few others.
i installed from AUR peazip-qt5-bin but it use their own binaries
Wait … so you explicitly installed the precompiled binary version (*-bin), and dont want its binaries?
That package uses the portable release, which ships with its own binaries instead of relying on the installed ones: PKGBUILD - aur.git - AUR Package Repositories
You may want to use peazip-qt-bin instead : AUR (en) - peazip-qt-bin
Or another archive manager available in the repositories rather than from AUR.
thank you
