Is it possible to deactivate the “stereo repeat” option?
If I use VLC for example to play STEREO music the channels get copied like this:
Left → Left
Right → Right
Left → Surround Left
Left → Surround Back Left
Right → Surround Right
Right → Surround Back Right
Left + Right → Center
Nothing → Subwoofer
But if i play a 5.1 File this happens:
Left → Left
Right → Right
Center → Center
Subwoofer → Subwoofer
Surround Left → Surround Left
Surround Right → Surround Right
Left Center + (Subwoofer) + Surround Left → Surround Back Left
Right Center + (Subwoofer) + Surround Right → Surround Back Right
Is it possible to deactivate this feature? I don’t exactly know if this issue is caused of PulseAudio or ALSA because i use JACK between them.
Thanks for the suggestion!
Sadly it didn’t work. I have uncommented remixing-use-all-sink-channels = no and i even have turned enable-remixing to off (and uncommenting it too) to this:
enable-remixing = no
But even after copying /etc/pulse/daemon.pa to /home/lube/.config/pulse/daemon.conf (not deleting the old file) i still have the stereo repeat.
I am not aware of any ‘stereo repeat’ function available in VLC or Linux
VLC can be configured to use either PulseAudio, JACK or ALSA
VLC advanced settings allow ALSA to be configured to use only the 5.1 channels instead of 8 channels for 7.1 surround
If VLC audio is playing to PulseAudio the audio stream can be inspected with this command
pactl list sink-inputs
If VLC is playing to either PulseAudio or JACK a user would be able to see the audio connections in JACK patchbay and could disconnect the 2 of 8 channels not required for 5.1 audio
Cadence and QjackCtl have options in settings to fix the number of audio i/o channels used by JACK. JACK start command can use additional options -i, --inchannels and -o, --outchannels to specify 6 channels instead of the 8 channels detected automatically
PulseAudio and JACK already are configured and JACK is connecting with a 7.1 input. And I don’t want to reduce the inputs. I just want to disable the otherwise known as “upmix” or “remix” feature in pulseaudio. ALSA and JACK work perfectly.
I’ll change the title from
I suggest you check PulseAudio configuration options with this command
pulseaudio --dumpconf
There are probably only 2 configuration changes needed to disable PulseAudio from using all channels for remixing and allow LFE remixing for the sub-woofer channel
This command will create a PulseAudio daemon configuration file in $USER home folder with the 2 configuration changes
I suggest you reboot system and check pulseaudio --dump-conf again
The first line in the response Read from configuration file: should confirm the configuration is from User home folder instead of default system folder /etc/pulse/daemon.conf
If the system default configuration is still in use, check the new configuration file in a text editor
nano ~/.config/pulse/daemon.conf
Considering the manpage comment for enable-remixing= option, I do not think it is prudent to be changing that configuration option
There is no known valid use case for setting this option to no, therefore, this option is deprecated and may be removed in a future version of PulseAudio.
