I’d like to switch to another audio device (e…g. HDMI 2) automaticly when connecting another screen (e.g. TV) to my laptop. Is that possible and howto?
Thanks,
Hans
Thanks,
Hans
Welcome to Manjaro forum
The simplest way to switch audio streams to a newly connected device is to use PulseAudio module module-switch-on-connect
This module is not loaded by default because it is was too aggressive for many users. The module will ignore defaults and user settings for audio streams and move all audio streams to the last audio device plugged in
PulseAudio/Documentation/module-switch-on-connect
To load the module temporarily to see if it works as expected: switching to external display when connected and switching back correctly when display is unplugged:
pacmd load-module module-switch-on-connect
If the module works as expected, it can be added to PulseAudio permanently by creating a custom user configuration:
cat <<EOT > ~/.config/pulse/default.pa
.include /etc/pulse/default.pa
EOT
