Is it ok to use laptop without battery and just plug it to AC and use?
System Info:
System:    Kernel: 5.4.148-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.4-x86_64 root=UUID=bbefb3bb-eb92-4b21-92c9-4316cb266597 rw
           rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
           Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine:   Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
           Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.15.0 date: 06/16/2021
CPU:       Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check family: 6
           model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 3 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
           Speed: 2500 MHz min/max: 400/2500 MHz Core speeds (MHz): 1: 2500 2: 2500 3: 2500 4: 2500
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics:  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916
           class-ID: 0300
           Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] vendor: Dell driver: radeon
           v: kernel alternate: amdgpu bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
           Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02
           serial: <filter>
           Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: ati,modesetting,radeon
           alternate: fbdev,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
           Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
           OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.2 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel alternate: snd_soc_skl
           bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
           Sound Server-1: ALSA v: k5.4.148-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.37 running: no
Network:   Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 8086:3165
           class-ID: 0280
           Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: d000
           bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0a2a
           class-ID: e001
           Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
           address: see --recommends
Drives:    Local Storage: total: 931.51 GiB used: 205.98 GiB (22.1%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3 scheme: GPT
Partition: ID-1: / raw-size: 100.1 GiB size: 100.1 GiB (100.00%) used: 14.33 GiB (14.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
           ID-2: /boot/efi raw-size: 250.2 MiB size: 246.3 MiB (98.45%) used: 554 KiB (0.2%) fs: vfat dev: /dev/sda3
           maj-min: 8:3
           ID-3: /home raw-size: 831.17 GiB size: 831.17 GiB (100.00%) used: 191.65 GiB (23.1%) fs: btrfs dev: /dev/sda2
           maj-min: 8:2
           ID-4: /var/log raw-size: 100.1 GiB size: 100.1 GiB (100.00%) used: 14.33 GiB (14.3%) fs: btrfs dev: /dev/sda1
           maj-min: 8:1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 45.0 C mobo: 43.0 C gpu: radeon temp: 40.0 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 224 Uptime: 5m wakeups: 1 Memory: 7.64 GiB used: 1.94 GiB (25.4%) Init: systemd v: 249 tool: systemctl
           Compilers: gcc: 11.1.0 Packages: pacman: 1286 lib: 358 flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole
           inxi: 3.3.06
Yes, that is perfectly doable. You wouldn’t be the first. :wink:
but iam not having any UPS. Is that ok?
Thousands of people use desktop computers without a UPS.
They seem to survive pretty well.
I’m one of them. My UPS broke down several years ago and I still haven’t bought another one. :man_shrugging:
If you do not need a battery to back up.
This is risky if you have a power outage when you update, or if you’re unlucky and it messes up the file system. In most cases it would still be recoverable though. But there is a slim risk that something at some point goes wrong.
That being said, statistically it should be safe in theory.
Speaking of UPS it’s been months that I have mine warning me my battery is dead sometimes, thanks for reminding me to buy a new one :rofl: I always tell myself “I’ll do it later”, after shutting down the computer and pressing the button to reset it, and forget about it.
Of course it is, all my laptops run on their adapters all the time…
Of course, using (only) second handers, the battery IS the first issue. But…sure…I’d not know why not :thinking:
Without the battery, you will only lose battery backup, but hardware-wise, should be fine. Software could be another story, though, as not everything is written with sudden power outage in mind.
Desktop computers have bios battery but most of laptops don’t .
