Please help me figure it out.
If periodically run the ‘System Monitor’ program, then pamac-manager works there with a CPU reaching up to 36% and Memory reaching from 300 MB to 700 MB, after which the program ends, but if immediately run ‘System Monitor’ again, then pamac-manager appears again with the same scenario. In the settings of the program the ‘Check for updates’ checkbox is removed.
In the ‘Logs’ program, in the ‘Security’ section, entries occur on average every 2 minutes
Sender: system
Message: dbus-:1.2-
org.manjaro.pamac.manager@17.service:
Consumed 7.151s CPU time.
Priority: 6
Subject: Resources consumed by unit runtime
Why does pamac-manager work at all if I didn’t set the ‘Check for updates’ setting? I want to manually manage updates.
After disabling the ‘aur’, memory consumption decreased, but the ‘Security’ section of the ‘Logs’ program still has entries, although Consumed 7.151s CPU time changed to 2.706s CPU time.
Probably you misunderstand here something. Pamac does/check updates through systemd services. The mentioned service pamac-daemon.service runs all the time waiting for pamac to request something through dbus.
Remove pamac if that little cpu time is not acceptable… it depends on how good you system is. Stay with pacman alone on the terminal and you can do your updates manually.
The service just consumes 57ms on my system
systemctl status pamac-daemon.service
● pamac-daemon.service - Pamac Daemon
Loaded: loaded (/usr/lib/systemd/system/pamac-daemon.service; static)
Active: active (running) since Wed 2024-03-06 12:46:05 CET; 18min ago
Main PID: 78172 (pamac-daemon)
Tasks: 4 (limit: 37689)
Memory: 9.8M (peak: 12.9M)
CPU: 57ms
CGroup: /system.slice/pamac-daemon.service
└─78172 /usr/bin/pamac-daemon
Mär 06 12:46:05 Elitedesk systemd[1]: Starting Pamac Daemon...
Mär 06 12:46:05 Elitedesk systemd[1]: Started Pamac Daemon.
Btw… no idea what you mean here. A program called “Logs” ?
