Wile freesync is enabled and recognized on my system, it doesn’t actually work. When i exit the game the monitor flickers with bumps from 40Hz to 155Hz.
Have you studied the wiki already?
https://wiki.archlinux.org/title/Variable_refresh_rate#Enable_on_AMDGPU
You did not provide much info. Please, provide output of
inxi -Fza
Please help us help you:
Kernel: 6.8.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.8-x86_64
root=UUID=ced79fb3-4485-450f-8dd8-8624a64c9365 rw apparmor=1
security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: ASRock model: B450 Gaming-ITX/ac
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: P8.01 date: 03/13/2023
Info: model: AMD Ryzen 5 5500 bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000D
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/5275 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 106843
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
affected
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M]
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 compositors: 1: Picom v: git-89c2c
2: xfwm4 v: 4.18.0 driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Dell S2719DGF
serial: <filter> built: 2019 res: 2560x1440 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 17.0.6 DRM 3.57 6.8.8-2-MANJARO) device-ID: 1002:73ff
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 24.0.6-manjaro1.1
device-ID: 1002:73ff surfaces: xcb,xlib
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 0d:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
speed: 16 GT/s bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Telink VR P10 Dongle driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:2
chip-ID: 291a:385d class-ID: 0300
API: ALSA v: k6.8.8-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 0a:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp10s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 0b:00.0
IF: enp11s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0aa7
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 931.51 GiB used: 267.7 GiB (28.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 800
lanes: 4 tech: SSD serial: <filter> fw-rev: V1122B0 temp: 37.9 C
scheme: GPT
ID-1: / raw-size: 465.41 GiB size: 457.03 GiB (98.20%)
used: 267.68 GiB (58.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 26.5 MiB (27.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 38.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.22 GiB used: 2.56 GiB (8.2%)
Processes: 294 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 255
Packages: pm: pacman pkgs: 1527 libs: 472 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
Please edit your reply and format the inxi output properly.
Please have a level of trust in others. When i say that Freesync is enabled on my system you should immediately understand that it was working until recently and still says enabled. Also you should trust that i already tested all the relevant parts like compositor or not. I don’t understand the way you people tray to help from afar. It’s actually very simple: in your system with an Amd Gpu, does Freesync work? If yes then start talking to me like the problem is on my side.
Is the above correct?
Yes, thank you for doing that. ![]()
Also:
sudo cat /sys/kernel/debug/dri/1/DP-1/vrr_range
Min: 40
Max: 155
Sorry to break it to you, but this is not how it works, especially on a technical support forum.
Well i just got it working with Gamescop Compositor. So the problem is Picom or Xfce i guess. The thing fooled me because i tried without Compositor to and failed. I understand little by little how many ages behind Linux is: requires Compositor for Freesync to work at all
. If someone has a clue please say.
Downgraded by a lot both Picom and Kernel. Nothing fixed. Problem is with Xfce or Mesa.
- picom is a standalone compositor
- xfce has it’s own compositor
don’t mix the two
In case this wasn’t plain enough;
remove picom; configure XFCE as needed.
Let’s hope for your sake it’s that simple. ![]()
If you have finished rolling on the floor laughing you might begin to understand that it was your lack of research that led to the problem. It can happen easily when you rely on limited assumptions.
I did the same initially, when trying to configure a stable instance of Wayland on BSD and wasted more time than I care to mention, in the process.
Cheers.
Nope, an Xfxe or Mesa update broke Picom’s correct connection. We must find it.
