Is correct sound drivers loaded on HP Victus AMD Ryzen 7 5800H laptop?
I have HP Victus AMD Ryzen 7 5800H laptop.
Manjaro KDE 6.5.5-1 kernel with pipewire.
There is Realtek audio drivers for windows on HP website.
Windows shows that I have Realtek sound device:
Screenshot
But I cannot see any Realtek sound devices in my Manjaro Linux system.
And I also have strange problem, possible related to sound subsystem, because I can get random power downs when I watching video or listening to music in music player. Side question, but does Manjaro kernel shows kernel panic message at all?
So I got this confusion, what exactly sound card is present in my laptop, and does correct drivers used for it?
Maybe Realtek that I seen on Windows is Bluetooth audio?
inxi output:
  Device-1: NVIDIA GA106 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e
    class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
    link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.81 status: n/a (root, process) with:
    3: pipewire-alsa type: plugin 4: pw-jack type: plugin
aplay -lL output, you can see here ALC245 - which is Realtek driver?:
aplay -lL
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PipeWire Media Server)
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
    HDA NVidia, HDMI 1
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
    HDA NVidia, HDMI 2
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 3
    HDMI Audio Output
usbstream:CARD=NVidia
    HDA NVidia
    USB Stream Output
sysdefault:CARD=Generic
    HD-Audio Generic, ALC245 Analog
    Default Audio Device
front:CARD=Generic,DEV=0
    Front output / input
surround21:CARD=Generic,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=Generic
    HD-Audio Generic
    USB Stream Output
usbstream:CARD=acp
    acp
    USB Stream Output
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC245 Analog [ALC245 Analog]
  Subdevices: 1/1
pactl list cards, and here is no Realtek drivers but snd_hda_intel:
pactl list cards
Card #45
        Driver: alsa
        Owner Module: n/a
        Properties:
                api.acp.auto-port = "false"
                api.alsa.card = "0"
                api.alsa.card.longname = "HDA NVidia at 0xfc080000 irq 80"
                api.alsa.card.name = "HDA NVidia"
                api.alsa.path = "hw:0"
                api.alsa.use-acp = "true"
                device.api = "alsa"
                device.bus = "pci"
                device.bus_path = "pci-0000:01:00.1"
                device.description = "GA106 High Definition Audio Controller"
                device.enum.api = "udev"
                device.icon_name = "audio-card-analog-pci"
                device.name = "alsa_card.pci-0000_01_00.1"
                device.nick = "HDA NVidia"
                device.plugged.usec = "6869929"
                device.product.id = "0x228e"
                device.product.name = "GA106 High Definition Audio Controller"
                device.subsystem = "sound"
                sysfs.path = "/devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0"
                device.vendor.id = "0x10de"
                device.vendor.name = "NVIDIA Corporation"
                media.class = "Audio/Device"
                factory.id = "14"
                client.id = "34"
                object.id = "43"
                object.serial = "45"
                object.path = "alsa:pcm:0"
                alsa.card = "0"
                alsa.card_name = "HDA NVidia"
                alsa.long_card_name = "HDA NVidia at 0xfc080000 irq 80"
                device.string = "0"
        Profiles:
                off: Выключено (sinks: 0, sources: 0, priority: 0, available: yes)
                HiFi: Play HiFi quality Music (sinks: 4, sources: 0, priority: 8000, available: no)
                pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
        Active Profile: off
        Ports:
                [Out] HDMI4: HDMI / DisplayPort 4 Output (type: HDMI, priority: 1400, latency offset: 0 usec, availability group: HDMI/DP,pcm=9, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=9"
                                card.profile.port = "0"
                        Part of profile(s): HiFi
                [Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 1300, latency offset: 0 usec, availability group: HDMI/DP,pcm=8, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=8"
                                card.profile.port = "1"
                [Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 1200, latency offset: 0 usec, availability group: HDMI/DP,pcm=7, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=7"
                                card.profile.port = "2"
                [Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 1100, latency offset: 0 usec, availability group: HDMI/DP,pcm=3, not available)
                        Properties:
                                port.type = "hdmi"
                                port.availability-group = "HDMI/DP,pcm=3"
                                card.profile.port = "3"
Card #46
        Driver: alsa
        Owner Module: n/a
        Properties:
                api.alsa.card = "1"
                api.alsa.card.longname = "HD-Audio Generic at 0xfc5c0000 irq 81"
                api.alsa.card.name = "HD-Audio Generic"
                api.alsa.path = "hw:1"
                api.dbus.ReserveDevice1 = "Audio1"
                device.api = "alsa"
                device.bus = "pci"
                device.bus_path = "pci-0000:06:00.6"
                device.description = "Family 17h/19h HD Audio Controller"
                device.name = "alsa_card.pci-0000_06_00.6"
                device.nick = "HD-Audio Generic"
                device.plugged.usec = "6996972"
                device.product.id = "0x15e3"
                device.product.name = "Family 17h/19h HD Audio Controller"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.6/sound/card1"
                device.vendor.id = "0x1022"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
                factory.id = "14"
                client.id = "34"
                object.id = "44"
                object.serial = "46"
                object.path = "alsa:pcm:1"
                alsa.card = "1"
                alsa.card_name = "HD-Audio Generic"
                alsa.long_card_name = "HD-Audio Generic at 0xfc5c0000 irq 81"
                device.string = "1"
        Profiles:
                HiFi: Play HiFi quality Music (sinks: 1, sources: 2, priority: 8000, available: yes)
                pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
        Active Profile: HiFi
        Ports:
                [Out] Speaker: Speaker (type: Speaker, priority: 100, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "speaker"
                [Out] Headphones: Headphones (type: Headphones, priority: 200, latency offset: 0 usec, availability group: Headphone, not available)
                        Properties:
                                port.type = "headphones"
                                port.availability-group = "Headphone"
                [In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, latency offset: 0 usec, availability group: Mic, not available)
                        Properties:
                                port.type = "mic"
                                port.availability-group = "Mic"
                [In] Mic1: Digital Microphone (type: Mic, priority: 100, latency offset: 0 usec, availability unknown)
                        Properties:
                                port.type = "mic"
lsmod | grep snd shows:
lsmod | grep snd
snd_seq_dummy          12288  0
snd_hrtimer            12288  1
snd_seq               131072  7 snd_seq_dummy
snd_seq_device         16384  1 snd_seq
snd_ctl_led            24576  0
snd_soc_dmic           12288  1
snd_acp3x_rn           12288  4
snd_acp3x_pdm_dma      16384  1
snd_sof_amd_rembrandt    16384  0
snd_sof_amd_renoir     16384  0
snd_sof_amd_acp        57344  2 snd_sof_amd_rembrandt,snd_sof_amd_renoir
snd_sof_pci            24576  2 snd_sof_amd_rembrandt,snd_sof_amd_renoir
snd_sof_xtensa_dsp     16384  1 snd_sof_amd_acp
snd_sof               421888  2 snd_sof_amd_acp,snd_sof_pci
snd_sof_utils          16384  1 snd_sof
snd_hda_codec_realtek   192512  1
snd_soc_core          458752  4 snd_acp3x_rn,snd_sof,snd_soc_dmic,snd_acp3x_pdm_dma
snd_hda_codec_generic   114688  1 snd_hda_codec_realtek
ledtrig_audio          12288  2 snd_ctl_led,snd_hda_codec_generic
snd_compress           28672  1 snd_soc_core
ac97_bus               12288  1 snd_soc_core
snd_hda_codec_hdmi     94208  1
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pci_ps             28672  0
snd_rpl_pci_acp6x      16384  0
snd_hda_intel          65536  10
snd_acp_pci            12288  0
snd_intel_dspcfg       32768  2 snd_hda_intel,snd_sof
snd_pci_acp6x          20480  0
snd_intel_sdw_acpi     16384  1 snd_intel_dspcfg
snd_pci_acp5x          16384  0
snd_rn_pci_acp3x       24576  0
snd_hda_codec         225280  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_acp_config         16384  7 snd_rn_pci_acp3x,snd_pci_acp6x,snd_pci_acp5x,snd_sof_amd_rembrandt,snd_acp_pci,snd_pci_ps,snd_sof_amd_renoir
snd_soc_acpi           12288  2 snd_sof_amd_acp,snd_acp_config
snd_hda_core          151552  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_pci_acp3x          16384  0
snd_hwdep              20480  1 snd_hda_codec
snd_pcm               204800  13 snd_sof_amd_acp,snd_hda_codec_hdmi,snd_pci_acp6x,snd_hda_intel,snd_hda_codec,snd_sof,snd_compress,snd_soc_core,snd_sof_utils,snd_hda_core,snd_acp3x_pdm_dma,snd_pci_ps,snd_pcm_dmaengine
snd_timer              53248  3 snd_seq,snd_hrtimer,snd_pcm
snd                   155648  44 snd_ctl_led,snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_pcm
soundcore              16384  2 snd_ctl_led,snd
I see that snd_hda_codec_realtek loaded. But also snd_hda_intel. But I dont have any intel devices in my Laptop?
Most onboard audio codecs use snd_hda_intel driver because they are compatible with Intel High Definition Audio specification. Intel HDA superseded previous audio standards Intel AC97 and Soundblaster16
Realtek codecs mostly use the same snd_hda_intel drivers on AMD and Intel systems. But modern laptops have a digital microphone array that requires an AMD or Intel-specifc driver
inxi shows 3 devices. 2 are using snd_hda_intel driver but one uses AMD Audio Co-Processor
driver (for the internal digital microphones)
ACP device inxi is shown as capture device in ALSA
HW probe of HP Victus by Laptop 16z... #577c6ab744: arecord
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
card 2: acp [acp], device 0: DMIC capture dmic-hifi-0 []
  Subdevices: 1/1
But in PulseAudio, the 2 devices are merged into one card - alsa_card.pci-0000_06_00.6
PulseAudio card data shows both analog and digital microphone inputs:
Thank you very much for explanation, now its much clearer for me.
Any advice on how I can debug possible sound problems?
