Is bogofilter active in Evolution?
Hello everyone,
How can I check whether the bogofilter is active in Evolution? I installed the bogofilter package.
There is a evolution-bogofilter package - this is likely what you want.
have a look:
Arch Linux - Package Search
You chose the first - what you want is likely the second
Arch Linux - evolution-bogofilter 3.52.1-1 (x86_64)
the installed package is evolution-bogofilter 3.50.4-1. But how can I see, if it is activated?
To be perfectly honest:
I don’t know.
And I’m not going to go and find out by testing.
What results would you expect to see?
How would you verify it working? -
activated or not
Probably check under the program’s preferences to find any reference to plugins/extensions.
According to the official page, you have to train the spam filter, it won’t filter anything by default.
Thank you very much! I found a Link
