I see this process constantly using 20+% cpu
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
129 root -51 0 0 0 0 S 27.2 0.0 9,04 [irq/9-acpi]
What is this process? And can I config something not to use as much so often?
I’m using Manjaro cu Gnome
Linux radu-gram 6.9.0-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon May 13 07:01:28 UTC 2024 x86_64 GNU/Linux
How long has this been this issue happening to you? Have you tried with another kernel like 6.6 LTS?
I was in the last day, Strangely it doesn’t show anymore, phew…
But now this process is using cpu almost all the time
869812 gnome 20 0 5528576 357712 123348 S 23.9 1.1 0:32.54 /usr/bin/gnome-shell
irq/9-acpi appeared again using cpu, an I see this
129 root -51 0 0 0 0 R 29.0 0.0 125:45.31 irq/9-acpi
855909 root 20 0 0 0 0 D 11.7 0.0 0:50.19 kworker/u64:23+USBC000:00-con2
869812 gnome 20 0 5842852 349864 112708 S 9.0 1.1 5:15.57 gnome-shell
also this process stays at about 10%
kworker/u64:14+USBC000:00-con2
