IPSEC VPN not working - no tun Device
Hi Community,
I recently switched from Ubuntu to Manjaro. With Ubuntu I was able to connect to my FritzBox via IPSEC vpn. Now I want to use this connection with manjaro to.
I configured the connection the same way as before with ubuntu, but it´s not working.
If a try to activate the connection I get a failure message. I the logs there is entry that there is no tun device.
How can I add a tun device to the system?
Thanks
Homer
The easy part first: did you reboot after installing?
Hi,
I did not install anything, every packages have installed already.
Now I rebooted the system and now the behavior changed. Now it takes 5 seconds until the failure report show up.
I´ll check the credentials will report.
Thanks for the hint.
