I am trying to set up a kvm with gpu passthrough to run games and other stuff that wont run on linux. To do that I need to enable iommu, but I am having trouble with it.
I believe my hardware supports it and I have enabled VT-d
I have an i7-7700k, GTX 1080, GT 1030, and an MSI B250 mb
sudo grub-mkconfig -o /boot/grub/grub.fg
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
reboot
then run dmesg
sudo dmesg | grep -i -e DMAR -e IOMMU
[ 0.006127] ACPI: DMAR 0x000000007ECD0748 000070 (v01 INTEL KBL 00000001 INTL 00000001)
[ 0.006144] ACPI: Reserving DMAR table memory at [mem 0x7ecd0748-0x7ecd07b7]
[ 0.137302] DMAR: Host address width 39
[ 0.137303] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[ 0.137306] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.137308] DMAR: RMRR base: 0x0000007e79b000 end: 0x0000007e7bafff
[ 0.137309] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed90000 IOMMU 0
[ 0.137310] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[ 0.137311] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.138626] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.257938] iommu: Default domain type: Translated
[ 0.321099] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.321099] AMD-Vi: AMD IOMMUv2 functionality not available on this system
it doesn’t say that iommu is enabled
then I check my iommu groups and nothing is there
I did not see a setting anywhere in my bios labeled IOMMU. And of what I have read there is no iommu setting, just a VT-d and VT-x setting which I have both enabled.
OK yeah my bad, for Intel CPU it is called VT-d, not IOMMU. The motherboard and CPU support it. So if you enabled it in UEFI it should be enabled. I don’t really know anything about this technology and passthrough, just a guess, thy without the GRUB forced settings (EDIT: but reading the Arch WIKI PCI passthrough via OVMF - ArchWiki, these parameters should be good actually, so probably wrong guess)?
EDIT: maybe you could update your very outdated BIOS if you know how to do it. You have the initial BIOS released at same time of the first revision of the board, in 2016.
If you know nothing about it, it is doable, but first know that there is a RISK implied in updating the motherboard BIOS, if you power down the computer during the operation, it could simply brick the motherboard. In 20 years of messing around this never happened to me, but this is a possible risk.
EDIT: also, before flashing the BIOS, make sure you have a Manjaro USB stick ready, in case you can’t boot back on Manjaro, it always happens to me (flashing the BIOS erase the motherboard settings and what contains the bootloader information to detect the OS), it never happens to some other people so just in case, be ready to use the Manjaro USB stick to detect your Manjaro installation, boot on it, and restore GRUB to fix this issue.
But it appears you did not properly change your commmandline, according to your inxi output your kernel params do not include the iommu parameters you listed in your OP…
Actually in your OP there’s:
But it should be:
sudo grub-mkconfig -o /boot/grub/grub.cfg
(Always use tab to autocomplete pre-existing filenames in the terminal just to be sure you got them right )
Indeed the kernel parameters do not appear in the inxi output. Well spotted I just assumed he did it correctly.
On a side not, just use sudo update-grub so no issues. It will properly update grub. And also now if he did the improper command with the wrong file, there is a /boot/grub/grub.fg lying around
Thx for the help. I updated my bios and fixed the typo and now iommu seems to be working, thoug havent tested it. I doubt the bois update is what fixed it, but it was probably good to update it anyways since it was so outdated.
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=ed74b9c6-7e1c-403f-87cd-903f93295482 rw intel_iommu=on iommu=pt quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.006187] ACPI: DMAR 0x000000007EC473F0 000070 (v01 INTEL KBL 00000001 INTL 00000001)
[ 0.006205] ACPI: Reserving DMAR table memory at [mem 0x7ec473f0-0x7ec4745f]
[ 0.058687] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=ed74b9c6-7e1c-403f-87cd-903f93295482 rw intel_iommu=on iommu=pt quiet apparmor=1 security=apparmor udev.log_priority=3
[ 0.058713] DMAR: IOMMU enabled
[ 0.136038] DMAR: Host address width 39
[ 0.136039] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[ 0.136042] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.136044] DMAR: RMRR base: 0x0000007ead2000 end: 0x0000007eaf1fff
[ 0.136046] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed90000 IOMMU 0
[ 0.136046] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[ 0.136047] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.137426] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.256898] iommu: Default domain type: Passthrough (set via kernel command line)
[ 0.302254] DMAR: No ATSR found
[ 0.302254] DMAR: No SATC found
[ 0.302255] DMAR: dmar0: Using Queued invalidation
[ 0.302279] pci 0000:00:00.0: Adding to iommu group 0
[ 0.302287] pci 0000:00:01.0: Adding to iommu group 1
[ 0.302292] pci 0000:00:08.0: Adding to iommu group 2
[ 0.302300] pci 0000:00:14.0: Adding to iommu group 3
[ 0.302305] pci 0000:00:14.2: Adding to iommu group 3
[ 0.302311] pci 0000:00:16.0: Adding to iommu group 4
[ 0.302316] pci 0000:00:17.0: Adding to iommu group 5
[ 0.302322] pci 0000:00:1b.0: Adding to iommu group 6
[ 0.302327] pci 0000:00:1c.0: Adding to iommu group 7
[ 0.302333] pci 0000:00:1c.7: Adding to iommu group 8
[ 0.302340] pci 0000:00:1d.0: Adding to iommu group 9
[ 0.302353] pci 0000:00:1f.0: Adding to iommu group 10
[ 0.302358] pci 0000:00:1f.2: Adding to iommu group 10
[ 0.302363] pci 0000:00:1f.3: Adding to iommu group 10
[ 0.302367] pci 0000:00:1f.4: Adding to iommu group 10
[ 0.302372] pci 0000:00:1f.6: Adding to iommu group 11
[ 0.302375] pci 0000:01:00.0: Adding to iommu group 1
[ 0.302377] pci 0000:01:00.1: Adding to iommu group 1
[ 0.302386] pci 0000:02:00.0: Adding to iommu group 12
[ 0.302392] pci 0000:02:00.1: Adding to iommu group 12
[ 0.302398] pci 0000:03:00.0: Adding to iommu group 13
[ 0.302403] pci 0000:04:00.0: Adding to iommu group 14
[ 0.302409] pci 0000:06:00.0: Adding to iommu group 15
[ 0.302427] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 0.323190] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.323190] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 1.011630] intel_iommu=on
Yeah the typo was the issue there but also updating your BIOS was a good thing regarding all the improvements you can read on the BIOS download page from the 6 past BIOS releases.
