I hope this is the right section for this posting β if not please advise me which one fits better or just move it there.
I really (enjoy) and
(love) my HP Elitebook 840 G8 with Manjaro Xfce and as a daily driver I often use sleep and resume in different working areas with changing devices attached.
Most of the time (9/10 times) this works like a charm β so in this thread Iβd like to investigate this one special case which frustrates me massively if it happens.
The single issue Iβm talking about is that I want to resume my notebook from sleep (more details following) and after opening the lid the power LED in the upper right corner KEEPS ON FLASHING, the FAN STARTS to run (you can hear him if it is silent enough so itβs not full speed) and the notebook is not reacting anymore. No matter if I attach / detach devices, hit the power button (many times), hit CTRL+ALT+DELETE, use the REISUB (MagicSys-Key procedure), attach the USB-C hub with networking and try a wake-on-lan. Nothing.
Itβs finally DEAD.
The only way to revive him is to press and hold the power button for at least four seconds until the PC turns completely off β βloosingβ the work I havenβt properly saved before putting him to sleepβ¦
This is massively frustrating me and Iβd like to find the main cause together with you fellow Manjaro people (TL;DR: I assume itβs the DELL USB-C Mobile Adapter DA300u but thatβs not assured yet)
Letβs dig into it!
Sleep procedure details and assumptions
My regular sleep procedure is as follows:
- Trigger the sleep using Xfceβs built in panel function (I think itβs using
systemctl suspend
) - Wait until the power LED in the upper right corner is flashing slowly (which means it has reached sleep state)
- Close the lid
- Detach all devices
Because Iβm changing working places on a regular basis I cannot assure that I reattach all devices in the same order / way like they were before. As I said before this is no problem in almost all cases and I also use the HP docking station with several devices connected at one of the working places without a problem.
So I assume the DELL USB-C Mobile Adapter DA300u is the main cause, because it is one of my mostly attached devices when this happens (unfortunately I did not pay attention on this explicitly by now). But I still need to proof it. This is where you might come into place.
It is difficult to investigate this in a structured way because I canβt even reproduce the issue. Trying different scenarios today I could only reproduce it exactly once at the very beginning of my testing. So Iβd like to provide you some logs here and maybe you have a hint for me what I could try next time to proof if itβs the DELL Hub or any other device.
In the meantime I will pay attention to NOT ATTACH the DELL Hub to my notebook anymore before resuming it β I will report back if that resolved the issue.
Technical details
- Kernel:
Linux MANJARO 6.1.25-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu Apr 20 13:48:36 UTC 2023 x86_64 GNU/Linux
(but I remember it already happened with the older 5.15 kernel) - OS: Manjaro Xfce
- Device: HP Elitebook 840 G8
- BIOS:
- Version: T37 Ver. 01.11.00
- Release Date: 10/13/2022
- BIOS Revision: 11.0
- Firmware Revision: 88.7
Details around the βsleep freezeβ
When this issue happened the following devices were attached to the computer
while putting it to sleep:
- DELL USB-C Mobile Adapter (referred to as DELL Hub)
- Yubico YubiKey OTP+FIDO+CCID
while resuming it from sleep:
- Power supply
- HDMI cable with screen attached
- USB 3.0 Hub (referred to as USB-HUB)
After the issue happend (reading after a hard shutdown) the log looked like this:
journalctl --boot -1
Show log
β2023-05-08 17:19:01.000000 840-G8-MANJARO systemd-logind[588]: The system will suspend now! β β2023-05-08 17:19:01.000000 840-G8-MANJARO ModemManager[604]: <info> [sleep-monitor-systemd] system is about to suspend β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.7489] manager: sleep: sleep requested (sleeping: no enabled: yes) β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.7489] device (p2p-dev-wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed') β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.7516] manager: NetworkManager state is now ASLEEP β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.7520] device (wlp0s20f3): state change: ip-config -> deactivating (reason 'sleeping', sys-iface-state: 'managed') β β2023-05-08 17:19:01.000000 840-G8-MANJARO dbus-daemon[585]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.s | β2023-05-08 17:19:01.000000 840-G8-MANJARO systemd[1]: Starting Network Manager Script Dispatcher Service... β β2023-05-08 17:19:01.000000 840-G8-MANJARO dbus-daemon[585]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher' β β2023-05-08 17:19:01.000000 840-G8-MANJARO systemd[1]: Started Network Manager Script Dispatcher Service. β β2023-05-08 17:19:01.000000 840-G8-MANJARO audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termiβ β2023-05-08 17:19:01.000000 840-G8-MANJARO kernel: audit: type=1130 audit(1683559141.775:2897): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/sysβ β2023-05-08 17:19:01.000000 840-G8-MANJARO kernel: wlp0s20f3: deauthenticating from REDACTED-FOR-PRIVACY by local choice (Reason: 3=DEAUTH_LEAVING) β β2023-05-08 17:19:01.000000 840-G8-MANJARO wpa_supplicant[745]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=REDACTED-FOR-PRIVACY reason=3 locally_generated=1 β β2023-05-08 17:19:01.000000 840-G8-MANJARO wpa_supplicant[745]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.9126] device (wlp0s20f3): supplicant interface state: completed -> disconnected β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.9129] device (wlp0s20f3): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed') β β2023-05-08 17:19:01.000000 840-G8-MANJARO avahi-daemon[581]: Withdrawing address record for fe80::8017:8adb:f43a:1a73 on wlp0s20f3. β β2023-05-08 17:19:01.000000 840-G8-MANJARO avahi-daemon[581]: Leaving mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::8017:8adb:f43a:1a73. β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.9135] dhcp4 (wlp0s20f3): canceled DHCP transaction β β2023-05-08 17:19:01.000000 840-G8-MANJARO avahi-daemon[581]: Interface wlp0s20f3.IPv6 no longer relevant for mDNS. β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.9136] dhcp4 (wlp0s20f3): state changed no lease β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.9500] device (wlp0s20f3): set-hw-addr: set MAC address to REDACTED-FOR-PRIVACY (scanning) β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.9547] device (wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed') β β2023-05-08 17:19:01.000000 840-G8-MANJARO wpa_supplicant[745]: wlp0s20f3: CTRL-EVENT-SCAN-FAILED ret=-100 β β2023-05-08 17:19:01.000000 840-G8-MANJARO NetworkManager[595]: <info> [1683559141.9899] device (wlp0s20f3): set-hw-addr: reset MAC address to REDACTED-FOR-PRIVACY (unmanage) β β2023-05-08 17:19:01.000000 840-G8-MANJARO wpa_supplicant[745]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 17:19:01.000000 840-G8-MANJARO wpa_supplicant[745]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 17:19:01.000000 840-G8-MANJARO wpa_supplicant[745]: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0 β β2023-05-08 17:19:02.000000 840-G8-MANJARO systemd[1]: Starting User suspend actions... β β2023-05-08 17:19:02.000000 840-G8-MANJARO wpa_supplicant[745]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 17:19:02.000000 840-G8-MANJARO wpa_supplicant[745]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 17:19:02.000000 840-G8-MANJARO wpa_supplicant[745]: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0 β β2023-05-08 17:19:03.000000 840-G8-MANJARO systemd[1]: suspend@myuseraccount.service: Deactivated successfully. β β2023-05-08 17:19:03.000000 840-G8-MANJARO systemd[1]: Started User suspend actions. β β2023-05-08 17:19:03.000000 840-G8-MANJARO audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=suspend@myuseraccount comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=β β2023-05-08 17:19:03.000000 840-G8-MANJARO audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=suspend@myuseraccount comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?β β2023-05-08 17:19:03.000000 840-G8-MANJARO systemd[1]: Reached target Sleep. β β2023-05-08 17:19:03.000000 840-G8-MANJARO kernel: audit: type=1130 audit(1683559143.079:2898): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=suspend@myuseraccount comm="systemd" exe="/usr/lib/systemd/systemdβ β2023-05-08 17:19:03.000000 840-G8-MANJARO kernel: audit: type=1131 audit(1683559143.079:2899): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=suspend@myuseraccount comm="systemd" exe="/usr/lib/systemd/systemdβ β2023-05-08 17:19:03.000000 840-G8-MANJARO systemd[1]: Starting System Suspend... β β2023-05-08 17:19:03.000000 840-G8-MANJARO systemd-sleep[1213796]: Entering sleep state 'suspend'... FROM NOW ON THE SYSTEM WAS DEAD
If the suspend / resume procedure works (which normally is the case) the log looks like this:
journalctl --boot -1 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
Show log
|2023-05-08 11:02:22.000000 840-G8-MANJARO systemd[1]: Starting System Suspend... β β2023-05-08 11:02:22.000000 840-G8-MANJARO systemd-sleep[1145484]: Entering sleep state 'suspend'... β β2023-05-08 11:02:22.000000 840-G8-MANJARO kernel: PM: suspend entry (s2idle) β β2023-05-08 11:02:22.000000 840-G8-MANJARO kernel: Filesystems sync: 0.006 seconds β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: Freezing user space processes β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: Freezing user space processes completed (elapsed 0.006 seconds) β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: OOM killer disabled. β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks completed (elapsed 0.003 seconds) β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: printk: Suspending console(s) (use no_console_suspend to debug) β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt blocked β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt unblocked β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: OOM killer enabled. β β2023-05-08 11:11:54.000000 840-G8-MANJARO systemd-logind[588]: Lid closed. β β2023-05-08 11:11:54.000000 840-G8-MANJARO systemd-logind[588]: Lid opened. β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: Restarting tasks ... done. β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: random: crng reseeded on system resumption β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915]) β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: PM: suspend exit β β2023-05-08 11:11:54.000000 840-G8-MANJARO kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915]) β β2023-05-08 11:11:54.000000 840-G8-MANJARO systemd-sleep[1145484]: System returned from sleep state. β β2023-05-08 11:11:54.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully. β β2023-05-08 11:11:54.000000 840-G8-MANJARO systemd[1]: Finished System Suspend. β2023-05-08 12:07:27.000000 840-G8-MANJARO systemd[1]: Starting System Suspend... β β2023-05-08 12:07:28.000000 840-G8-MANJARO systemd-sleep[1169073]: Entering sleep state 'suspend'... β β2023-05-08 12:07:28.000000 840-G8-MANJARO kernel: PM: suspend entry (s2idle) β β2023-05-08 12:07:28.000000 840-G8-MANJARO kernel: Filesystems sync: 0.020 seconds β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: Freezing user space processes β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: Freezing user space processes completed (elapsed 0.007 seconds) β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: OOM killer disabled. β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks completed (elapsed 0.003 seconds) β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: printk: Suspending console(s) (use no_console_suspend to debug) β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt blocked β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt unblocked β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: OOM killer enabled. β β2023-05-08 15:05:04.000000 840-G8-MANJARO systemd-logind[588]: Lid closed. β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: Restarting tasks ... β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915]) β β2023-05-08 15:05:04.000000 840-G8-MANJARO systemd-logind[588]: Lid opened. β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915]) β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: done. β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: random: crng reseeded on system resumption β β2023-05-08 15:05:04.000000 840-G8-MANJARO kernel: PM: suspend exit β β2023-05-08 15:05:04.000000 840-G8-MANJARO systemd-sleep[1169073]: System returned from sleep state. β β2023-05-08 15:05:04.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully.
I could reproduce it ONCEβ¦
β¦using this procedure:
- Sending device to sleep with
- Lid open
- YubiKey attached
- DELL Hub attached to one of the USB-C ports
Trigger: System command systemctl suspend
Detaching all devices
Waking up with
- YubiKey attached
- USB-HUB attached
- DELL Hub attached (not sure if I changed the port)
- HDMI attached
- Power attached
Trigger: Lid opened
journalctl --boot -1 | lnav
Show log
β2023-05-08 19:26:57.000000 MANJABOOK systemd-logind[637]: The system will suspend now! β β2023-05-08 19:26:57.000000 MANJABOOK NetworkManager[659]: <info> [1683566817.9696] manager: sleep: sleep requested (sleeping: no enabled: yes) β β2023-05-08 19:26:57.000000 MANJABOOK ModemManager[661]: <info> [sleep-monitor-systemd] system is about to suspend β β2023-05-08 19:26:57.000000 MANJABOOK NetworkManager[659]: <info> [1683566817.9697] device (p2p-dev-wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed') β β2023-05-08 19:26:57.000000 MANJABOOK NetworkManager[659]: <info> [1683566817.9704] manager: NetworkManager state is now ASLEEP β β2023-05-08 19:26:57.000000 MANJABOOK NetworkManager[659]: <info> [1683566817.9707] device (wlp0s20f3): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed') β β2023-05-08 19:26:57.000000 MANJABOOK dbus-daemon[633]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0β β2023-05-08 19:26:58.000000 MANJABOOK systemd[1]: Starting Network Manager Script Dispatcher Service... β β2023-05-08 19:26:58.000000 MANJABOOK dbus-daemon[633]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher' β β2023-05-08 19:26:58.000000 MANJABOOK systemd[1]: Started Network Manager Script Dispatcher Service. β β2023-05-08 19:26:58.000000 MANJABOOK audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termiβ β2023-05-08 19:26:58.000000 MANJABOOK kernel: audit: type=1130 audit(1683566818.009:123): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systβ β2023-05-08 19:26:58.000000 MANJABOOK kernel: wlp0s20f3: deauthenticating from REDACTED-FOR-PRIVACY by local choice (Reason: 3=DEAUTH_LEAVING) β β2023-05-08 19:26:58.000000 MANJABOOK wpa_supplicant[759]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=REDACTED-FOR-PRIVACY reason=3 locally_generated=1 β β2023-05-08 19:26:58.000000 MANJABOOK wpa_supplicant[759]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 19:26:58.000000 MANJABOOK NetworkManager[659]: <info> [1683566818.1225] device (wlp0s20f3): supplicant interface state: completed -> disconnected β β2023-05-08 19:26:58.000000 MANJABOOK NetworkManager[659]: <info> [1683566818.1227] device (wlp0s20f3): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed') β β2023-05-08 19:26:58.000000 MANJABOOK NetworkManager[659]: <info> [1683566818.1412] dhcp4 (wlp0s20f3): canceled DHCP transaction β β2023-05-08 19:26:58.000000 MANJABOOK NetworkManager[659]: <info> [1683566818.1413] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds) β β2023-05-08 19:26:58.000000 MANJABOOK NetworkManager[659]: <info> [1683566818.1413] dhcp4 (wlp0s20f3): state changed no lease β β2023-05-08 19:26:58.000000 MANJABOOK avahi-daemon[631]: Interface wlp0s20f3.IPv4 no longer relevant for mDNS. β β2023-05-08 19:26:58.000000 MANJABOOK avahi-daemon[631]: Leaving mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.222.222. β β2023-05-08 19:26:58.000000 MANJABOOK avahi-daemon[631]: Withdrawing address record for 192.168.222.222 on wlp0s20f3. β β2023-05-08 19:26:58.000000 MANJABOOK NetworkManager[659]: <info> [1683566818.1644] device (wlp0s20f3): set-hw-addr: set MAC address to REDACTED-FOR-PRIVACY (scanning) β β2023-05-08 19:26:58.000000 MANJABOOK avahi-daemon[631]: Joining mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.222.222. | β2023-05-08 19:26:58.000000 MANJABOOK avahi-daemon[631]: New relevant interface wlp0s20f3.IPv4 for mDNS. β β2023-05-08 19:26:58.000000 MANJABOOK avahi-daemon[631]: Registering new address record for 192.168.222.222 on wlp0s20f3.IPv4. β β2023-05-08 19:26:58.000000 MANJABOOK avahi-daemon[631]: Withdrawing address record for 192.168.222.222 on wlp0s20f3. β β2023-05-08 19:26:58.000000 MANJABOOK avahi-daemon[631]: Leaving mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.222.222. β β2023-05-08 19:26:58.000000 MANJABOOK avahi-daemon[631]: Interface wlp0s20f3.IPv4 no longer relevant for mDNS. β β2023-05-08 19:26:58.000000 MANJABOOK NetworkManager[659]: <info> [1683566818.1998] device (wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed') β β2023-05-08 19:26:58.000000 MANJABOOK NetworkManager[659]: <info> [1683566818.3331] device (wlp0s20f3): set-hw-addr: reset MAC address to REDACTED-FOR-PRIVACY (unmanage) β β2023-05-08 19:26:58.000000 MANJABOOK systemd[1]: Created slice Slice /system/resume. β β2023-05-08 19:26:58.000000 MANJABOOK systemd[1]: Created slice Slice /system/suspend. β β2023-05-08 19:26:58.000000 MANJABOOK systemd[1]: Starting User suspend actions... β β2023-05-08 19:26:58.000000 MANJABOOK wpa_supplicant[759]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 19:26:58.000000 MANJABOOK wpa_supplicant[759]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 19:26:58.000000 MANJABOOK wpa_supplicant[759]: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0 β β2023-05-08 19:26:58.000000 MANJABOOK wpa_supplicant[759]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 19:26:58.000000 MANJABOOK wpa_supplicant[759]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all β β2023-05-08 19:26:58.000000 MANJABOOK wpa_supplicant[759]: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0 β β2023-05-08 19:26:59.000000 MANJABOOK systemd[1]: suspend@myuseraccount.service: Deactivated successfully. β β2023-05-08 19:26:59.000000 MANJABOOK systemd[1]: Started User suspend actions. β β2023-05-08 19:26:59.000000 MANJABOOK audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=suspend@myuseraccount comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? reβ β2023-05-08 19:26:59.000000 MANJABOOK audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=suspend@myuseraccount comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? resβ β2023-05-08 19:26:59.000000 MANJABOOK systemd[1]: Reached target Sleep. β β2023-05-08 19:26:59.000000 MANJABOOK kernel: audit: type=1130 audit(1683566819.425:124): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=suspend@myuseraccount comm="systemd" exe="/usr/lib/systemd/systemd" hosβ β2023-05-08 19:26:59.000000 MANJABOOK kernel: audit: type=1131 audit(1683566819.425:125): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=suspend@myuseraccount comm="systemd" exe="/usr/lib/systemd/systemd" hosβ β2023-05-08 19:26:59.000000 MANJABOOK systemd[1]: Starting System Suspend... β β2023-05-08 19:26:59.000000 MANJABOOK systemd-sleep[8910]: Entering sleep state 'suspend'...
Unfortunately I couldnβt reproduce it using this procedure again so I assume it maybe has to do with the TIMING or it is some kind of sporadic issue. I hope the βlog snapshotsβ of my test scenarios are helpful instead.
Different testing scenarios
For all upcoming logs I used the following command:
journalctl --boot 0 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
Scenario A
Trying to reproduce it again: Sleep and resume with βreproduction scenarioβ (see above) without attaching USB-HUB during sleep while keeping DELL Hub attached
Show log
β2023-05-08 19:43:40.000000 840-G8-MANJARO systemd[1]: Starting System Suspend... β β2023-05-08 19:43:40.000000 840-G8-MANJARO systemd-sleep[5512]: Entering sleep state 'suspend'... β β2023-05-08 19:43:40.000000 840-G8-MANJARO kernel: PM: suspend entry (s2idle) β β2023-05-08 19:43:40.000000 840-G8-MANJARO kernel: Filesystems sync: 0.006 seconds β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: Freezing user space processes β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: Freezing user space processes completed (elapsed 0.002 seconds) β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: OOM killer disabled. β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds) β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: printk: Suspending console(s) (use no_console_suspend to debug) β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt blocked β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt unblocked β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: OOM killer enabled. β β2023-05-08 19:44:14.000000 840-G8-MANJARO systemd-logind[535]: Lid closed. β β2023-05-08 19:44:14.000000 840-G8-MANJARO systemd-logind[535]: Lid opened. β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: Restarting tasks ... done. β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: random: crng reseeded on system resumption β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: r8152 2-1.2:1.0 enp0s13f0u1u2: carrier on β β2023-05-08 19:44:14.000000 840-G8-MANJARO NetworkManager[542]: <info> [1683567854.0716] device (enp0s13f0u1u2): carrier: link connected β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcpβ β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tβ β2023-05-08 19:44:14.000000 840-G8-MANJARO systemd-sleep[5512]: System returned from sleep state. β β2023-05-08 19:44:14.000000 840-G8-MANJARO bluetoothd[883]: Controller resume with wake event 0x0 β β2023-05-08 19:44:14.000000 840-G8-MANJARO kernel: PM: suspend exit β β2023-05-08 19:44:14.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully. β β2023-05-08 19:44:14.000000 840-G8-MANJARO systemd[1]: Finished System Suspend. |
Scenario B
Attaching USB-HUB during sleep while keeping DELL Hub attached
Show log
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt unblocked β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: OOM killer enabled. β
β2023-05-08 19:45:41.000000 840-G8-MANJARO systemd-logind[535]: Lid closed. β
β2023-05-08 19:45:41.000000 840-G8-MANJARO systemd-logind[535]: Lid opened. β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: Restarting tasks β¦ done. β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: random: crng reseeded on system resumption β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcpβ
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tβ
β2023-05-08 19:45:41.000000 840-G8-MANJARO NetworkManager[542]: [1683567941.0597] device (enp0s13f0u1u2): carrier: link connected β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: r8152 2-1.2:1.0 enp0s13f0u1u2: carrier on β
β2023-05-08 19:45:41.000000 840-G8-MANJARO systemd-sleep[6854]: System returned from sleep state. β
β2023-05-08 19:45:41.000000 840-G8-MANJARO bluetoothd[883]: Controller resume with wake event 0x0 β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: PM: suspend exit β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: usb 4-2: new SuperSpeed USB device number 4 using xhci_hcd β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: usb 4-2: New USB device found, idVendor=2109, idProduct=0812, bcdDevice=90.91 β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: usb 4-2: Product: USB3.0 Hub β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: usb 4-2: Manufacturer: VIA Labs, Inc. β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: hub 4-2:1.0: USB hub found β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: hub 4-2:1.0: 4 ports detected β
β2023-05-08 19:45:41.000000 840-G8-MANJARO kernel: usb 3-1: new high-speed USB device number 12 using xhci_hcd β
β2023-05-08 19:45:41.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully. β
β2023-05-08 19:45:41.000000 840-G8-MANJARO systemd[1]: Finished System Suspend.
Scenario C
Reattaching DELL Hub into same USB-C slot with nothing else attached
Show log
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: printk: Suspending console(s) (use no_console_suspend to debug) β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt blocked β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt unblocked β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: usb 2-1: reset SuperSpeed Plus Gen 2x1 USB device number 3 using xhci_hcd β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: usb 3-5: reset high-speed USB device number 5 using xhci_hcd β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: usb 2-1.2: reset SuperSpeed USB device number 4 using xhci_hcd β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: r8152 2-1.2:1.0: skip request firmware β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: r8152 2-1.2:1.0: load rtl8153b-2 v1 10/23/19 successfully β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: usb 3-5.1: reset full-speed USB device number 10 using xhci_hcd β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: usb 3-5.3: reset low-speed USB device number 7 using xhci_hcd β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: OOM killer enabled. β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: Restarting tasks β¦ β
β2023-05-08 19:47:58.000000 840-G8-MANJARO kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcpβ
β2023-05-08 19:47:58.000000 840-G8-MANJARO systemd-logind[535]: Lid closed. β
β2023-05-08 19:47:59.000000 840-G8-MANJARO kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tβ
β2023-05-08 19:47:59.000000 840-G8-MANJARO systemd-logind[535]: Lid opened. β
β2023-05-08 19:47:59.000000 840-G8-MANJARO kernel: done. β
β2023-05-08 19:47:59.000000 840-G8-MANJARO kernel: random: crng reseeded on system resumption β
β2023-05-08 19:47:59.000000 840-G8-MANJARO systemd-sleep[8750]: System returned from sleep state. β
β2023-05-08 19:47:59.000000 840-G8-MANJARO bluetoothd[883]: Controller resume with wake event 0x0 β
β2023-05-08 19:47:59.000000 840-G8-MANJARO kernel: PM: suspend exit β
β2023-05-08 19:47:59.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully. β
β2023-05-08 19:47:59.000000 840-G8-MANJARO systemd[1]: Finished System Suspend.
Scenario D
Trying the exact reproduction scenario (see above) again.
Show log
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: r8152 2-1.2:1.0: load rtl8153b-2 v1 10/23/19 successfully β
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: usb 3-5.1: reset full-speed USB device number 10 using xhci_hcd β
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: usb 3-5.3: reset low-speed USB device number 7 using xhci_hcd β
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: OOM killer enabled. β
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: Restarting tasks β¦ done. β
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: random: crng reseeded on system resumption β
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcpβ
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tβ
β2023-05-08 19:49:51.000000 840-G8-MANJARO systemd-logind[535]: Lid closed. β
β2023-05-08 19:49:51.000000 840-G8-MANJARO systemd-logind[535]: Lid opened. β
β2023-05-08 19:49:51.000000 840-G8-MANJARO bluetoothd[883]: Controller resume with wake event 0x0 β
β2023-05-08 19:49:51.000000 840-G8-MANJARO systemd-sleep[9916]: System returned from sleep state. β
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: PM: suspend exit β
β2023-05-08 19:49:51.000000 840-G8-MANJARO kernel: usb 4-2: new SuperSpeed USB device number 6 using xhci_hcd β
β2023-05-08 19:49:52.000000 840-G8-MANJARO kernel: usb 4-2: New USB device found, idVendor=2109, idProduct=0812, bcdDevice=90.91 β
β2023-05-08 19:49:52.000000 840-G8-MANJARO kernel: usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 β
β2023-05-08 19:49:52.000000 840-G8-MANJARO kernel: usb 4-2: Product: USB3.0 Hub β
β2023-05-08 19:49:52.000000 840-G8-MANJARO kernel: usb 4-2: Manufacturer: VIA Labs, Inc. β
β2023-05-08 19:49:52.000000 840-G8-MANJARO kernel: hub 4-2:1.0: USB hub found β
β2023-05-08 19:49:52.000000 840-G8-MANJARO kernel: hub 4-2:1.0: 4 ports detected β
β2023-05-08 19:49:52.000000 840-G8-MANJARO kernel: usb 3-1: new high-speed USB device number 16 using xhci_hcd β
β2023-05-08 19:49:52.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully. β
β2023-05-08 19:49:52.000000 840-G8-MANJARO systemd[1]: Finished System Suspend.
Scenario E
Suspend with DELL Hub attached to USB-C port near user, switching it to USB-C port near HDMI port while asleep, nothing else connected
Show log
β2023-05-08 19:51:48.000000 840-G8-MANJARO avahi-daemon[520]: Withdrawing address record for 10.50.3.0 on enp0s13f0u1u2. β
β2023-05-08 19:51:48.000000 840-G8-MANJARO NetworkManager[542]: [1683568308.6186] dhcp4 (enp0s13f0u1u2): canceled DHCP transaction β
β2023-05-08 19:51:48.000000 840-G8-MANJARO NetworkManager[542]: [1683568308.6187] dhcp4 (enp0s13f0u1u2): activation: beginning transactiβ
β2023-05-08 19:51:48.000000 840-G8-MANJARO NetworkManager[542]: [1683568308.6187] dhcp4 (enp0s13f0u1u2): state changed no lease β
β2023-05-08 19:51:48.000000 840-G8-MANJARO systemd-sleep[11902]: System returned from sleep state. β
β2023-05-08 19:51:48.000000 840-G8-MANJARO bluetoothd[883]: Controller resume with wake event 0x0 β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: PM: suspend exit β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 2-2: new SuperSpeed Plus Gen 2x1 USB device number 5 using xhci_hcd β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 2-2: New USB device found, idVendor=2109, idProduct=0820, bcdDevice=30.03 β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 2-2: Product: USB3.1 Hub β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 2-2: Manufacturer: VIA Labs, Inc. β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: hub 2-2:1.0: USB hub found β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: hub 2-2:1.0: 4 ports detected β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 3-6: new high-speed USB device number 20 using xhci_hcd β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 3-6: New USB device found, idVendor=2109, idProduct=2820, bcdDevice=30.03 β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0 β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 3-6: Product: USB2.0 Hub β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: usb 3-6: Manufacturer: VIA Labs, Inc. β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: hub 3-6:1.0: USB hub found β
β2023-05-08 19:51:48.000000 840-G8-MANJARO kernel: hub 3-6:1.0: 5 ports detected β
β2023-05-08 19:51:49.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully. β
β2023-05-08 19:51:49.000000 840-G8-MANJARO systemd[1]: Finished System Suspend.
Scenario F
Trying the reproduction scenario (see above) again, but:
Sleep with DELL Hub attached to USB-C port near HDMI port
Resume after attaching USB-HUB, POWER, HDMI and DELL Hub (this time to USB-C port near user)
Show log
β2023-05-08 19:53:54.000000 840-G8-MANJARO systemd[1]: Starting System Suspendβ¦ β
β2023-05-08 19:53:54.000000 840-G8-MANJARO systemd-sleep[13585]: Entering sleep state βsuspendββ¦ β
β2023-05-08 19:53:54.000000 840-G8-MANJARO kernel: PM: suspend entry (s2idle) β
β2023-05-08 19:53:54.000000 840-G8-MANJARO kernel: Filesystems sync: 0.003 seconds
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds) β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: printk: Suspending console(s) (use no_console_suspend to debug) β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt blocked β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt unblocked β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: OOM killer enabled. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO systemd-logind[535]: Lid closed. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO rtkit-daemon[1829]: The canary thread is apparently starving. Taking action. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO rtkit-daemon[1829]: Demoting known real-time threads. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO rtkit-daemon[1829]: Successfully demoted thread 2486 of process 2466. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO rtkit-daemon[1829]: Successfully demoted thread 2495 of process 2453. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO rtkit-daemon[1829]: Successfully demoted thread 2453 of process 2453. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO rtkit-daemon[1829]: Successfully demoted thread 11491 of process 1825. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO rtkit-daemon[1829]: Successfully demoted thread 1825 of process 1825. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO rtkit-daemon[1829]: Demoted 5 threads. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO systemd-logind[535]: Lid opened. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: Restarting tasks β¦ β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915]) β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915]) β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: done. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: random: crng reseeded on system resumption β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 3-1: new high-speed USB device number 23 using xhci_hcd β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 7 using xhci_hcd β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 2-1: New USB device found, idVendor=2109, idProduct=0820, bcdDevice=30.03 β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 2-1: Product: USB3.1 Hub β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 2-1: Manufacturer: VIA Labs, Inc. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: hub 2-1:1.0: USB hub found β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: hub 2-1:1.0: 4 ports detected β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 2-2: USB disconnect, device number 5 β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 2-2.2: USB disconnect, device number 6 β
β2023-05-08 19:54:14.000000 840-G8-MANJARO systemd-sleep[13585]: System returned from sleep state. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO bluetoothd[883]: Controller resume with wake event 0x0 β
β2023-05-08 19:54:14.000000 840-G8-MANJARO avahi-daemon[520]: Interface enp0s13f0u2u2.IPv4 no longer relevant for mDNS. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO NetworkManager[542]: [1683568454.7385] device (enp0s13f0u2u2): state change: activated β unmanaged (reason βremovedβ, sys-iface-state: βremovedβ) β
β2023-05-08 19:54:14.000000 840-G8-MANJARO avahi-daemon[520]: Leaving mDNS multicast group on interface enp0s13f0u2u2.IPv4 with address 192.168.111.111. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO avahi-daemon[520]: Withdrawing address record for 192.168.111.111 on enp0s13f0u2u2. |
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: PM: suspend exit β
β2023-05-08 19:54:14.000000 840-G8-MANJARO NetworkManager[542]: [1683568454.7638] dhcp4 (enp0s13f0u2u2): canceled DHCP transaction β
β2023-05-08 19:54:14.000000 840-G8-MANJARO NetworkManager[542]: [1683568454.7639] dhcp4 (enp0s13f0u2u2): activation: beginning transaction (timeout in 45 seconds) β
β2023-05-08 19:54:14.000000 840-G8-MANJARO NetworkManager[542]: [1683568454.7639] dhcp4 (enp0s13f0u2u2): state changed no lease β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 3-1: New USB device found, idVendor=2109, idProduct=2812, bcdDevice=90.90 β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 3-1: Product: USB2.0 Hub β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 3-1: Manufacturer: VIA Labs, Inc. β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: hub 3-1:1.0: USB hub found β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: hub 3-1:1.0: 4 ports detected β
β2023-05-08 19:54:14.000000 840-G8-MANJARO kernel: usb 4-2: new SuperSpeed USB device number 8 using xhci_hcd β
β2023-05-08 19:54:15.000000 840-G8-MANJARO audit[13823]: CRED_ACQ pid=13823 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct=βlightdmβ exe=β/usr/bin/lightdmβ hostname=? addr=β
β2023-05-08 19:54:15.000000 840-G8-MANJARO lightdm[13823]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=972) by (uid=0) β
β2023-05-08 19:54:15.000000 840-G8-MANJARO kernel: audit: type=1103 audit(1683568455.002:228): pid=13823 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct=βlightdmβ exe=β/usr/β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd-logind[535]: New session c7 of user lightdm. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[1]: Created slice User Slice of UID 972. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[1]: Starting User Runtime Directory /run/user/972β¦ β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[1]: Finished User Runtime Directory /run/user/972. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@972 comm=βsystemdβ exe=β/usr/lib/systemd/systemd" hostname=? addr=? terminal=?β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[1]: Starting User Manager for UID 972β¦ β
β2023-05-08 19:54:15.000000 840-G8-MANJARO kernel: audit: type=1130 audit(1683568455.058:229): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@972 comm=βsystemdβ exe=β/usr/lib/systemd/systemdβ β
β2023-05-08 19:54:15.000000 840-G8-MANJARO dbus-daemon[522]: [system] Activating via systemd: service name=βorg.freedesktop.home1β unit=βdbus-org.freedesktop.home1.serviceβ requested by β:1.184β (uid=0 pid=13875 comβ
β2023-05-08 19:54:15.000000 840-G8-MANJARO dbus-daemon[522]: [system] Activation via systemd failed for unit βdbus-org.freedesktop.home1.serviceβ: Unit dbus-org.freedesktop.home1.service not found. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO (systemd)[13875]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO audit[13875]: USER_ACCT pid=13875 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct=βlightdmβ exe=β/usr/lib/β
β2023-05-08 19:54:15.000000 840-G8-MANJARO audit[13875]: CRED_ACQ pid=13875 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct=βlightdmβ exe=β/usr/lib/systemd/systemd" hostname=? addr=? terminaβ
β2023-05-08 19:54:15.000000 840-G8-MANJARO audit[13875]: SYSCALL arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffd06f6e090 a2=3 a3=0 items=0 ppid=1 pid=13875 auid=972 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sβ
β2023-05-08 19:54:15.000000 840-G8-MANJARO audit: PROCTITLE proctitle=β(systemd)β β
β2023-05-08 19:54:15.000000 840-G8-MANJARO (systemd)[13875]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal= user=[lightdm] ruser=[] rhost=[<unknow |
β2023-05-08 19:54:15.000000 840-G8-MANJARO (systemd)[13875]: pam_unix(systemd-user:session): session opened for user lightdm(uid=972) by (uid=0) β
β2023-05-08 19:54:15.000000 840-G8-MANJARO audit[13875]: USER_START pid=13875 uid=0 auid=972 ses=10 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_peβ
β2023-05-08 19:54:15.000000 840-G8-MANJARO kernel: audit: type=1101 audit(1683568455.065:230): pid=13875 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time aβ
β2023-05-08 19:54:15.000000 840-G8-MANJARO kernel: audit: type=1103 audit(1683568455.065:231): pid=13875 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct=βlightdmβ exe=β/usr/lib/systemd/systeβ
β2023-05-08 19:54:15.000000 840-G8-MANJARO kernel: audit: type=1006 audit(1683568455.065:232): pid=13875 uid=0 old-auid=4294967295 auid=972 tty=(none) old-ses=4294967295 ses=10 res=1 β
β2023-05-08 19:54:15.000000 840-G8-MANJARO kernel: audit: type=1300 audit(1683568455.065:232): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffd06f6e090 a2=3 a3=0 items=0 ppid=1 pid=13875 auid=972 uid=0 gid=0 β
β2023-05-08 19:54:15.000000 840-G8-MANJARO kernel: audit: type=1327 audit(1683568455.065:232): proctitle=β(systemd)" β
β2023-05-08 19:54:15.000000 840-G8-MANJARO kernel: audit: type=1105 audit(1683568455.065:233): pid=13875 uid=0 auid=972 ses=10 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_homeβ
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Queued start job for default target Main User Target. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Created slice User Application Slice. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Reached target Paths. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Reached target Timers. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Starting D-Bus User Message Bus Socketβ¦ β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on GnuPG network certificate management daemon. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on GCR ssh-agent wrapper. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on GNOME Keyring daemon. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers). β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on GnuPG cryptographic agent and passphrase cache (restricted). β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on GnuPG cryptographic agent (ssh-agent emulation). β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on GnuPG cryptographic agent and passphrase cache. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on p11-kit server. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on PipeWire Multimedia System Socket. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on Sound System. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Listening on D-Bus User Message Bus Socket. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Reached target Sockets. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Reached target Basic System. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Starting Update XDG user dir configurationβ¦ β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Finished Update XDG user dir configuration. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Reached target Main User Target. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[13875]: Startup finished in 101ms. β
β2023-05-08 19:54:15.000000 840-G8-MANJARO systemd[1]: Finished System Suspend.
Scenario G
Resume without DELL Hub attached
Show log
β2023-05-08 19:59:28.000000 840-G8-MANJARO systemd[1]: Starting System Suspendβ¦ β
β2023-05-08 19:59:28.000000 840-G8-MANJARO systemd-sleep[16551]: Entering sleep state βsuspendββ¦ β
β2023-05-08 19:59:28.000000 840-G8-MANJARO kernel: PM: suspend entry (s2idle) β
β2023-05-08 19:59:28.000000 840-G8-MANJARO kernel: Filesystems sync: 0.004 seconds β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: Freezing user space processes β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: Freezing user space processes completed (elapsed 0.009 seconds) β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: OOM killer disabled. β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds) β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: printk: Suspending console(s) (use no_console_suspend to debug) β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt blocked β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt unblocked β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: usb 2-1: reset SuperSpeed Plus Gen 2x1 USB device number 7 using xhci_hcd β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: usb 3-5: reset high-speed USB device number 24 using xhci_hcd β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: usb 2-1.2: reset SuperSpeed USB device number 8 using xhci_hcd β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: r8152 2-1.2:1.0: skip request firmware β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: r8152 2-1.2:1.0: load rtl8153b-2 v1 10/23/19 successfully β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: usb 3-5.3: reset low-speed USB device number 29 using xhci_hcd β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: usb 3-5.1: reset full-speed USB device number 27 using xhci_hcd β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: OOM killer enabled. β
β2023-05-08 19:59:37.000000 840-G8-MANJARO systemd-logind[535]: Lid closed. β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: Restarting tasks β¦ done. β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: random: crng reseeded on system resumption
β2023-05-08 19:59:37.000000 840-G8-MANJARO systemd-logind[535]: Lid opened. β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915]) β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915]) β
β2023-05-08 19:59:37.000000 840-G8-MANJARO systemd-sleep[16551]: System returned from sleep state. β
β2023-05-08 19:59:37.000000 840-G8-MANJARO bluetoothd[883]: Controller resume with wake event 0x0 β
β2023-05-08 19:59:37.000000 840-G8-MANJARO kernel: PM: suspend exit β
β2023-05-08 19:59:37.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully. β
β2023-05-08 19:59:38.000000 840-G8-MANJARO systemd[1]: Finished System Suspend. β
β2023-05-08 20:00:24.000000 840-G8-MANJARO systemd[1]: Starting System Suspendβ¦ β
β2023-05-08 20:00:24.000000 840-G8-MANJARO systemd-sleep[17539]: Entering sleep state βsuspendββ¦ β
β2023-05-08 20:00:24.000000 840-G8-MANJARO kernel: PM: suspend entry (s2idle) β
β2023-05-08 20:00:24.000000 840-G8-MANJARO kernel: Filesystems sync: 0.007 seconds β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: Freezing user space processes β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: Freezing user space processes completed (elapsed 0.003 seconds) β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: OOM killer disabled. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds) β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: printk: Suspending console(s) (use no_console_suspend to debug) β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt blocked β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: ACPI: EC: interrupt unblocked β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: OOM killer enabled. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: Restarting tasks β¦ β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 2-1: USB disconnect, device number 7 β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 2-1.2: USB disconnect, device number 8 β
β2023-05-08 20:00:43.000000 840-G8-MANJARO systemd-logind[535]: Lid closed. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO rtkit-daemon[1829]: The canary thread is apparently starving. Taking action. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO rtkit-daemon[1829]: Demoting known real-time threads. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO rtkit-daemon[1829]: Successfully demoted thread 16141 of process 1825. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO rtkit-daemon[1829]: Demoted 1 threads. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: done. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: random: crng reseeded on system resumption β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915]) β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915]) β
β2023-05-08 20:00:43.000000 840-G8-MANJARO systemd-logind[535]: Lid opened. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 3-1: new high-speed USB device number 30 using xhci_hcd
β2023-05-08 20:00:43.000000 840-G8-MANJARO systemd-sleep[17539]: System returned from sleep state. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO bluetoothd[883]: Controller resume with wake event 0x0 β
β2023-05-08 20:00:43.000000 840-G8-MANJARO avahi-daemon[520]: Interface enp0s13f0u1u2.IPv6 no longer relevant for mDNS. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO avahi-daemon[520]: Leaving mDNS multicast group on interface enp0s13f0u1u2.IPv6 with address fe80::d292:680c:b13e:a426. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: PM: suspend exit β
β2023-05-08 20:00:43.000000 840-G8-MANJARO NetworkManager[542]: [1683568843.7508] device (enp0s13f0u1u2): state change: activated β unmanaged (reason βremovedβ, sys-iface-state: βremovedβ) β
β2023-05-08 20:00:43.000000 840-G8-MANJARO avahi-daemon[520]: Interface enp0s13f0u1u2.IPv4 no longer relevant for mDNS. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO avahi-daemon[520]: Leaving mDNS multicast group on interface enp0s13f0u1u2.IPv4 with address 10.50.3.0. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO avahi-daemon[520]: Withdrawing address record for fe80::d292:680c:b13e:a426 on enp0s13f0u1u2. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO avahi-daemon[520]: Withdrawing address record for 192.168.111.111 on enp0s13f0u1u2. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO avahi-daemon[520]: Withdrawing address record for 10.50.3.0 on enp0s13f0u1u2. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO NetworkManager[542]: [1683568843.7746] dhcp4 (enp0s13f0u1u2): canceled DHCP transaction β
β2023-05-08 20:00:43.000000 840-G8-MANJARO NetworkManager[542]: [1683568843.7746] dhcp4 (enp0s13f0u1u2): activation: beginning transaction (timeout in 45 seconds) β
β2023-05-08 20:00:43.000000 840-G8-MANJARO NetworkManager[542]: [1683568843.7746] dhcp4 (enp0s13f0u1u2): state changed no lease β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 3-1: New USB device found, idVendor=2109, idProduct=2812, bcdDevice=90.90 β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 3-1: Product: USB2.0 Hub β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 3-1: Manufacturer: VIA Labs, Inc. β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: hub 3-1:1.0: USB hub found β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: hub 3-1:1.0: 4 ports detected β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 3-5: USB disconnect, device number 24 β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 3-5.1: USB disconnect, device number 27 β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 3-5.3: USB disconnect, device number 29 β
β2023-05-08 20:00:43.000000 840-G8-MANJARO kernel: usb 4-2: new SuperSpeed USB device number 10 using xhci_hcd β
β2023-05-08 20:00:44.000000 840-G8-MANJARO kernel: usb 4-2: New USB device found, idVendor=2109, idProduct=0812, bcdDevice=90.91 β
β2023-05-08 20:00:44.000000 840-G8-MANJARO kernel: usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 β
β2023-05-08 20:00:44.000000 840-G8-MANJARO kernel: usb 4-2: Product: USB3.0 Hub β
β2023-05-08 20:00:44.000000 840-G8-MANJARO kernel: usb 4-2: Manufacturer: VIA Labs, Inc. β
β2023-05-08 20:00:44.000000 840-G8-MANJARO kernel: hub 4-2:1.0: USB hub found β
β2023-05-08 20:00:44.000000 840-G8-MANJARO kernel: hub 4-2:1.0: 4 ports detected β
β2023-05-08 20:00:44.000000 840-G8-MANJARO kernel: usb 3-1.1: new high-speed USB device number 31 using xhci_hcd β
β2023-05-08 20:00:44.000000 840-G8-MANJARO systemd[1]: systemd-suspend.service: Deactivated successfully. β
β2023-05-08 20:00:44.000000 840-G8-MANJARO systemd[1]: Finished System Suspend.
Summary
One thing I stumbled upon was the changing βUSB Hub productβ in the logs. One time it was Product: USB2.0 Hub
then it was Product: USB3.0 Hub
or Product: USB3.1 Hub
. Maybe this could be a hint.
As I already said I will try to NOT ATTACH the DELL Hub before resuming during the next weeks and letβs see if the issue is solved. I will report back. And if you have a tip or an idea what I could test Iβm looking forward to read from you here.
Thanks for reading and maybe this thread is helpful for others searching for this issue too.
