I am using XFCE’s Horizontal Reflection on my Display settings. It works fine, the only problem is that the mouse and keyboard work in an akward manner. I would like to invert the mouse X axis and invert left/right arrow keys.
This can be achieved with:
xinput --set-prop 11 169 -1 0 0 0 1 0 0 0 1
xmodmap -e "keycode 113 = Right" ; xmodmap -e "keycode 114 = Left"
To revert to normal:
xinput --set-prop 11 169 1 0 0 0 1 0 0 0 1
xmodmap -e "keycode 113 = Left" ; xmodmap -e "keycode 114 = Right"
The number 11 is the id of the mouse, which can be obtained from: xinput --list
The number 169 is right after the Coordinate Transformation Matrix, in parentheses, obtained from xinput --list-props 11
Replace 11 and 169 with numbers that are specific for the mouse you have.
