Hello, I am new to this distro, I have had no problems until this morning, I tried to update a couple of packages and I am having the following error:
The content of the file does not make sense to me, what can I do to solve it?
Start with removing screenshot of text and replace it with preformatted text.
CDN Cache problem in your area. Wait and repeat. Packages are stored on CloudFlare/AWS for Manjaro-Sway. Possible that your country blocks it? Who knows
O.K. I had the same problem and disabled the manjaro-sway repo for the time being to at least update the other packages. Now reactivated it and it works again with manjaro-sway too.
FYI: The main issue tracker for Manjaro sway is the Manjaro sway GitHub issue tracker, not the Manjaro Forum. You can find it here: GitHub - manjaro-sway/manjaro-sway: manjaro linux with wayland 🖼, sway 🌴 and a lot of ♥
