Invalid or corrupted package (PGP signature) warning
getting error message:
invalid or corrupted package (PGP signature):
  Kernel: 6.6.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=946d67f7-e2d1-44f8-96b2-4bf678b3bde9 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm:
    1: GDM v: 44.1 note: stopped 2: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Gigabyte product: H110M-S2H v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: <superuser required>
    UEFI: American Megatrends v: F22 date: 06/12/2017
  Info: model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF4
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 800/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 57616
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ZOTAC driver: nvidia
    v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:1b81 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
    s-diag: 692mm (27.26")
  Monitor-1: Unknown-1 mapped: DP-0 res: 2560x1440 dpi: 109
    size: 598x336mm (23.54x13.23") modes: 1024x768
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 535.113.01
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.264 layers: 6 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1070 driver: nvidia v: 535.113.01
    device-ID: 10de:1b81 surfaces: xcb,xlib
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a170 class-ID: 0403
  Device-2: NVIDIA GP104 High Definition Audio vendor: ZOTAC
    bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
  API: ALSA v: k6.6.0-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
    lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Qualcomm Atheros AR9271 802.11n driver: ath9k_htc type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:6 chip-ID: 0cf3:9271
    class-ID: ff00 serial: <filter>
  IF: wlp0s20f0u4 state: down mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  IF-ID-2: virbr1 state: down mac: <filter>
  IF-ID-3: virbr2 state: down mac: <filter>
  Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
    chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
  Local Storage: total: 931.51 GiB used: 287.52 GiB (30.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DX002-2DV162
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 287.52 GiB (31.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
    used: 300 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 33.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 237 Uptime: 35m wakeups: 0 Memory: total: 16 GiB
  available: 15.58 GiB used: 3.65 GiB (23.4%) Init: systemd v: 254
  Packages: 1853 pm: pacman pkgs: 1837 libs: 476 tools: pamac,yay pm: flatpak
  pkgs: 0 pm: snap pkgs: 16 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: yakuake inxi: 3.3.30
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Please use the search function, there is even tutorial for that, and it has nothing to do with the monthly update so it should have been in the separate thread… and post the error log in the future, not just the inxi. Aaaaand format it with ```
ok thanks
Try
pacman-key --init
pacman-key --populate archlinux manjaro
pacman-key --refresh-keys
and update again.
If this does not help have a look into the wiki:
