Hi, I’ve got an issue similar to this: Can't update or install or search anything from normal repository. Invalid or corrupted database
Always when I try to update or install a package, I get the error prompted from the headline.
The commands from the linked issue produce the following output:
~ >>> cat /etc/pacman.conf [1]
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta = 0.7
Architecture = auto
#IgnorePkg =
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#TotalDownload
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
~ >>> sudo pacman -Syu [1]
error: GPGME error: No data
core 168.9 KiB 3.11 MiB/s 00:00 [#######################################################################################] 100%
extra is up to date
community is up to date
multilib is up to date
error: failed to synchronize all databases (unexpected error)
~ >>> sudo pacman -Scc [130]
sudo pacman-mirrors --country all --api --protocols all --set-branch stable && sudo pacman -Syyu
Cache directory: /var/cache/pacman/pkg/
:: Do you want to remove ALL files from cache? [y/N] y
removing all files from cache...
Database directory: /var/lib/pacman/
:: Do you want to remove unused repositories? [Y/n] y
removing unused sync repositories...
::INFO Branch in config is changed
::INFO Protocols in config is changed
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
0.136 Australia : https://manjaro.lucassymons.net/
0.343 Austria : ftp://mirror.easyname.at/manjaro/
1.860 Bangladesh : http://mirror.xeonbd.com/manjaro/
0.346 Belarus : http://mirror.datacenter.by/pub/mirrors/manjaro/
::China : https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable
::Thailand : ftp://mirror.kku.ac.th/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core 168.9 KiB 2.89 MiB/s 00:00 [#######################################################################################] 100%
extra 1918.1 KiB 11.3 MiB/s 00:00 [#######################################################################################] 100%
community 6.8 MiB 14.9 MiB/s 00:00 [#######################################################################################] 100%
multilib 176.5 KiB 5.74 MiB/s 00:00 [#######################################################################################] 100%
What can I do to fix it?
