Hello
I tried to update my system by running
sudo pacman-mirrors -f
sudo pacman -Syu
With the latter command, I received this output:
error: GPGME error: No data
core 143.6 KiB 1306 KiB/s 00:00 [######################] 100%
extra 8.3 MiB 21.0 MiB/s 00:00 [######################] 100%
multilib 149.2 KiB 11.2 MiB/s 00:00 [######################] 100%
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
How can I fix this?
The following tutorial should be useful;
In the meantime, please provide system information as described (below).
I’m sure someone will help when they are able.
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly;
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Highly Recommended
Required Reading
Technical Resources
Thank you. I am currently running the script outlined here: [HowTo] Work around gpg verification issue on left behind systems
I truly hope this was not an error. If it is, I will respond
Thank you! Your tutorial appears to have worked
