linub
17 December 2021 10:09
1
the links inside an application under “Details” open with Abiword.
did somethig got messed with my file associations?
mimeapps.list
[Added Associations]
application/vnd.openxmlformats-officedocument.wordprocessingml.document=abiword.desktop;
x-scheme-handler/tg=userapp-Telegram Desktop-Y27E10.desktop;
[Default Applications]
x-scheme-handler/etcher=balena-etcher-electron.desktop
x-scheme-handler/skype=skypeforlinux.desktop
x-scheme-handler/tel=org.kde.kdeconnect.handler.desktop
x-scheme-handler/callto=skypeforlinux.desktop
Hi @linub ,
Try the following (from my ~/.config/mimeapps.list):
x-scheme-handler/http=firefox-developer-edition.desktop;
x-scheme-handler/https=firefox-developer-edition.desktop;
(Of course, use your own .desktop file preference.)
Hope this helps!
linub
17 December 2021 10:28
3
can i freely delete lines from this file and they will recreate them selves if needed?
can i delete the whole file and get a clean one next time it needs to be?
I have no idea, but I think so. I might be wrong, though.
Best would be to test. Just rename the file and see:
mv ~/.config/mimeapps.list ~/.config/mimeapps.list.backup
something like this can be done in xfce and gnome too
linub
17 December 2021 10:39
6
it is set correctly on my side,the same as in this picture.
linub
18 December 2021 16:05
7
i renamed it,deleted it but couldn’t get rid of Abiword so i went with @Mirdarthos solution.
i don’t know why it didn’t recreate a blank new file after i renamed or deleted it.
system
Closed
21 December 2021 06:05
8
