I recently bought a 2023 Huawei Matebook 14S and installed both Manjaro and Windows 11 on it. While most things are working fine on Manjaro, I’ve just discovered that the built-in speaker does not work properly on Manjaro Linux while on Windows it is working just fine.
When I check the pavucontrol configurations, there are two options available: 'Play HiFi Quality Music' and 'Pro Audio', none of which would play sound.
What’s more, headphones plugged in with audio jack also play perfectly.
Output for aplay -l:
lspci -nn | grep audio
00:1f.3 Multimedia audio controller [0401]: Intel Corporation Raptor Lake-P/U/H cAVS [8086:51ca] (rev 01)
Output of inxi -A:
Device-1: Intel Raptor Lake-P/U/H cAVS driver: sof-audio-pci-intel-tgl
API: ALSA v: k6.6.1-1-MANJARO status: kernel-api
Server-1: PipeWire v: 0.3.84 status: active
Output of dmesg | grep -E ‘sof|snd’:
[ 0.048286] software IO TLB: area num 32.
[ 1.022154] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.022155] software IO TLB: mapped [mem 0x00000000311ac000-0x00000000351ac000] (64MB)
[ 4.158447] sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
[ 4.158684] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 6.019751] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 6.092386] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
[ 6.131493] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
[ 6.131497] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 6.131501] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 4
[ 6.135881] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 6.135886] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 6.135892] sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
[ 6.250404] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 2:2:0-57864
[ 6.250411] sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:22:1 Kernel ABI 3:23:0
[ 6.268461] sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:22:1 Kernel ABI 3:23:0
[ 6.323958] input: sof-hda-dsp Mic as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input16
[ 6.324070] input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input17
[ 6.324164] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input18
[ 6.324260] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input19
[ 6.324340] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input20
i have tried replacing my kernel with the latest linux66 as is suggested [here](https://bbs.archlinux.org/viewtopic.php?id=290321) but the audio is yet still not working…
When you say built-in speaker does not work properly on Manjaro; what is the exact problem - no sound?
There is a long github issue that might be relevant:
opened 06:34PM - 21 Dec 21 UTC
codec
Community
I tried different distros Ubuntu 21.10/Fedora and now Arch linux. I have an issu… e with speaker, headphone settings.
First of all the laptop has 4 speakers and 4 dijital mics.
Well these are problems:
1) Gnome volume slider does not effect on volume. Each clicks give same beep until below %5 and volume goes down.
2) If I plug a headphone, no sound at headphone and sound still comes from speakers. And after unplugged the headphone, speakers go mutted!
3) To unmut the speakers I have to go alsamixer and select sound card 'sof-hda-dsp' (codec Chip: Conexant CX8070 ) and then I have to unmut headphone
4) I can set speaker's volume from alsamixer's headphone slider. Speaker slider has no effect, Master slider only effect depends on headphone slider point.
**Environment**
1) Branch name and commit hash of the 2 repositories: sof (firmware/topology) and linux (kernel driver).
* Kernel: linux 5.15.10-arch1
* SOF: 1.9.3
2) Name of the topology file
* Topology: {FILE} no idead. (lead me for the file please)
3) Name of the platform(s) on which the bug is observed.
* Platform: Arclinux
I tried several model=NAME options but there is no result.
Here they are, installed alsa packages with sof-bin: alsa-card-profiles, alsa-firmware, alsa-lib, alsa-plugins, alsa-topology-conf, alsa-ucm-conf, alsa-utils, pulseaudio-alsa, zita-alsa-pcmi, sof-firmware, sof-tools
If you need more log, outputs, please lead me :)
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sofhdadsp [sof-hda-dsp], device 0: HDA Analog (*) []
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: sofhdadsp [sof-hda-dsp], device 1: HDA Digital (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 3: HDMI1 (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 4: HDMI2 (*) []
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 5: HDMI3 (*) []
Subdevices: 1/1
pacmd list-sinks
4 sink(s) available.
index: 0
name: <alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink>
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9037
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s24-32le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 170.67 ms
card: 0 <alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic>
module: 6
properties:
alsa.resolution_bits = "32"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = ""
alsa.id = "HDMI3 (*)"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "5"
alsa.card = "0"
alsa.card_name = "sof-hda-dsp"
alsa.long_card_name = "HUAWEI-HKD_WXX-M1010-HKD_WXX_PCB"
alsa.driver_name = "snd_soc_skl_hda_dsp"
device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a0c8"
device.product.name = "Tiger Lake-LP Smart Sound Technology Audio Controller"
device.string = "_ucm0001.hw:sofhdadsp,5"
device.buffering.buffer_size = "65536"
device.buffering.fragment_size = "16384"
device.access_mode = "mmap+timer"
device.profile.name = "HiFi: hw:sofhdadsp,5: sink"
device.profile.description = "HDMI / DisplayPort 3 Output"
alsa.mixer_device = "_ucm0001.hw:sofhdadsp"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
[Out] HDMI3: HDMI / DisplayPort 3 Output (priority 700, latency offset 0 usec, available: no)
properties:
active port: <[Out] HDMI3>
index: 1
name: <alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink>
state: SUSPENDED
suspend cause: IDLE
priority: 9036
balance 0.00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 1
Stereo
used by: 0
linked by: 0
module: 6
properties:
device.api = "alsa"
alsa.name = ""
alsa.id = "HDMI2 (*)"
alsa.device = "4"
alsa.card = "0"
device.bus = "pci"
device.string = "_ucm0001.hw:sofhdadsp,4"
device.profile.name = "HiFi: hw:sofhdadsp,4: sink"
device.profile.description = "HDMI / DisplayPort 2 Output"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output"
ports:
[Out] HDMI2: HDMI / DisplayPort 2 Output (priority 600, latency offset 0 usec, available: no)
properties:
active port: <[Out] HDMI2>
index: 2
name: <alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink>
state: SUSPENDED
suspend cause: IDLE
priority: 9035
balance 0.00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 2
Stereo
used by: 0
linked by: 0
module: 6
properties:
device.api = "alsa"
alsa.name = ""
alsa.id = "HDMI1 (*)"
alsa.device = "3"
alsa.card = "0"
device.bus = "pci"
device.string = "_ucm0001.hw:sofhdadsp,3"
device.profile.name = "HiFi: hw:sofhdadsp,3: sink"
device.profile.description = "HDMI / DisplayPort 1 Output"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output"
ports:
[Out] HDMI1: HDMI / DisplayPort 1 Output (priority 500, latency offset 0 usec, available: no)
properties:
active port: <[Out] HDMI1>
* index: 3
name: <alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: IDLE
suspend cause: (none)
priority: 9032
volume: front-left: 31032 / 47% / -19.48 dB, front-right: 31032 / 47% / -19.48 dB
balance 0.00
volume steps: 65537
muted: no
current latency: 40.32 ms
max request: 15 KiB
max rewind: 15 KiB
monitor source: 3
Stereo
used by: 0
linked by: 2
configured latency: 40.00 ms; range is 0.50 .. 170.67 ms
module: 6
properties:
device.api = "alsa"
alsa.name = ""
alsa.id = "HDA Analog (*)"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
device.string = "_ucm0001.hw:sofhdadsp"
device.profile.name = "HiFi: hw:sofhdadsp: sink"
device.profile.description = "Speaker + Headphones"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones"
ports:
[Out] Speaker: Speaker (priority 100, latency offset 0 usec, available: unknown)
properties:
[Out] Headphones: Headphones (priority 200, latency offset 0 usec, available: no)
properties:
active port: <[Out] Speaker>
sudo lshw -c multimedia
*-usb:1
description: Video
product: USB Camera
vendor: 3730304231385631354A4A
physical id: 6
bus info: usb@3:6
version: 0.0e
serial: 200901010001
capabilities: usb-2.01
configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
*-multimedia
description: Multimedia audio controller
product: Tiger Lake-LP Smart Sound Technology Audio Controller
vendor: Intel Corporation
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 20
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=sof-audio-pci-intel-tgl latency=32
resources: iomemory:600-5ff iomemory:600-5ff irq:168 memory:601d170000-601d173fff memory:601d000000-601d0fffff
arecord -l
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
Subdevices: 1/1
card 0: sofhdadsp [sof-hda-dsp], device 6: DMIC (*) []
Subdevices: 0/1
card 0: sofhdadsp [sof-hda-dsp], device 7: DMIC16kHz (*) []
Subdevices: 1/1
amixer
Simple mixer control 'Master',0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 65536
Mono:
Front Left: Playback 31032 [47%] [on]
Front Right: Playback 31032 [47%] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch cswitch-joined
Capture channels: Front Left - Front Right - Rear Left - Rear Right
Limits: Capture 0 - 65536
Front Left: Capture 65536 [100%] [off]
Front Right: Capture 65536 [100%] [off]
Rear Left: Capture 65536 [100%] [off]
Rear Right: Capture 65536 [100%] [off]
script claims to toggle speaker/headphones output
thnkas buddy, i can confirm the commands
sudo hda-verb /dev/snd/hwC0D0 0x16 0x701 0x0001 // move output to speaker dac
sudo hda-verb /dev/snd/hwC0D0 0x17 0x70C 0x0002 // enable speaker
sudo hda-verb /dev/snd/hwC0D0 0x1 0x715 0x2 // disable headphones
solve the issue on manjaro and fedora linux.
