Hi everyone,
I’m not new to Linux, but I’m still a noob at a lot of stuff. Anyways, I own an Asus ROG Flow Z13 computer, which has an internal SD Card. Attempting to read SD cards on my Manjaro KDE Plasma partition never works. The SD card is shown in Dolphin, but can never mount. This is what ````dmesg | tail -n 10``` looks like:
[ 72.827683] ntfs3: Enabled Linux POSIX ACLs support
[ 72.827691] ntfs3: Read-only LZX/Xpress compression included
[ 76.623745] pcieport 0000:00:1c.0: broken device, retraining non-functional downstream link at 2.5GT/s
[ 77.623672] pcieport 0000:00:1c.0: retraining failed
[ 78.623703] pcieport 0000:00:1c.0: Data Link Layer Link Active not set in 1000 msec
[ 78.623759] rtsx_pci 0000:31:00.0: Unable to change power state from D3cold to D0, device inaccessible
[ 80.767017] mmc0: error -110 doing runtime resume
[ 91.559895] mmc0: card aaaa removed
[ 895.578198] pcieport 0000:00:1c.0: Data Link Layer Link Active not set in 1000 msec
[ 895.578238] rtsx_pci 0000:31:00.0: Unable to change power state from D3cold to D0, device inaccessible
I also would like to note that my laptop has a PCIe slot for plugging in an external GPU. I don’t have one so I don’t think it matters for me.
This is what inxi --admin --verbosity=7 --filter --no-host --width
looks like for me by the way:
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=b32eb167-0613-452f-a1b2-fb1861d85de9 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
Type: Detachable System: ASUSTeK product: ROG Flow Z13 GZ301VU v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: GZ301VU v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: GZ301VU.316
date: 10/24/2024
ID-1: BAT0 charge: 56.8 Wh (100.0%) condition: 56.8/56.0 Wh (101.4%)
volts: 17.7 min: 16.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: full cycles: 9
System RAM: total: 16 GiB available: 15.25 GiB used: 4.22 GiB (27.6%)
Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
max-module-size: 2 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous size: 2 GiB
speed: spec: 6400 MT/s actual: 5200 MT/s volts: curr: 0.5 min: 0.5 max: 0.5
width (bits): data: 16 total: 16 manufacturer: Samsung
part-no: K3LKBKB0BM-MGCP serial: <filter>
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous size: 2 GiB
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous size: 2 GiB
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous size: 2 GiB
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous size: 2 GiB
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous size: 2 GiB
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous size: 2 GiB
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous size: 2 GiB
Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4123
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 915 min/max: 400/5200:5400:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 915 2: 915 3: 915 4: 915
5: 915 6: 915 7: 915 8: 915 9: 915 10: 915 11: 915 12: 915 13: 915 14: 915
15: 915 16: 915 17: 915 18: 915 19: 915 20: 915 bogomips: 119840
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: ASUSTeK driver: i915
v: kernel alternate: xe arch: Xe process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-2,DP-3 bus-ID: 0000:00:02.0 chip-ID: 8086:a7a0
class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 550/565.xx+
status: current (as of 2025-01) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ ports: active: none empty: DP-1,eDP-3
bus-ID: 0000:01:00.0 chip-ID: 10de:28e1 class-ID: 0300
Device-3: Shinetech USB2.0 5M UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:4 chip-ID: 3277:0031
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris,nouveau gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: TL134ADXP01-0 built: 2022 res: mode: 2560x1600
hz: 165 scale: 175% (1.75) to: 1463x914 dpi: 226 gamma: 1.2
size: 288x180mm (11.34x7.09") diag: 340mm (13.4") ratio: 16:10
modes: 2560x1600
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: iris device: 1 drv: nouveau device: 2 drv: swrast gbm:
drv: iris surfaceless: drv: iris wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 7.45 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.303 layers: N/A device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4050 Laptop GPU (NVK AD107) driver: N/A device-ID: 10de:28e1
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: Intel Iris
Xe Graphics (RPL-P) driver: N/A device-ID: 8086:a7a0
Device-1: Intel Raptor Lake IPU vendor: ASUSTeK driver: intel-ipu6
alternate: intel_ipu6 bus-ID: 0000:00:05.0 chip-ID: 8086:a75d class-ID: 0480
Device-2: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51ca class-ID: 0403
Device-3: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:22be
class-ID: 0403
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f1 class-ID: 0280
Device-2: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.3:3 chip-ID: 0b95:1790
class-ID: 0a00 serial: <filter>
IF: enp0s20f0u1u3c2 state: down mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:8 chip-ID: 8087:0033
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 953.87 GiB used: 240.93 GiB (25.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDPTQD-1T00-1002 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 73101000 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 318.89 GiB size: 312.81 GiB (98.10%)
used: 41.74 GiB (13.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: b32eb167-0613-452f-a1b2-fb1861d85de9
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 69.5 MiB (27.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 4C5B-E752
ID-3: /run/media/asad/OS raw-size: 605.48 GiB size: 605.48 GiB (100.00%)
used: 199.12 GiB (32.9%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: OS uuid: 66585D90585D5FBB
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: RECOVERY
uuid: DC7C38B67C388D70
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 28 GiB fs: ntfs label: RESTORE
uuid: 780C1B820C1B3B18
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 260 MiB fs: vfat label: MYASUS
uuid: 2C1B-7C70
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-1:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 3-1.1:5 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Device-2: 3-1.4:7 info: Compx 2.4G Wireless Receiver type: keyboard,mouse
lanes: 1 mode: 1.1 power: 98mA chip-ID: 3554:fa09 class-ID: 0301
Device-3: 3-1.5:9 info: Anker USB-C Hub Device type: billboard driver: N/A
power: 100mA chip-ID: 291a:8365 class-ID: 1100 serial: <filter>
Device-4: 3-4:3 info: Winbond USB Device type: HID
driver: hid-generic,hid-sensor-hub,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 20mA
chip-ID: 0416:5020 class-ID: 0300 serial: <filter>
Device-5: 3-8:4 info: Shinetech USB2.0 5M UVC WebCam type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 3277:0031 class-ID: fe01 serial: <filter>
Device-6: 3-9:6 info: ASUSTek N-KEY Device type: keyboard
driver: asus,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:18c6 class-ID: 0301
Device-7: 3-10:8 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 4-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
Device-1: 4-1.3:3 info: ASIX AX88179 Gigabit Ethernet
type: communication,CDC-data driver: cdc_ncm interfaces: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 184mA
chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 357 Power: uptime: 21m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.07 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1401 pm: pacman pkgs: 1380 libs: 386 tools: pamac pm: rpm pkgs: 0
pm: flatpak pkgs: 21 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
If anyone can help me fix this issue with my SD Card slot I’d really appreciate it. Also let me knwo if my formatting is messed up, I don’t usually post to forums so I don’t know much about formatting posts.
