Hello,
My laptop’s internal microphone was working fine, untill it suddenly stops working. I do not know why. I did not even update my kernel. There are some similar posts in the forum. I have looked into all of them. But none of them are addressing my issue.
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7151649b-586a-41d1-a2ac-16cdeaface39 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: GL502VSK v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: GL502VSK v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GL502VSK.309 date: 05/03/2019
ID-1: BAT0 charge: 53.0 Wh (100.0%) condition: 53.0/60.7 Wh (87.4%)
volts: 15.1 min: 15.1 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 12
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 869 high: 900 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 848 2: 844 3: 864 4: 856
5: 900 6: 898 7: 888 8: 855 bogomips: 44817
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP104BM [GeForce GTX 1070 Mobile] vendor: ASUSTeK
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1be1 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 13d3:5666 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 508x572mm (20.00x22.52")
s-diag: 765mm (30.12")
Monitor-1: DP-0 pos: primary,bottom res: 1920x1080 hz: 120 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
Monitor-2: HDMI-0 pos: top res: 1920x1080 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
1070/PCIe/SSE2 direct render: Yes
Device-1: Intel CM238 HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.63 running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: AzureWave driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-9:8
chip-ID: 13d3:3491 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.05 TiB used: 185.54 GiB (8.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: A020 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 2108 scheme: MBR
ID-1: / raw-size: 439.46 GiB size: 431.49 GiB (98.19%)
used: 185.51 GiB (43.0%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 27.4 MiB (10.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 59.0 C pch: 57.0 C mobo: N/A gpu: nvidia
temp: 58 C
Fan Speeds (RPM): cpu: 2500
Processes: 295 Uptime: 4m wakeups: 1 Memory: 15.58 GiB
used: 2.65 GiB (17.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1499 libs: 426 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.24
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 86
Tile Size: 65472
User Name: mohammad
Host Name: mohammad-gl502vsk
Server Name: PulseAudio (on PipeWire 0.3.63)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Default Source: alsa_input.pci-0000_00_1f.3.analog-stereo
Cookie: 99a6:73f7
