Internal microphone not working
Internal Microphone not working.
The voice intensity is shows maximum in volume control.
I tried switching back and forth between pipewire & pulseaudio, both seems to give same result. The voice recording has high volume noise.
$ inxi -Faxz
  Kernel: 5.18.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
    root=UUID=38422d63-8f74-4526-8fc7-5323de68cca6 rw apparmor=1
    security=apparmor resume=UUID=9ce2076f-8ca5-4041-85e1-bfef8888b750
    udev.log_priority=3
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
    base: Arch Linux
  Type: Laptop System: Dell product: Inspiron 15 3511 v: N/A
  Mobo: Dell model: 0042CN v: A00 serial: <superuser required> UEFI: Dell
    v: 1.12.1 date: 04/27/2022
  ID-1: BAT0 charge: 32.9 Wh (89.2%) condition: 36.9/40.4 Wh (91.4%)
    volts: 12.7 min: 11.2 model: SMP DELL MGCM51A type: Li-poly
    serial: <filter> status: charging
  Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake built: 2020 process: Intel 10nm family: 6
    model-id: 0x8C (140) stepping: 1 microcode: 0xA4
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 928 high: 1183 min/max: 400/4200 scaling:
    driver: intel_pstate governor: powersave cores: 1: 731 2: 894 3: 1119
    4: 799 5: 992 6: 661 7: 1051 8: 1183 bogomips: 38720
  Type: spectre_v2
    mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
    driver: i915 v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
    bus-ID: 1-6:3 chip-ID: 0c45:6d1a class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
    compositor: xfwm v: 4.16.1 driver: X: loaded: modesetting
    alternate: fbdev,vesa gpu: i915 display-ID: :0.0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: LG Display 0x06ff built: 2021 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
    bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.18.7-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 16.1 running: no
  Sound Server-4: PipeWire v: 0.3.52 running: yes
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000
    bus-ID: 0000:01:00.0 chip-ID: 10ec:c821 class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-10:4 chip-ID: 0bda:c829 class-ID: e001 serial: <filter>
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
    class-ID: 0104
  Local Storage: total: 476.94 GiB used: 151.05 GiB (31.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel
    model: 670p SSDPEKNU512GZ NVMe 512GB size: 476.94 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 7003 temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 331.35 GiB size: 325.08 GiB (98.11%)
    used: 151.05 GiB (46.5%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p8 maj-min: 259:8
  System Temperatures: cpu: 61.0 C mobo: N/A
  Processes: 243 Uptime: 3m wakeups: 1 Memory: 15.37 GiB
  used: 2.45 GiB (15.9%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1208
  lib: 329 flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
  inxi: 3.3.19
$ pacmd list-cards
bash: pacmd: command not found
$ arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC3204 Analog [ALC3204 Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
The microphone which is shown as unplugged could be the internal microphone:
How do I fix it?
Did you installed the sof-firmware and alsa-ucm-conf packages?
Check this [Solved] No audio sinks to play sound to / Newbie Corner / Arch Linux Forums
See in alsamixer if the option Auto-Mute Mode is enabled and disable it.
I have both packages sof-firmware and alsa-ucm-conf installed.
alsamixer shows this:
Is this mute?
$ sudo dmesg | grep -iE 'snd|sof'
[    0.246873] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.282322] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.282322] software IO TLB: mapped [mem 0x000000005378f000-0x000000005778f000] (64MB)
[    2.662682] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[    2.662882] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    2.663712] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    2.834836] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC3204: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[    2.834842] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.834844] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[    2.834846] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    2.834847] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    2.834848] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
[    2.834850] snd_hda_codec_realtek hdaudioC0D0:      Headphone Mic=0x1a
[    2.834851] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
$ lspci -k
0000:00:00.0 Host bridge: Intel Corporation 11th Gen Core Processor Host Bridge/DRAM Registers (rev 01)
	Subsystem: Dell Device 0ab0
	Kernel modules: igen6_edac
0000:00:02.0 VGA compatible controller: Intel Corporation TigerLake-LP GT2 [Iris Xe Graphics] (rev 01)
	Kernel driver in use: i915
	Kernel modules: i915
0000:00:04.0 Signal processing controller: Intel Corporation TigerLake-LP Dynamic Tuning Processor Participant (rev 01)
	Kernel driver in use: proc_thermal
	Kernel modules: processor_thermal_device_pci_legacy
0000:00:0a.0 Signal processing controller: Intel Corporation Tigerlake Telemetry Aggregator Driver (rev 01)
	Kernel driver in use: intel_vsec
	Kernel modules: intel_vsec
0000:00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller
	Kernel driver in use: vmd
	Kernel modules: vmd
0000:00:14.0 USB controller: Intel Corporation Tiger Lake-LP USB 3.2 Gen 2x1 xHCI Host Controller (rev 20)
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
0000:00:14.2 RAM memory: Intel Corporation Tiger Lake-LP Shared SRAM (rev 20)
0000:00:15.0 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #0 (rev 20)
	Kernel driver in use: intel-lpss
	Kernel modules: intel_lpss_pci
0000:00:15.1 Serial bus controller: Intel Corporation Tiger Lake-LP Serial IO I2C Controller #1 (rev 20)
0000:00:16.0 Communication controller: Intel Corporation Tiger Lake-LP Management Engine Interface (rev 20)
	Kernel driver in use: mei_me
	Kernel modules: mei_me
0000:00:17.0 System peripheral: Intel Corporation Device 09ab
0000:00:1d.0 PCI bridge: Intel Corporation Device a0b1 (rev 20)
	Kernel driver in use: pcieport
0000:00:1f.0 ISA bridge: Intel Corporation Tiger Lake-LP LPC Controller (rev 20)
0000:00:1f.3 Audio device: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller (rev 20)
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
0000:00:1f.4 SMBus: Intel Corporation Tiger Lake-LP SMBus Controller (rev 20)
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
0000:00:1f.5 Serial bus controller: Intel Corporation Tiger Lake-LP SPI Controller (rev 20)
	Kernel driver in use: intel-spi
	Kernel modules: spi_intel_pci
0000:01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
	Subsystem: Realtek Semiconductor Co., Ltd. Device c828
	Kernel driver in use: rtw_8821ce
	Kernel modules: rtw88_8821ce
10000:e0:17.0 SATA controller: Intel Corporation Device a0d3 (rev 20)
	Kernel driver in use: ahci
10000:e0:1c.0 System peripheral: Intel Corporation Device 09ab
10000:e0:1c.4 PCI bridge: Intel Corporation Device a0bc (rev 20)
10000:e1:00.0 Non-Volatile memory controller: Intel Corporation Device f1aa (rev 03)
	Subsystem: Intel Corporation Device 390f
	Kernel driver in use: nvme
	Kernel modules: nvme
$ cat /etc/asound.conf
cat: /etc/asound.conf: No such file or directory
$ cat ~/.asoundrc
cat: /home/anks/.asoundrc: No such file or directory
Press F6 and select the card …
