My current wifi card is:
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0608
class-ID: 0280
This is a junk, not a proper card, so I want to replace it with a stronger one. I bought:
Intel Card BE200 WiFi 7 802.11AX 6GHz M.2 PCIe
The problem is, the laptop doesn’t boot after the exchange, there is only black screen and quiet fan humming, and keyboard lights, but the screen stays black infinitely. I can’t get into the BIOS/UEFI. When I go back to my old wifi card, all starts to work. I tried two times with the same result.
Either the new card is broken or simply not compatible with my motherboard.
The question is, can someone advise me on how to find a new, powerful wifi card that will be compatible? Possibly on the same spec level and the Intel Card BE200 WiFi 7:
https://www.intel.com/content/www/us/en/products/sku/230078/intel-wifi-7-be200/specifications.html
I’ve been searching online for some info, but it is surprisingly sparse. Mostly some very general info for PC wifi cards, never for laptop ones, and specs are not explained anywhere. I bought basically blindly, The same socket, form factor, sizes - it can be successfully installed, but it is not enough as it seems.
I can post photos of those cards, so you could see how one compares to the other physically. When it comes to specs, it’s a night and day, The current card is as trashy as possible, while the new one is from upper shelf, alas not working for me.
Both cards are M.2 2230.
