Internal camera is not working
Hi all,
Recently I got a problem with my internal camera. Just stopped working. I don’t have any issue with a usb webcam (Logi C920). Any kind of help is much appreciated.
https://imgur.com/FxkCjhY.png
Imgur
~ ❯ lsusb
Bus 001 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 004: ID 0cf3:e500 Qualcomm Atheros Communications
Bus 001 Device 065: ID 174f:2426 Syntek Integrated Camera
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
~ ❯ v4l2-ctl --list-devices
Integrated Camera: Integrated C (usb-0000:00:14.0-6):
	/dev/video0
	/dev/video1
	/dev/media0
Hi @wils0n,
Please provide the output for:
/usr/bin/inxi --admin --verbosity=8
  Host: lenovo Kernel: 6.9.3-2-MANJARO arch: x86_64 bits: 64
    compiler: gcc v: 14.1.1 clocksource: tsc avail: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=8a4121af-3d0b-415e-af8d-eada59f0f37a rw quiet apparmor=1
    security=apparmor resume=UUID=fe9298f7-cef3-4d54-bf25-dfee493000ac
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 81N8 v: Lenovo IdeaPad S340-15IWL
    serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad
    S340-15IWL serial: <superuser required>
  Mobo: LENOVO model: LNVNB161216 v: No DPK
    part-nu: LENOVO_MT_81N8_BU_idea_FM_IdeaPad S340-15IWL
    uuid: <superuser required> UEFI: LENOVO v: ALCN24WW(V2.01)
    date: 03/29/2019
  ID-1: BAT1 charge: 41.9 Wh (100.0%) condition: 41.9/52.5 Wh (79.9%)
    volts: 12.8 min: 11.2 model: Celxpert L18C3PF7 type: Li-ion
    serial: 3272 status: full cycles: 1104
  Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device
    Mouse serial: 23-e1-84-9c charge: 55% (should be ignored)
    rechargeable: yes status: discharging
  System RAM: total: 12 GiB available: 11.41 GiB used: 7.42 GiB (65.1%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 4 GiB
    speed: 2400 MT/s volts: curr: 1 min: 2 max: 2 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M471A5244CB0-CTD serial: N/A
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    total: 64 manufacturer: 86d3 part-no: N/A serial: N/A
  Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xFA
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 799 high: 800 min/max: 400/3900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 799
    4: 800 5: 800 6: 800 7: 800 8: 800 bogomips: 28808
    clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
    dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
    hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid lahf_lm lm
    mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse
    pse36 pts rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
    tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1
    xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
  Type: spec_store_bypass mitigation: Speculative Store Bypass
    disabled via prctl
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user
    pointer sanitization
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop,
    KVM: SW loop
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
    ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX230] vendor: Lenovo driver: nvidia
    v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2024-04; EOL~2026-12-xx) arch: Pascal
    code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
    speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s
    bus-ID: 01:00.0 chip-ID: 10de:1d11 class-ID: 0302
  Device-3: Syntek Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:95
    chip-ID: 174f:2426 class-ID: 0e02 serial: 200901010001
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: xfwm4 v: 4.18.0 driver: X: loaded: modesetting
    unloaded: nvidia alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96
    s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: LG Display 0x05e5 built: 2018 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.369 green:
    x: 0.349 y: 0.557 blue: x: 0.153 y: 0.110 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1920x1080
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa
    v: 24.0.9-manjaro1.1 glx-v: 1.4 direct-render: yes renderer: Mesa
    Intel UHD Graphics 620 (WHL GT2) device-ID: 8086:3ea0
    memory: 11.14 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce MX230 driver: nvidia v: 550.90.07
    device-ID: 10de:1d11 surfaces: xcb,xlib
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:9dc8
    class-ID: 0403
  API: ALSA v: k6.9.3-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module
    tools: pacat,pactl,pavucontrol
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042
    class-ID: 0280
  IF: wlp3s0 state: up mac: e8:d0:fc:dc:f5:65
  IP v4: 192.168.0.205/24 type: noprefixroute scope: global
    broadcast: 192.168.0.255
  IP v6: fe80::c7d3:2e54:c226:ea52/64 type: noprefixroute scope: link
  WAN IP: 94.236.128.111
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 0cf3:e500
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 2 state: up
    address: E8:D0:FC:DC:F5:66 bt-v: 4.2 lmp-v: 8 status: discoverable: no
    pairing: no class-ID: 6c010c
  Local Storage: total: 476.94 GiB used: 410.06 GiB (86.0%)
  SMART Message: Required tool smartctl not installed. Check
    --recommends
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC
    SN520 SDAPMUW-512G-1101 size: 476.94 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD
    serial: 192227801595 fw-rev: 20210001 temp: 44.9 C scheme: GPT
  ID-1: / raw-size: 59.96 GiB size: 58.72 GiB (97.93%)
    used: 39.89 GiB (67.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 8a4121af-3d0b-415e-af8d-eada59f0f37a
    used: 152 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: DCD1-F460
  ID-3: /home raw-size: 414.47 GiB size: 406.9 GiB (98.17%)
    used: 370.17 GiB (91.0%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 58eee25b-823b-4356-90f6-5a647b4a7342
    zswap: yes compressor: zstd max-pool: 20%
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: fe9298f7-cef3-4d54-bf25-dfee493000ac
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid
    interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-6:95 info: Syntek Integrated Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:2426 class-ID: 0e02
  Device-3: 1-10:4 info: Qualcomm Atheros type: bluetooth driver: btusb
    power: 100mA chip-ID: 0cf3:e500 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1
  System Temperatures: cpu: 54.0 C pch: 51.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 2311 pm: pacman pkgs: 2278 libs: 586 tools: pamac,yay
    pm: flatpak pkgs: 24 pm: snap pkgs: 9
    1: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    3: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    4: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    5: https://manjaro.kurdy.org/stable/$repo/$arch
    6: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    7: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    8: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
    9: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    10: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    11: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    12: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    13: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    14: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    15: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    18: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    19: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    20: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    21: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    22: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    24: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    25: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://mirror.init7.net/manjaro/stable/$repo/$arch
    28: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    29: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    30: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    31: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    32: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    33: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    34: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    36: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    37: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    38: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    39: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    40: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    41: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    42: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    43: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    44: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    45: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    46: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    47: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    48: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    49: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    50: https://mirror.23m.com/manjaro/stable/$repo/$arch
    51: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    52: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    53: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    54: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    55: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    56: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    57: https://mirrors2.manjaro.org/stable/$repo/$arch
    58: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    59: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    60: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    61: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    62: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    63: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    64: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    65: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    66: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    67: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    68: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    69: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    70: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    71: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    72: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    73: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    74: https://manjaro.ynh.ovh/stable/$repo/$arch
    75: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    76: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    77: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    78: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    79: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    80: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 305
  1: cpu: 23.0% command: firefox pid: 5373 mem: 814.2 MiB (6.9%)
  2: cpu: 12.7% command: alacritty pid: 18984 mem: 87.7 MiB (0.7%)
  3: cpu: 8.6% command: firefox pid: 18496 mem: 955.5 MiB (8.1%)
  4: cpu: 7.1% command: Xorg pid: 1027 mem: 88.6 MiB (0.7%)
  5: cpu: 6.2% command: firefox pid: 13595 mem: 349.0 MiB (2.9%)
  Memory top: 5 of 305
  1: mem: 955.5 MiB (8.1%) command: firefox pid: 18496 cpu: 8.6%
  2: mem: 814.2 MiB (6.9%) command: firefox pid: 5373 cpu: 23.0%
  3: mem: 553.8 MiB (4.7%) command: firefox pid: 5507 cpu: 2.1%
  4: mem: 536.7 MiB (4.5%) command: firefox pid: 8741 cpu: 2.0%
  5: mem: 486.4 MiB (4.1%) command: firefox pid: 13425 cpu: 3.6%
  Processes: 305 Power: uptime: 56m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 4.54 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 255
  Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: fish v: 3.7.1
    running-in: alacritty inxi: 3.3.34
Well, If it’s not this one:
Which, judging from your description:
…it’s probably not it, then I don’t really know what top suggest except trying a different, slightly older kernel. I recommend 6.1.
To install it, run:
sudo mhwd-kernel --install linux61
Reboot into it:
All available kernels installed on your system will be presented upon booting up. GNU GRUB is visible with a couple of options. Choose “Advanced Options for Manjaro Linux” by using the arrow keys ↑ ↓ on your keyboard and then ↵ Enter.
On the next screen (as illustrated) are backup copies of each kernel version installed (which will also be automatically removed if or when a kernel version is deleted). To select a kernel, simply use the arrow keys ↑ ↓ to highlight the desired version, and then press ↵ Enter.
–Manjaro Kernels - Manjaro
And remove the current one:
sudo mhwd-kernel --remove linux69
Hi, still the same. Linux kernel 6.1 and 6.6
Then I’m going with hardware…
Occasionally the camera will work. I don’t know exactly what the cause is. Yesterday it happened to run for a bit then quite a few times I had no success.
The randomness makes it sound like a loose/faulty connection.
Thank you, I’ll be watching it.
