Hey everyone!
For half a year I have been suffering with complete freezes of the laptop, only turning off by pressing the power button helps. Tried the solutions found on the forum, but nothing helps.
I tried to switch to proprietary drivers, but I get a black screen when loading. Also tried different kernels.
As I understand it, buying laptop for linux os with dual graphics was a mistake…
Please help me understand what is the problem.
inxi -v7azy
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8f8a14f7-620d-447f-a658-6461c1f45cab rw quiet
resume=UUID=9d6cdea1-74c3-464f-a36b-33794983a92f udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Micro-Star product: Pulse GL76 12UEK v: REV:1.0
Mobo: Micro-Star model: MS-17L3 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E17L3IMS.10A date: 06/09/2022
ID-1: BAT1 charge: 46.9 Wh (96.5%) condition: 48.6/52.0 Wh (93.5%)
volts: 12.7 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
RAM: total: 15.33 GiB used: 7.3 GiB (47.6%)
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2019 high: 2700 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 421 2: 2700 3: 437 4: 433
5: 2700 6: 2700 7: 2700 8: 2700 9: 2700 10: 491 11: 2700 12: 2700 13: 401
14: 2700 15: 2700 16: 400 17: 2700 18: 2700 19: 2700 20: 2700
bogomips: 107560
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:46a6
class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nouveau v: kernel non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: nvidia gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x978f built: 2020 res: 1920x1080
dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Micro-Star MSI
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: br-0916a7e11115 state: down mac: <filter>
IF-ID-2: br-0cf74a178232 state: down mac: <filter>
IF-ID-3: br-331cfbcffa3e state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-4: br-8fac8848034f state: down mac: <filter>
all]
IF-ID-5: docker0 state: down mac: <filter>
all]
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-10:3
chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 276.8 GiB (58.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA512TFK
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: V5MA010 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 459.77 GiB size: 451.48 GiB (98.20%)
used: 276.8 GiB (61.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 8f8a14f7-620d-447f-a658-6461c1f45cab
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 4E7C-AEA3
ID-1: swap-1 type: partition size: 16.87 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 9d6cdea1-74c3-464f-a36b-33794983a92f
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-7:2 info: Micro Star MysticLight MS-1563 v0001 type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 1462:1563 class-ID: 0300 serial: <filter>
Device-2: 1-10:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 436 Uptime: 34m wakeups: 4469 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1152 libs: 328 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-vesa 2017.03.12 true PCI
video-modesetting 2020.01.13 true PCI
