When I apply the video effects, nothing happens, but if I record it with Vokoscreen & then watch the recording in VLC they are applied. Why is this happening? Here is the oddest part, on another video, the effects apply when I do then in VLC.
Effects and Filters Not Working - The VideoLAN Forums
Are you using hardware decoding acceleration? That can’t be combined with (most) filters since the CPU does not see the pictures.
reddit.com/r/VLC - Effects and Filters not working
https://i.imgur.com/yAe9rPx.png
Go to the Simple Preferences view → Input / Codecs and disable Hardware-accelerated decoding to fix this issue.
The effects don’t work with hardware accelerated decoding
Thanks.
