Intel Wireless 7265 on latest marjaro. No wifi
Not just Manjaro but tried 7 different distros. No wifi working.
Did update
Tried different kernels from the kernel swicher 4.19272-1 5.4.231-1 5.10.167-1 6.1.12-1
no bueno.
I know the adaptor was working with Manjaro but I had to do a fresh install because the computer was in storage and I hadn’t updated Manjaro for 2 years. The update completly (which I figured it would) failed so I did a fresh install. Wifi was 100% working on the old Manjaro.
lspci | grep Intel
00:18.3 Signal processing controller: Intel Corporation Celeron/Pentium Silver Processor Serial IO UART Host Controller (rev 06)
00:1c.0 SD Host controller: Intel Corporation Celeron/Pentium Silver Processor SDA Standard Compliant SD Host Controller (rev 06)
00:1e.0 SD Host controller: Intel Corporation Device 31d0 (rev 06)
00:1f.0 ISA bridge: Intel Corporation Celeron/Pentium Silver Processor LPC Controller (rev 06)
00:1f.1 SMBus: Intel Corporation Celeron/Pentium Silver Processor Gaussian Mixture Model (rev 06)
04:00.0 Network controller: Intel Corporation Wireless 7265 (rev 59)
uname -r
4.19.272-1-MANJARO
ls /lib/firmware | grep iwlwifi
iwlwifi-7265-17.ucode
iwlwifi-7265D-22.ucode
iwlwifi-7265D-27.ucode
iwlwifi-7265D-29.ucode
iwlwifi-8000C-22.ucode
sudo dmesg | grep iwl
[    5.624890] iwlwifi 0000:04:00.0: Refused to change power state, currently in D3
[    5.685751] iwlwifi 0000:04:00.0: Refused to change power state, currently in D3
[    5.685990] iwlwifi 0000:04:00.0: pci_enable_msi failed - -22
[    5.689726] iwlwifi 0000:04:00.0: loaded firmware version 17.3216344376.0 op_mode iwlmvm
[    5.997396] iwlwifi 0000:04:00.0: Detected Intel(R) Dual Band Wireless AC 7265, REV=0xFFFFFFFF
[    5.997403] iwlwifi 0000:04:00.0: Error, can not clear persistence bit
[    6.014125] WARNING: CPU: 3 PID: 571 at drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2030 iwl_trans_pcie_grab_nic_access+0x1f9/0x230 [iwlwifi]
[    6.014127] Modules linked in: iwlmvm(+) mac80211 loop snd_soc_skl snd_soc_skl_ipc snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core intel_rapl intel_telemetry_pltdrv intel_punit_ipc intel_telemetry_core intel_pmc_ipc iwlwifi x86_pkg_temp_thermal intel_powerclamp i915 snd_compress ac97_bus coretemp snd_pcm_dmaengine kvm_intel kvmgt vfio_mdev mdev vfio_iommu_type1 vfio kvm crct10dif_pclmul crc32_pclmul ghash_clmulni_intel 8250_dw snd_hda_intel pcbc cfg80211 snd_hda_codec r8169 irqbypass i2c_algo_bit snd_hda_core aesni_intel snd_hwdep aes_x86_64 realtek drm_kms_helper snd_pcm crypto_simd cryptd glue_helper snd_timer libphy intel_cstate intel_rapl_perf rfkill nls_iso8859_1 mei_me wdat_wdt pcspkr intel_gtt syscopyarea nls_cp437 sysfillrect idma64 i2c_i801
[    6.014177] RIP: 0010:iwl_trans_pcie_grab_nic_access+0x1f9/0x230 [iwlwifi]
[    6.014202]  iwl_write_prph+0x35/0x80 [iwlwifi]
[    6.014211]  iwl_pcie_apm_init+0x1d9/0x230 [iwlwifi]
[    6.014220]  iwl_pcie_apm_stop+0x40f/0x440 [iwlwifi]
[    6.014228]  iwl_trans_pcie_op_mode_leave+0xa4/0x1d0 [iwlwifi]
[    6.014244]  iwl_op_mode_mvm_start+0x878/0x9e0 [iwlmvm]
[    6.014254]  _iwl_op_mode_start.isra.0+0x43/0x90 [iwlwifi]
[    6.014262]  iwl_opmode_register+0x6d/0xd0 [iwlwifi]
[    6.014277]  iwl_mvm_init+0x34/0x1000 [iwlmvm]
[    6.014314] iwlwifi 0000:04:00.0: iwlwifi transaction failed, dumping registers
[    6.014316] iwlwifi 0000:04:00.0: iwlwifi device config registers:
[    6.014330] iwlwifi 0000:04:00.0: 00000000: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[    6.014332] iwlwifi 0000:04:00.0: 00000020: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[    6.014333] iwlwifi 0000:04:00.0: iwlwifi device memory mapped registers:
[    6.014342] iwlwifi 0000:04:00.0: 00000000: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[    6.014343] iwlwifi 0000:04:00.0: 00000020: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[    6.014514] iwlwifi 0000:04:00.0: iwlwifi parent port (0000:00:14.1) config registers:
[    6.014525] iwlwifi 0000:00:14.1: 00000000: 31d78086 00100407 060400f6 00810010 00000000 00000000 00040400 200000f0
[    6.014527] iwlwifi 0000:00:14.1: 00000020: a110a110 0001fff1 00000000 00000
sudo dmesg
[    5.705963] loop: module loaded
[    5.851035] audit: type=1130 audit(1677906395.469:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.865241] audit: type=1130 audit(1677906395.479:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.877769] audit: type=1130 audit(1677906395.499:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=plymouth-quit-wait comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.878286] audit: type=1130 audit(1677906395.499:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=plymouth-quit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.902352] fbcon: inteldrmfb (fb0) is primary device
[    5.902354] fbcon: Deferring console take-over
[    5.902357] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    5.904536] audit: type=1130 audit(1677906395.519:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.014084] ------------[ cut here ]------------
[    6.014085] Timeout waiting for hardware access (CSR_GP_CNTRL 0xffffffff)
[    6.014149]  snd intel_lpss_pci sysimgblt i2c_hid processor_thermal_device vfat intel_lpss mei fb_sys_fops soundcore intel_soc_dts_iosf hid fat ac pcc_cpufreq int3400_thermal int3403_thermal acpi_thermal_rel int340x_thermal_zone int3406_thermal dptf_power evdev mac_hid drm crypto_user fuse agpgart dmi_sysfs ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 sd_mod crc32c_intel ahci libahci sdhci_pci libata cqhci sdhci xhci_pci mmc_core xhci_hcd scsi_mod
[    6.014166] CPU: 3 PID: 571 Comm: modprobe Not tainted 4.19.272-1-MANJARO #1
[    6.014167] Hardware name: $(DEFAULT_STRING) $(DEFAULT_STRING)/$(DEFAULT_STRING), BIOS 5.13 08/31/2020
[    6.014179] Code: 71 d9 49 8d 56 08 bf 40 01 00 00 e8 a1 f3 45 d8 e9 33 ff ff ff 89 c6 48 c7 c7 a8 f1 e5 c0 c6 05 b8 4b 03 00 01 e8 fc 8a c1 d8 <0f> 0b e9 ee fe ff ff 48 8b 7b 30 48 c7 c1 10 f2 e5 c0 31 d2 31 f6
[    6.014180] RSP: 0018:ffffa061015dfc40 EFLAGS: 00010086
[    6.014182] RAX: 0000000000000000 RBX: ffff906aa67d0018 RCX: 0000000000000006
[    6.014182] RDX: 0000000000000007 RSI: 0000000000000096 RDI: ffff906ab7b9b5b0
[    6.014183] RBP: 0000000000000000 R08: 000000000000037e R09: 0000000000000001
[    6.014184] R10: 0000000000000001 R11: 0000000000000000 R12: ffff906aa67da258
[    6.014184] R13: ffffa061015dfc78 R14: 00000000ffffffff R15: ffff906ab3a555a0
[    6.014186] FS:  00007feec7e3b740(0000) GS:ffff906ab7b80000(0000) knlGS:0000000000000000
[    6.014187] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[    6.014188] CR2: 00007f0894777e60 CR3: 0000000264e14000 CR4: 0000000000340ee0
[    6.014189] Call Trace:
[    6.014264]  ? 0xffffffffc0f34000
[    6.014278]  ? 0xffffffffc0f34000
[    6.014283]  do_one_initcall+0x46/0x1c0
[    6.014287]  ? kmem_cache_alloc_trace+0x14c/0x1b0
[    6.014291]  do_init_module+0x4c/0x260
[    6.014293]  __se_sys_init_module+0x166/0x190
[    6.014296]  do_syscall_64+0x4e/0x110
[    6.014300]  entry_SYSCALL_64_after_hwframe+0x5c/0xc1
[    6.014302] RIP: 0033:0x7feec7f48eee
[    6.014304] Code: 48 8b 0d 85 ee 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 52 ee 0c 00 f7 d8 64 89 01 48
[    6.014304] RSP: 002b:00007ffc8a8a2598 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
[    6.014306] RAX: ffffffffffffffda RBX: 000055981b370c80 RCX: 00007feec7f48eee
[    6.014306] RDX: 0000559819fe3cb2 RSI: 00000000000d3c01 RDI: 000055981bb7f510
[    6.014307] RBP: 0000559819fe3cb2 R08: 000055981b373830 R09: 00007feec8018aa0
[    6.014308] R10: 0000000000000005 R11: 0000000000000246 R12: 0000000000040000
[    6.014309] R13: 000055981b370ae0 R14: 0000000000000000 R15: 000055981b3717a0
[    6.014310] ---[ end trace 5b9d5c0a8f8820b2 ]---
[    6.014527] iwlwifi 0000:00:14.1: 00000020: a110a110 0001fff1 00000000 00000000 00000000 00000040 00000000 0010020b
https://wiki.archlinux.org/title/Network_configuration/Wireless#iwlwifi
Try
Create file as root
/etc/modprobe.d/iwlwifi.conf
options iwlwifi 11n_disable=1 swcrypto=1
Save changes.
Reboot.
Reference
https://bugzilla.redhat.com/show_bug.cgi?id=1213673
