I’ve got an Intel NUC11PAHi5 set up as a media player, connected to a TV w/ HDMI, running fully updated Manjaro w/ KDE, kernel 5.10, pulseaudio.
After a reboot, there’s no sound on the TV, although apps seem to work fine (ie: VLC, aplay, etc). Whatever I try software-wise (eg: kill pulse audio, suspend sink, pavucontrol, source change, …) doesn’t make any difference… the sound will only start playing after I disconnect and reconnect HDMI. I’ve examined PA sink & card info after a reboot, while a video was playing and there was no sound, and when I did a reconnect… I couldn’t find any difference in configuration (even ran outputs thru a diff), except for sink index number change after a reconnect (it’s 0 after a reboot, and 2 after a reconnect).
what am I missing?
tnx.
PS: it’s not hardware… the same NUC booted to W11 works flawlessly.
I came back to this, tried a few other things (ie pipewire, upgraded the kernel to 6.10), but to no avail. I also bought a mini HDMI 2 port switch, in hopes that after a reboot I would be able to just switch it briefly to the other (unconnected) port and back, and get the sound working, but it doesn’t help… I still have to physically pull the cable out (albeit from the HDMI switch now) and reconnect it to get the sound.
So, throwing some additional hardware at a software problem didn’t work.
Anybody?
PulseAudio data shows sink-input from VLC media player is in a corked state:
1 sink input(s) available.
index: 0
driver: <protocol-native.c>
flags: START_CORKED FIX_RATE
state: CORKED
sink: 2 <alsa_output.pci-0000_00_1f.3.hdmi-stereo>
Archwiki suggests users disable loading of module-role-cork in /etc/pulse/default.pa so audio applications cannot be corked by an incoming VOIP call
sudo sed -i '/load-module module-role-cork/s/^/#/' /etc/pulse/default.pa
and restart PulseAudio
systemctl --user restart pulseaudio
wiki.archlinux.org/title/PulseAudio/Troubleshooting - Starting an application interrupts other app’s sound
Hi. Thank you for your assistance, but this doesn’t make any difference… on reboot there’s no audio, like described… only a physical disconnect and reconnect of HDMI will produce audio.
PS: the config you quoted is post-reconnect - it shows sink id as 2. after reboot it’s listed as 0… you have any idea why this is the case?
I suggest delete PulseAudio user databases and cookie
rm ~/.config/pulse/*.tdb ~/.config/pulse/cookie
Reboot system so PulseAudio creates new database and cookie files
And post more information about PulseAudio module, profile and sink configurations for non-working state
pacmd dump
check module-role-cork is not loaded
If the card profile is not set to the working profile (HDMI stereo out + analog stereo in)
pactl set-card-profile alsa_card.pci-0000_00_1f.3 output:hdmi-stereo+input:analog-stereo
Once the profile is set to use HDMI output, check output is not muted or suspended in pacmd dump when audio is playing:
set-sink-mute alsa_output.pci-0000_00_1f.3.hdmi-stereo no
suspend-sink alsa_output.pci-0000_00_1f.3.hdmi-stereo no
