Hi, i’ve here a testlaptop from dell, latitude 7450 with intel vpro enterprise.
i want to use intel “amt” and therefor i want to install intel MEI driver, so that could activate this.
So does anybody has some information for using the MEI driver here in Manjaro/arch and activate amt? I’m using a remote managment programm that could handle with this so it would be very nice, if i get this thing to work.
Regards
Hi @simpsonetti,
I think for that you need intel-lms
from the AUR:
https://aur.archlinux.org/packages/intel-lms
Allows applications to access the Intel AMT firmware via the Intel MEI
So it can simply be installed using:
pamac build intel-lms
Hope this helps!
Thanks.
