Disclaimer:
For some reason I cannot replicate the proplematic behaviour atm. I don’t know why, but I’m happy for now.
@mods: if you close this thread, can I re-open it, if the issue comes back?
Hi everybody,
NV41 Series 14" coreboot laptop
- SKU: nv41pz-i5
- CPU: i5-1240p
- M.2 SSD: Samsung 980 Pro
after logging in there is a 1 in 7 chance the screen starts to flicker. Meaning that black rectangles cover the whole width of the screen but not the whole height (starting from the bottom) repeatedly for fractions of a second. When moving the cursor they seem to intensify.
→ there has never been flickering on the log-in screen, only after logging in!
→ sometimes it doesn’t flicker
- I tried multiple Kernels (5.10, 5.15, 6.1, 6.2 and 6.3).
- I turned off any sleep options via gui
- I added the recommended i915.enabled parameters in the GRUB_CMDLINE_LINUX_DEFAULT=“” and the sudo update-grub afterwards: i915.enable_psr=0 i915.enable_dc=0 i915.enable_dc=0 i915.force_probe=pci_myId
- I reinstalled the whole system
- I disabled Intel Management Engine and Secure Boot (but also tried when it was enabled)
///// Please do not answer yet, I’m still gathering information \\\
sudo update-grub shows these lines at the end:
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
I don’t understand what this means. this is the only hard drive in the system, how is it unknown?
$ lspci -k | grep -EA3 ‘VGA|3D|Display’
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-P Integrated Graphics Controller (rev 0c)
DeviceName: VGA compatible controller
Subsystem: CLEVO/KAPOK Computer Alder Lake-P Integrated Graphics Controller
Kernel driver in use: i915
Kernel modules: i915
$ inxi --admin --verbosity=7 --filter --width
Kernel: 6.3.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=0e1d411d-6634-4552-ae38-d0528f4df061 rw quiet apparmor=1
security=apparmor udev.log_priority=3 i915.enable_psr=0 i915.enable_fbc=0
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Notebook product: NV4xPZ v: v2.1
Mobo: Notebook model: NV4xPZ v: v2.1 serial: <superuser required>
UEFI: 3mdeb v: Dasharo (coreboot+UEFI) v1.6.0 date: 03/17/2023
ID-1: BAT0 charge: 25.1 Wh (47.6%) condition: 52.7/51.5 Wh (102.2%)
volts: 14.8 min: 15.2 model: Notebook BAT type: Li-ion serial: <filter>
status: discharging cycles: 5
System RAM: available: 31.19 GiB used: 2.71 GiB (8.7%)
Info: model: 12th Gen Intel Core i5-1240P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x42A
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1326 high: 2100 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 623 2: 752 3: 1031 4: 2100
5: 964 6: 2100 7: 2100 8: 2100 9: 823 10: 399 11: 2100 12: 2100 13: 717
14: 2100 15: 816 16: 406 bogomips: 67600
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2,
HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:4626 class-ID: 0300
Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 5986:9102
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-b700a driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d5 built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.3.5-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: off tools: pacat,pactl
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz vendor: Rivet Networks
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 2d:00.0
chip-ID: 8086:2725 class-ID: 0280
IF: wlp45s0 state: up mac: <filter>
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 4000 bus-ID: 2f:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp47s0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0032
class-ID: e001
Local Storage: total: 1.82 TiB used: 13.95 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 30.9 C
scheme: GPT
ID-1: / raw-size: 190.43 GiB size: 186.38 GiB (97.87%) used: 8.73 GiB (4.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0e1d411d-6634-4552-ae38-d0528f4df061
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1662-C51B
ID-3: /home raw-size: 700.2 GiB size: 688.14 GiB (98.28%)
used: 85.8 MiB (0.0%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: 8f5a42f1-a191-49e3-a77d-4da8f8472f18
ID-4: /mnt/ONBOARD raw-size: 771.7 GiB size: 758.52 GiB (98.29%)
used: 28 KiB (0.0%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 57171624-5d10-4f64-9b57-b34db295f356
ID-5: /var raw-size: 200.2 GiB size: 196 GiB (97.90%) used: 5.14 GiB (2.6%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 50ec98c2-6105-43b8-a3a4-dd7e1efe2f7a
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-7:2 info: Bison BisonCam NB Pro type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:9102 class-ID: 0e02
Device-2: 3-10:3 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1501
Processes: 281 Uptime: 42m wakeups: 1 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1120 libs: 354 tools: pamac,yay Shell: Bash v: 5.1.16
running-in: urxvtd inxi: 3.3.27
$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
1920x1080 60.01*+ 60.01 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
HDMI-3 disconnected (normal left inverted right x axis y axis)
$ mhwd -l && mhwd -li
> 0000:2f:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:00:02.0 (0300:8086:4626) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
some entries of journalctl that were highlighted:
$ jounralctl
Jun 17 00:18:13 talos kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=0e1d411d-6634-4552-ae38-d0528f4df061 rw quiet apparmor=1 security=apparmor udev.log_priority=3
Jun 17 00:18:13 talos kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64", will be passed to user space.
Jun 17 00:18:13 talos kernel: random: crng init done
Jun 17 00:18:13 talos kernel: ------------[ cut here ]------------
Jun 17 00:18:13 talos kernel: memcpy: detected field-spanning write (size 368) of single field "&device->entry" at drivers/firmware/google/coreboot_table.c:104 (size 8)
Jun 17 00:18:13 talos kernel: WARNING: CPU: 4 PID: 406 at drivers/firmware/google/coreboot_table.c:104 coreboot_table_probe+0x1ba/0x1e2 [coreboot_table]
Jun 17 00:18:13 talos kernel: Modules linked in: coreboot_table(+) sparse_keymap acpi_cpufreq(-) mac_hid fuse crypto_user bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 serio_raw sdhci_pci>
Jun 17 00:18:13 talos kernel: CPU: 4 PID: 406 Comm: systemd-udevd Not tainted 6.1.1-1-MANJARO #1 58eeef856bad441bca33a8abb39f91301fd24d8d
Jun 17 00:18:13 talos kernel: Hardware name: Notebook NV4xPZ/NV4xPZ, BIOS Dasharo (coreboot+UEFI) v1.6.0 03/17/2023
Jun 17 00:18:13 talos kernel: RIP: 0010:coreboot_table_probe+0x1ba/0x1e2 [coreboot_table]
Jun 17 00:18:13 talos kernel: Code: 08 00 00 00 48 89 c6 48 89 04 24 48 c7 c2 00 e1 5a c0 48 c7 c7 48 e1 5a c0 4c 89 44 24 08 c6 05 f3 1e 00 00 01 e8 b1 81 81 df <0f> 0b 4c 8b 44 24 08 48 8b 04 24 e9 71 ff ff ff>
Jun 17 00:18:13 talos kernel: RSP: 0018:ffff9926c2de7be8 EFLAGS: 00010282
Jun 17 00:18:13 talos kernel: RAX: 0000000000000000 RBX: ffff8aed89a89000 RCX: 0000000000000027
Jun 17 00:18:13 talos kernel: RDX: ffff8af4df921668 RSI: 0000000000000001 RDI: ffff8af4df921660
Jun 17 00:18:13 talos kernel: RBP: ffff9926c00f5018 R08: 0000000000000000 R09: ffff9926c2de7a70
Jun 17 00:18:13 talos kernel: R10: 0000000000000003 R11: ffffffffa10cb768 R12: 0000000000000000
Jun 17 00:18:13 talos kernel: R13: ffff9926c00f5000 R14: ffff8aed82681810 R15: 0000000000000000
Jun 17 00:18:13 talos kernel: FS: 00007f5c0d62f080(0000) GS:ffff8af4df900000(0000) knlGS:0000000000000000
Jun 17 00:18:13 talos kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 17 00:18:13 talos kernel: CR2: 00007f5c0c6b9000 CR3: 0000000109988003 CR4: 0000000000f70ee0
Jun 17 00:18:13 talos kernel: PKRU: 55555554
Jun 17 00:18:13 talos kernel: Call Trace:
Jun 17 00:18:13 talos kernel: <TASK>
Jun 17 00:18:13 talos kernel: platform_probe+0x45/0x90
Jun 17 00:18:13 talos kernel: really_probe+0xdb/0x380
Jun 17 00:18:13 talos kernel: ? pm_runtime_barrier+0x54/0x90
Jun 17 00:18:13 talos kernel: __driver_probe_device+0x78/0x170
Jun 17 00:18:13 talos kernel: driver_probe_device+0x1f/0x90
Jun 17 00:18:13 talos kernel: __driver_attach+0xd5/0x1d0
Jun 17 00:18:13 talos kernel: ? __device_attach_driver+0x110/0x110
Jun 17 00:18:13 talos kernel: bus_for_each_dev+0x88/0xd0
Jun 17 00:18:13 talos kernel: bus_add_driver+0x1b2/0x200
Jun 17 00:18:13 talos kernel: driver_register+0x8d/0xe0
Jun 17 00:18:13 talos kernel: coreboot_table_driver_init+0x2f/0x1000 [coreboot_table 7a0441a8ccb487b24af9e476002c49b866427759]
Jun 17 00:18:13 talos kernel: ? 0xffffffffc059f000
Jun 17 00:18:13 talos kernel: do_one_initcall+0x5a/0x220
Jun 17 00:18:13 talos kernel: do_init_module+0x4a/0x1e0
Jun 17 00:18:13 talos kernel: __do_sys_init_module+0x17f/0x1b0
Jun 17 00:18:13 talos kernel: do_syscall_64+0x5c/0x90
Jun 17 00:18:13 talos kernel: ? syscall_exit_to_user_mode+0x1b/0x40
Jun 17 00:18:13 talos kernel: ? do_syscall_64+0x6b/0x90
Jun 17 00:18:13 talos kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd
Jun 17 00:18:13 talos kernel: RIP: 0033:0x7f5c0e121eae
Jun 17 00:18:13 talos kernel: Code: 48 8b 0d dd ee 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d aa ee 0c 00>
Jun 17 00:18:13 talos kernel: RSP: 002b:00007ffd184c0c18 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
Jun 17 00:18:13 talos kernel: RAX: ffffffffffffffda RBX: 00005574183363d0 RCX: 00007f5c0e121eae
Jun 17 00:18:13 talos kernel: RDX: 00007f5c0e5f4343 RSI: 0000000000003eb8 RDI: 00007f5c0c699010
Jun 17 00:18:13 talos kernel: RBP: 00007f5c0e5f4343 R08: 0000000000003eb8 R09: 85ebca77c2b2ae63
Jun 17 00:18:13 talos kernel: R10: 00000000000012c1 R11: 0000000000000246 R12: 0000000000020000
Jun 17 00:18:13 talos kernel: R13: 000055741834be00 R14: 00005574183363d0 R15: 0000557418331260
Jun 17 00:18:13 talos kernel: </TASK>
Jun 17 00:18:13 talos kernel: ---[ end trace 0000000000000000 ]---
Jun 17 00:18:13 talos kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
Jun 17 00:18:13 talos kernel: spi-nor spi0.0: BFPT parsing failed. Please consider using SPI_NOR_SKIP_SFDP when declaring the flash
Jun 17 00:18:13 talos kernel: spi-nor: probe of spi0.0 failed with error -524
Jun 17 00:18:15 talos bluetoothd[622]: Bluetooth daemon 5.66
Jun 17 00:18:15 talos bluetoothd[622]: Starting SDP server
Jun 17 00:18:15 talos bluetoothd[622]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Jun 17 00:18:15 talos bluetoothd[622]: src/plugin.c:plugin_init() Failed to init vcp plugin
Jun 17 00:18:15 talos bluetoothd[622]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Jun 17 00:18:15 talos bluetoothd[622]: src/plugin.c:plugin_init() Failed to init mcp plugin
Jun 17 00:18:15 talos bluetoothd[622]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Jun 17 00:18:15 talos bluetoothd[622]: src/plugin.c:plugin_init() Failed to init bap plugin
Jun 17 00:18:15 talos systemd-logind[628]: Watching system buttons on /dev/input/event3 (Power Button)
Jun 17 00:18:15 talos systemd-logind[628]: Watching system buttons on /dev/input/event0 (Power Button)
Jun 17 00:18:15 talos bluetoothd[622]: Bluetooth management interface 1.22 initialized
Jun 17 00:45:39 talos pkexec[1145]: pam_unix(polkit-1:session): session opened for user root(uid=0) by apollo(uid=1000)
Jun 17 00:45:39 talos pkexec[1145]: apollo: Executing command [USER=root] [TTY=unknown] [CWD=/home/apollo] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness-switch 0]
Jun 17 00:45:39 talos pkexec[1151]: pam_unix(polkit-1:session): session opened for user root(uid=0) by apollo(uid=1000)
Jun 17 00:45:39 talos pkexec[1151]: apollo: Executing command [USER=root] [TTY=unknown] [CWD=/home/apollo] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness-switch 0]
Jun 17 00:45:40 talos kernel: i915 0000:00:02.0: [drm] *ERROR* Fault errors on pipe A: 0x00000080
this is the output while the screen is flickering:
///// Please do not answer yet, I’m still gathering information - unless you have a solution of course ; ) \\\
