Since I updated my system about a week ago I have been unable to use the onboard 3.5mm headphone jacks on my machine.
I believe these are controlled by the Intel HDA Audio built into my motherboard, but I can’t find any references to it at all in Pavucontrol or Pactl on the commandline. There is no option to select the ‘Analog Stereo’ in PavuControl or if I run pacmd list-cards in the terminal. The only audio device I can currently see is the HDMI audio from my Nvidia card. (Listed as NVIDIA Corporation TU104 HD Audio Controller)
I’ve tried the commands inxi -Fa | grep Audio and lspci and it shows up as “Intel 100 Series/C230 Series Family HD Audio Vendor: Gigabyte”, so they’re definitely recognised by my system, just not by Pulse for some reason.
What’s more confusing is that cat /proc/asound/cards produces:
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xef080000 irq 17
Also cat /proc/asound/modules produces:
1 snd_hda_intel
These seem to imply to me that Nvidia is using the snd_hda_intel driver, which doesn’t make sense? (Please correct me here if I’m wrong)
I’ve tried a couple of solutions so far, for instance writing options snd_hda_intel model=generic in my /etc/modprobe.d/alsa-base.conf, (Side note: This file didn’t exist prior to me doing this) but that didn’t appear to have any effect.
I’ve also tried:
options snd_hda_intel probe_mask=1
options snd_hda_intel dmic_detect=0
options snd_hda_intel index=1,0
as suggested on some other threads, but none of these appear to make a difference.
For what it’s worth, I dug back through my bash history and found that I’d previously executed the command pactl set-default-sink alsa_output.pci-0000_00_1f.3.analog-stereo. Tried executing it again but the command just returns the error: Failure: No such entity
I’m at a loss as to what else I can try at this point. I’ve trawled the internet for hours but I’ve yet to find a solution that works…
The output for alsa-info.sh can be found here if that helps at all…
http://alsa-project.org/db/?f=0de8ddddc002b11bcb3c2a1d41ab26efc8affc53
Anything else I can try?
Thanks in advance. Let me know if there’s any additional information you want me to provide.
