Running Manjaro XFCE for a while now and have been loving it. However after installing 5.9.1-1 my cpu does not seem to want to turbo past it 2.59GHz base clock. Rebooting into 5.8 and the turbo is back.
Intel E5-2690v3
governor set to performance in CPUpower
cpupower frequency-info returns the same thing with either kernel loaded
analyzing CPU 0:
driver: intel_cpufreq
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 20.0 us
hardware limits: 1.20 GHz - 3.50 GHz
available cpufreq governors: performance schedutil
current policy: frequency should be within 1.20 GHz and 3.50 GHz.
The governor “performance” may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 2.51 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
