Intel CPU not being used
So my laptop doesn’t detect my cpu for some reason, it isn’t really a problem since the device works but I should get a performance upgrade if it does, so I want to try and fix it.
inxi -Faz
  Info: model: Intel Core i7-2820QM bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 813 high: 913 min/max: 800/3400 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 798 3: 798 4: 800
    5: 798 6: 800 7: 913 8: 800 bogomips: 36734
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
It is’t disabled by BIOS so I truly don’t understand how this happens. Whenever I do a clean install the CPU works. But every time I download my Nvidia (390xx) drivers the CPU just stops working but is being detected.
Has anyone every experienced an issue like this?
Hi @N.Kamer,
I suspect you mean GPU. You DO mean GPU, yes? Because if it was the CPU, this: :point_down:
…wouldn’t have been the case. And
Doesn’t make CPUs AFAK.
Anyway, your
…output is not nearly enough…please provide the output of:
inxi --full --admin --filter --width
Hi @Mirdarthos
Thanks for helping me out!
What I meant was, whenever I install my GPU drivers and reboot back into my system. From that moment my CPU stops working and my device fully runs of my GPU.
inxi --full --admin --fliter --width
  Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=668b3e96-8152-484b-a70f-cb54f843d4a0 rw quiet splash
    resume=UUID=31cd834c-7e38-43b5-a939-0ef4e4472892 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: Hewlett-Packard product: HP EliteBook 8760w v: A0001D02
  Mobo: Hewlett-Packard model: 1630 v: KBC Version 01.39
    serial: <superuser required> BIOS: Hewlett-Packard v: 68SAD Ver. F.23
    date: 01/18/2012
  ID-1: BAT0 charge: 53.5 Wh (95.5%) condition: 56.0/56.0 Wh (100.0%)
    volts: 16.5 min: 14.4 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: not charging
  Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Speed (MHz): avg: 800 high: 810 min/max: 800/3400 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 800 3: 800 4: 800
    5: 800 6: 810 7: 798 8: 800 bogomips: 36734
    vulnerable
  Device-1: NVIDIA GF104GLM [Quadro 4000M] vendor: Hewlett-Packard
    driver: nvidia v: 390.157 alternate: nouveau,nvidia_drm non-free:
    series: 390.xx+ status: legacy-active (EOL~late 2022) arch: Fermi
    code: GF1xx process: 40/28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s
    lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0e3b class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 128 s-size: 381x211mm (15.00x8.31")
    s-diag: 436mm (17.15")
  Monitor-1: LVDS-0 res: 1920x1080 hz: 60 dpi: 128 size: 381x214mm (15x8.43")
    diag: 437mm (17.2") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: kms_swrast x11:
    egl: 1.4 drv: nvidia inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.6.0 vendor: nvidia mesa v: 390.157
    glx-v: 1.4 direct-render: yes renderer: Quadro 4000M/PCIe/SSE2
    memory: 1.95 GiB
    vendor: Hewlett-Packard 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GF104 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:0beb class-ID: 0403
  API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.80 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
    driver: e1000e v: kernel port: 5020 bus-ID: 00:19.0 chip-ID: 8086:1502
    class-ID: 0200
  IF: enp0s25 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 25:00.0 chip-ID: 8086:4238
    class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-3: HP hs2340 HSPA+ mobile broadband driver: cdc_acm,cdc_ncm,cdc_wdm
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:3
    chip-ID: 03f0:3a1d class-ID: 0202 serial: <filter>
  IF: enp0s26u1u2i6 state: down mac: <filter>
  Device-1: HP Broadcom 2070 Bluetooth Combo driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.6:4 chip-ID: 03f0:231d
    class-ID: fe01
  Local Storage: total: 704.24 GiB used: 71.86 GiB (10.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7PC256HAFU-000H1
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 5H1Q scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500VT000-1DK142
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: MBC1
  ID-1: / raw-size: 221.34 GiB size: 216.81 GiB (97.95%)
    used: 71.86 GiB (33.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 49.0 C mobo: N/A gpu: nvidia temp: 54 C
  Fan Speeds (rpm): N/A
  Processes: 312 Uptime: 39m wakeups: 8 Memory: total: 16 GiB
  available: 15.56 GiB used: 2.16 GiB (13.9%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1350 libs: 410 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.30
AFAIK, this cannot happen. What makes you say it?
Was this from before you installed the drivers?
How did you install said drivers?
Edit:
Except if by fully, you meant all your video, and not the whole, complete device, as your wording suggests. Any case, please provide the output for:
mhwd --list
and
mhwd --listinstalled
and
glxinfo | grep server
and
prime-run glxinfo | grep server
The inxi is after the Nvidia drivers where installed, whenever I remove nvidia-390xx with mhwd and reinstall video-linux my OS breaks (to the original settings). How I installed them: sudo mhwd -r pci video-linux && sudo mhwd -a pci nonfree 0300 && reboot. Then my resolution changes and my DPI gets messed up, and then intel’s integrated graphics aren’t detected anymore. And whenever I install xf86-intel-drivers my resolution is so small that my device becomes unusable because it affects the bash shell as well (the shell you open with ctrl+alt+F3).
mhwd --list
 mhwd --list
> 0000:01:00.0 (0300:10de:0e3b) Display controller nVidia Corporation:
    video-nvidia-390xx            2023.03.23               false            PCI
           video-linux            2018.05.04                true            PCI
> Installed PCI configs:
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
Prime-run isn’t installed on my device a.t.m. So I just installed the nvidia-prime package and the output is the same as glxinfo | grep server
I only see one (1) GPU there, and that’s the nvidia:
It seems to also only use the old driver for it. Which is installed.
So there is nothing else to use. That’s why:
I don’t know if you are perhaps looking for the nouveau drivers, which works well on older GPUs I’m led to believe. To install them, run the following:
sudo mhwd -a pci free 0300
And then you should remove the current ones:
sudo mhwd --remove pci video-nvidia-390xx
You can also remove the nvidia-prime package:
pamac remove nvidia-prime
And reboot to test.
I’m still unsure why you claim the intel CPU is not being used. There is only one CPU present:
…and if it wasn’t being used, your laptop wouldn’t even start. And if you meant GPU, it can’t use the Intel one, never mind only that, since there is only the Nvidia one to use.
