I wish there was some way to reverse engineer the windows driver because it works in Windows.
I did this and got this result but kde still says no bluetooth adapter found.
[demo@manjaro ~]$ systemctl start bluetooth.service
[demo@manjaro ~]$ systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Sat 2022-10-08 17:50:46 EDT; 21s ago
Docs: man:bluetoothd(8)
Main PID: 36712 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18732)
Memory: 2.0M
CPU: 29ms
CGroup: /system.slice/bluetooth.service
└─36712 /usr/lib/bluetooth/bluetoothd
Oct 08 17:50:46 manjaro systemd[36712]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 08 17:50:46 manjaro systemd[1]: Starting Bluetooth service...
Oct 08 17:50:46 manjaro bluetoothd[36712]: Bluetooth daemon 5.65
Oct 08 17:50:46 manjaro systemd[1]: Started Bluetooth service.
Oct 08 17:50:46 manjaro bluetoothd[36712]: Starting SDP server
Oct 08 17:50:46 manjaro bluetoothd[36712]: Bluetooth management interface 1.22 initialized
so if you check with: rfkill list
is bluetooth detected?
post output from:
cat /usr/lib/systemd/system/bluetooth.service
[demo@manjaro ~]$ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
[demo@manjaro ~]$ cat /usr/lib/systemd/system/bluetooth.service
[Unit]
Description=Bluetooth service
Documentation=man:bluetoothd(8)
ConditionPathIsDirectory=/sys/class/bluetooth
[Service]
Type=dbus
BusName=org.bluez
ExecStart=/usr/lib/bluetooth/bluetoothd
NotifyAccess=main
#WatchdogSec=10
#Restart=on-failure
CapabilityBoundingSet=CAP_NET_ADMIN CAP_NET_BIND_SERVICE
LimitNPROC=1
# Filesystem lockdown
ProtectHome=true
ProtectSystem=strict
PrivateTmp=true
ProtectKernelTunables=true
ProtectControlGroups=true
StateDirectory=bluetooth
StateDirectoryMode=0700
ConfigurationDirectory=bluetooth
ConfigurationDirectoryMode=0555
# Execute Mappings
MemoryDenyWriteExecute=true
# Privilege escalation
NoNewPrivileges=true
# Real-time
RestrictRealtime=true
[Install]
WantedBy=bluetooth.target
Alias=dbus-org.bluez.service
not detected …
open this file:
kate /usr/lib/systemd/system/bluetooth.service
and edit this line:
to look like this:
ConfigurationDirectoryMode=0755
save the file… this will fix this message:
then turn off your computer, unplug it, remove the battery, and hold the power button for around 10 seconds, plug battery back, boot and check if it helped: rfkill list
I changed that line in the file however taking the battery out is out of the question at this time.
I have to remove the whole bottom of the case to do that and it is quite an ordeal to do.
I will use it unplugged until it dies and then hold the power button down.
I’ll let you know if it makes a difference
Well I let the battery go completely dead , held down the power button.
Started it back up.
Still not working.
so open this file:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT=
inside the quotes add these parameters:
acpi_osi=! acpi_osi='Windows 2017'
dont remove anything from there, add it to existing parameters, save the file, update grub:
sudo update-grub
reboot and check with: rfkill list
if you cant boot with these parameters, in the grub menu press ‘E’ and locate the paramaters and remove them
First I really appreciate you sticking with me through all of this.
I felt we were getting real close with some of the results .
Still not there yet.
My Grub file looks like this now:
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nocrs acpi=force acpi_osi=! acpi_osi='Windows 2017'"
The part before what you had me add was there already. I hope it doesn’t interfere with what you had me add.
I can remove it if you think it will help.
The result of rfkill is the same as it was before:
Soft blocked: no
Hard blocked: no
ok, so now replace the parameters, so that the grub looks like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nocrs acpi_osi=Linux"
i removed the acpi=force
that you had there, lets try without it… if you however have issues that require this parameter, keep it there, dont remove it
then save the grub, update grub, reboot and test
edit: there was a typo there: apci_osi=Linux
, so i corrected it to: acpi_osi=Linux
I think I had errors when the system booted is why I had the acpi=force there but it doesn’t seem to have affected anything.
So every time I boot I check the status of bluetooth and this time is is inactive.
and the commands to enable it and start it don’t seem to have an effect anymore.
○ bluetooth.service - Bluetooth service
Active: inactive (dead)
Oct 09 18:48:07 manjaro systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
did you noticed this :
if not correct it and try again;
if it didnt worked, add this parameter:
acpi_osi=
so that your grub looks like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nocrs acpi_osi="
save the grub, update grub, reboot and check
if it doesnt work, add back the parameters you had there before
could be because of those changes in parameters that its status changed…
if bluetooth is detected
Well I got something different with rfkill
However I lost my touchpad for some reason.
Putting grub back to what it was
0: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
× bluetooth.service - Bluetooth service
Active: failed (Result: timeout) since Sun 2022-10-09 19:52:38 EDT; 6min ago
Process: 996 ExecStart=/usr/lib/bluetooth/bluetoothd (code=killed, signal=TERM)
Main PID: 996 (code=killed, signal=TERM)
CPU: 1ms
Oct 09 19:51:08 manjaro systemd[1]: Starting Bluetooth service...
Oct 09 19:52:38 manjaro systemd[1]: bluetooth.service: start operation timed out. Terminating.
Oct 09 19:52:38 manjaro systemd[1]: bluetooth.service: Failed with result 'timeout'.
Oct 09 19:52:38 manjaro systemd[1]: Failed to start Bluetooth service.
it detected the bluetooth as another wireless…
so now your grub looks like this?:
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nocrs acpi=force acpi_osi=!"
first edit this:
kate /etc/modprobe.d/iwlwifi.conf
and put a #
at the beginning so that it looks like this:
#options iwlwifi bt_coex_active=N
save the file
so lets try some more of these parameters:
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nocrs acpi=force acpi_osi=!!"
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nocrs acpi=force acpi_osi=!*"
GRUB_CMDLINE_LINUX_DEFAULT="quiet pci=nocrs acpi=force acpi_osi='Windows 2015'"
after adding each parameter, save the grub, update grub, reboot and check with:
rfkill list
I will reply after I do each change.
With this
acpi_osi=!
I lose my touchpad
and have this for rfkill
Soft blocked: no
Hard blocked: no
1: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
boot into a live-iso. use a live-iso of manjaro and a second one like linux-mint and check if bluetooth is avaiable in a live-session.
also check if bluetooth is still avaiable in your ms-windows. boot to windows and activate bluetooth.
touchpad working
Soft blocked: no
Hard blocked: no
No Touchpad
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: no
touchpad working
Soft blocked: no
Hard blocked: no
Bluetooth working fine in windows
Linux mint live usb no adapter found
Manjaro live usb no adapter found
please post the output of
sudo dmesg | grep Bluetooth
[demo@manjaro ~]$ sudo dmesg | grep Bluetooth
[sudo] password for demo:
[demo@manjaro ~]$
