Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=36acd397-6da9-481f-96e8-45691fae1332 ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81LK v: IdeaPad L340-15IRH Gaming
serial: <filter> Chassis: type: 10 v: IdeaPad L340-15IRH Gaming
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: BGCN33WW date: 11/24/2020
Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b class ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 460.39 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f91 class ID: 0300
Device-3: Lite-On Integrated Camera type: USB driver: uvcvideo bus ID: 1-8:3
chip ID: 04ca:7070 class ID: 0e02
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia
display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-2: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
okay, the thing is: my cpu randomly stops supporting boost state, but for the most part it’s happening
when i’m playing games so this is how it looks like when i boot up and set up everything with cpupower
by running frequency-set -g performance and -u 4100000:
analyzing CPU 0:
driver: intel_pstate
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: Cannot determine or is not supported.
hardware limits: 800 MHz - 4.10 GHz
available cpufreq governors: performance powersave
current policy: frequency should be within 800 MHz and 4.1 GHz.
The governor "performance" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 4.0 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
and then when i run a game for some reason only AFTER the loading screen it changes to:
analyzing CPU 0:
current policy: frequency should be within 800 MHz and 2.40 GHz.
within this range.
current CPU frequency: 2.4 GHz (asserted by call to kernel)
Supported: no
Active: no
oh and for thefirst time it happened i was using prime-run to run minecraft on my nvidia gpu but i stopped having this problem when running it without prime-run but using Xorg.conf configured by
Xorg --configure
Section "ServerLayout"
Identifier "X.org Configured"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" RightOf "Screen0"
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/misc"
FontPath "/usr/share/fonts/TTF"
FontPath "/usr/share/fonts/OTF"
FontPath "/usr/share/fonts/Type1"
FontPath "/usr/share/fonts/100dpi"
FontPath "/usr/share/fonts/75dpi"
EndSection
Section "Module"
Load "glx"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Monitor"
Identifier "Monitor1"
EndSection
Section "Device"
Identifier "Card0"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Device"
### Available Driver options are:-
### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
### <percent>: "<f>%"
### [arg]: arg optional
#Option "SWcursor" # [<bool>]
#Option "kmsdev" # <str>
#Option "ShadowFB" # [<bool>]
#Option "AccelMethod" # <str>
#Option "PageFlip" # [<bool>]
#Option "ZaphodHeads" # <str>
#Option "DoubleShadow" # [<bool>]
#Option "Atomic" # [<bool>]
Identifier "Card1"
Driver "modesetting"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Card1"
Monitor "Monitor1"
Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
it probably should be noted that when i boot up the laptop my cpupower shows that boost state is not supported for first 30-60seconds and even after that i need to change max cpu frequency by myself
just to add i suspect it might have to do something with GPU offloading
I have no idea, sorry.
load) turbo baby! ← “YEAH! Single thread, it’s all up to me! I AM POWERFUL!”
idle ) no turbo
load) no turbo ← “Okay, sorry! I’ll stop being turbo now…”
