Hi,
I just switched to Manjaro after having use for quite some years Debian/Ubuntu! Great first impression!
I have installed Manjaro 21.0.1 on a Dell Latitude 9410. Everything is working fine (even the LTE module!) apart from the wifi. I know the model is a Intel ax201, when I run lspci is recognized as
Intel Corporation Comet Lake PCH-LP CNVi WiFi
I am on kernel 5.10.26-1, the package linux-firmware is already installed. Any help with this would be amazing!
Thanks,
Maurizio
this is what I get when I run sudo dmesg | grep iwlwifi
[ 1.894675] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 1.898736] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 1.898755] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 65.3.35.22
[ 1.899146] iwlwifi 0000:00:14.3: loaded firmware version 59.601f3a66.0 QuZ-a0-hr-b0-59.ucode op_mode iwlmvm
[ 2.288195] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 3.329666] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x0, CPU2 Status: 0x3100000
[ 3.329742] iwlwifi 0000:00:14.3: UMAC PC: 0xc00c0538
[ 3.329805] iwlwifi 0000:00:14.3: LMAC PC: 0x0
[ 3.329809] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired.
[ 3.331221] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 3.331223] iwlwifi 0000:00:14.3: Status: 0x00000000, count: -218269787
[ 3.331225] iwlwifi 0000:00:14.3: Loaded firmware version: 59.601f3a66.0 QuZ-a0-hr-b0-59.ucode
[ 3.331227] iwlwifi 0000:00:14.3: 0x3BBBF607 | ADVANCED_SYSASSERT
[ 3.331229] iwlwifi 0000:00:14.3: 0x936EBE2B | trm_hw_status0
[ 3.331230] iwlwifi 0000:00:14.3: 0xAD1677A5 | trm_hw_status1
[ 3.331232] iwlwifi 0000:00:14.3: 0x35F27236 | branchlink2
[ 3.331233] iwlwifi 0000:00:14.3: 0xBB81B8FA | interruptlink1
[ 3.331235] iwlwifi 0000:00:14.3: 0xC27D55B7 | interruptlink2
[ 3.331236] iwlwifi 0000:00:14.3: 0xAFA64657 | data1
[ 3.331238] iwlwifi 0000:00:14.3: 0x7FA551D8 | data2
[ 3.331239] iwlwifi 0000:00:14.3: 0x1D9CCF56 | data3
[ 3.331241] iwlwifi 0000:00:14.3: 0xC7250928 | beacon time
[ 3.331242] iwlwifi 0000:00:14.3: 0xB58C5949 | tsf low
[ 3.331244] iwlwifi 0000:00:14.3: 0xFF494810 | tsf hi
[ 3.331245] iwlwifi 0000:00:14.3: 0xC51E947D | time gp1
[ 3.331247] iwlwifi 0000:00:14.3: 0x1F8BF633 | time gp2
[ 3.331248] iwlwifi 0000:00:14.3: 0xC692AAC0 | uCode revision type
[ 3.331250] iwlwifi 0000:00:14.3: 0x6C306D66 | uCode version major
[ 3.331251] iwlwifi 0000:00:14.3: 0x457A09FA | uCode version minor
[ 3.331252] iwlwifi 0000:00:14.3: 0xBF510DCE | hw version
[ 3.331254] iwlwifi 0000:00:14.3: 0xACDD566E | board version
[ 3.331255] iwlwifi 0000:00:14.3: 0xF9D6D0C2 | hcmd
[ 3.331257] iwlwifi 0000:00:14.3: 0xBE29EDCD | isr0
[ 3.331258] iwlwifi 0000:00:14.3: 0xBCF77CCA | isr1
[ 3.331260] iwlwifi 0000:00:14.3: 0x67B5C8F2 | isr2
[ 3.331261] iwlwifi 0000:00:14.3: 0xB33D5BD4 | isr3
[ 3.331263] iwlwifi 0000:00:14.3: 0x362C7DAE | isr4
[ 3.331264] iwlwifi 0000:00:14.3: 0x7F3F7A54 | last cmd Id
[ 3.331266] iwlwifi 0000:00:14.3: 0xEB4E520F | wait_event
[ 3.331267] iwlwifi 0000:00:14.3: 0xB34889CD | l2p_control
[ 3.331269] iwlwifi 0000:00:14.3: 0xADCE758C | l2p_duration
[ 3.331270] iwlwifi 0000:00:14.3: 0xACE3E546 | l2p_mhvalid
[ 3.331271] iwlwifi 0000:00:14.3: 0x390097D4 | l2p_addr_match
[ 3.331273] iwlwifi 0000:00:14.3: 0x2B9BD1FF | lmpm_pmg_sel
[ 3.331274] iwlwifi 0000:00:14.3: 0x21AAF092 | timestamp
[ 3.331276] iwlwifi 0000:00:14.3: 0x7AC96872 | flow_handler
[ 3.331691] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 3.331693] iwlwifi 0000:00:14.3: Status: 0x00000000, count: -1051949204
[ 3.331694] iwlwifi 0000:00:14.3: 0xA4C454BD | ADVANCED_SYSASSERT
[ 3.331696] iwlwifi 0000:00:14.3: 0xE9416416 | umac branchlink1
[ 3.331697] iwlwifi 0000:00:14.3: 0x58B01E0A | umac branchlink2
[ 3.331699] iwlwifi 0000:00:14.3: 0x1D8160AB | umac interruptlink1
[ 3.331700] iwlwifi 0000:00:14.3: 0x11992234 | umac interruptlink2
[ 3.331702] iwlwifi 0000:00:14.3: 0xF1D7E93D | umac data1
[ 3.331703] iwlwifi 0000:00:14.3: 0x45685E0D | umac data2
[ 3.331705] iwlwifi 0000:00:14.3: 0xB3B03A57 | umac data3
[ 3.331706] iwlwifi 0000:00:14.3: 0x0A7D5948 | umac major
[ 3.331708] iwlwifi 0000:00:14.3: 0x9D8344F3 | umac minor
[ 3.331709] iwlwifi 0000:00:14.3: 0xFBF0C8F3 | frame pointer
[ 3.331711] iwlwifi 0000:00:14.3: 0x6CADEE15 | stack pointer
[ 3.331712] iwlwifi 0000:00:14.3: 0xA6D4B08B | last host cmd
[ 3.331714] iwlwifi 0000:00:14.3: 0x34221A81 | isr status reg
[ 3.331749] iwlwifi 0000:00:14.3: Fseq Registers:
[ 3.331771] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 3.331774] iwlwifi 0000:00:14.3: 0x00290033 | FSEQ_TOP_INIT_VERSION
[ 3.331778] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION
[ 3.331797] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION
[ 3.331818] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[ 3.331839] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 3.331842] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 3.331862] iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
[ 3.331883] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 3.331936] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_AUX_MISC_CHIP
[ 3.332020] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 3.332103] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 3.332135] iwlwifi 0000:00:14.3: Failed to start RT ucode: -110
[ 3.682487] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
and the results from inxy -Fazy
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
port: 3000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
type: USB driver: r8152 bus-ID: 4-2:2 chip-ID: 2357:0601 class-ID: 0000
serial: <filter>
IF: enp36s0u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wwp0s20f0u4c2 state: down mac: <filter>
I’m running a Lenovo X1 Carbon with the same chip and revision:
[ 6.734773] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-64.ucode failed with error -2
[ 6.735984] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 6.735998] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[ 6.736205] iwlwifi 0000:00:14.3: loaded firmware version 63.c04f3485.0 QuZ-a0-hr-b0-63.ucode op_mode iwlmvm
[ 6.975923] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 7.099032] iwlwifi 0000:00:14.3: Detected RF HR B5, rfid=0x10a100
[ 7.165689] iwlwifi 0000:00:14.3: base HW address: xx:xx:xx:xx:xx:xx
[ 7.330921] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
I have had brand new Manjaro 21.x installed for a month now. I guess the driver was updated.
A few magic tricks with laptops and their internal internals: Boot to Windows and test the wifi there, enable and disable flight mode. Try to disable and enable WLAN adapter in BIOS/UEFI and boot in between.
Does it works for you now or is it still broken?
