I recently purchased a computer that has an Intel AX200 wifi card. While the drivers seem to be included in all the recent firmware updates (Unstable Branch), when the package is extracted, the correct driver files are not in the lib/firmware directory.
When I first installed Manjaro on this computer, I tried all kinds of things, modprobe, etc. to try and have the computer recognize the wifi chip, with no success. I happened upon a post somewhere regarding the “46” driver directly from Intel. I wound up getting the “46” driver from Intel and after a reboot the wifi was recognized and working. Prior to doing that inxi noted the following: Module:iwlwifi Driver N/A.
When manually inserting the following files into lib/firmware, everything works as expected:
iwlwifi-cc-a0-46.ucode (directly from Intel)
iwlwifi-cc-a0-50.ucode
iwlwifi-cc-a0-59.ucode
iwlwifi-cc-a0-66.ucode
iwlwifi-cc-a0-72.ucode
iwlwifi-cc-a0-73.ucode
iwlwifi-cc-a0-74.ucode
iwlwifi-cc-a0-77.ucode
Just this morning with the amd.ucode and firmware updates, I had to manually copy the above files over. Afterwards, wifi is recognized. Why don’t the driver files extract into the directory from the linux-firmware installation file??? The issue occurs with Kernels 6.1 as well as 6.3.
sudo dmesg -T | grep iwlwifi
[sudo] password for jrichard:
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: Detected crf-id 0x3617, cnv-id 0x100530 wfpm id 0x80000000
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: PCI dev 2723/0084, rev=0x340, rfid=0x10a100
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-cc-a0-78.ucode failed with error -2
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: api flags index 2 larger than supported by driver
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: loaded firmware version 77.206b0184.0 cc-a0-77.ucode op_mode iwlmvm
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: Detected RF HR B3, rfid=0x10a100
[Wed Jul 5 07:06:08 2023] iwlwifi 0000:02:00.0: base HW address: ac:5a:fc:a5:8f:16
[Wed Jul 5 07:06:10 2023] iwlwifi 0000:02:00.0: Registered PHC clock: iwlwifi-PTP, with index: 0
inxi:
Kernel: 6.4.1-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
root=UUID=a4356953-c72b-40da-845f-f30936703dea ro ipv6.disable=1
mitigations=off apparmor=1 security=apparmor amd_pstate=passive nowatchdog
nmi_watchdog=0 udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Mini-pc Mobo: AZW model: SER v: V1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: 5800H502 date: 02/15/2023
System RAM: available: 28.32 GiB used: 1.92 GiB (6.8%)
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 4463 min/max: 400/4463 boost: enabled scaling:
driver: amd-pstate governor: performance cores: 1: 4463 2: 4463 3: 4463
4: 4463 5: 4463 6: 4463 7: 4463 8: 4463 9: 4463 10: 4463 11: 4463 12: 4463
13: 4463 14: 4463 15: 4463 16: 4463 bogomips: 102248
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 36.0 C
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69") monitors: <missing: xrandr>
Monitor-1: HDMI-A-2 model: HannSpree/HannStar HF199H serial: <filter>
built: 2008 res: 1440x900 dpi: 81 gamma: 1.2 size: 453x255mm (17.83x10.04")
diag: 520mm (20.5") ratio: 16:9 modes: max: 1440x900 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.1-4-MANJARO) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.1-4-MANJARO status: kernel-api with: aoss
Server-2: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlan0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:7 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 1.38 TiB used: 188.93 GiB (13.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8SEP4512N-A0
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM01100 temp: 36.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD Blue SA510 2.5 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0100
ID-1: / raw-size: 39.06 GiB size: 38.15 GiB (97.67%) used: 14.72 GiB (38.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: a4356953-c72b-40da-845f-f30936703dea
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 3C65-A0BD
ID-3: /home raw-size: 58.59 GiB size: 57.37 GiB (97.92%)
used: 2.49 GiB (4.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 4dfbf5ef-220e-4ca3-bb73-cbe8d86284e2
ID-4: /mnt/017f508f-13dd-45a1-aec4-4ebb9e8ceb6f raw-size: 192.52 GiB
size: 188.44 GiB (97.88%) used: 479.8 MiB (0.2%) fs: ext4 dev: /dev/nvme0n1p5
maj-min: 259:5 label: Linux Data 2
uuid: 017f508f-13dd-45a1-aec4-4ebb9e8ceb6f
ID-5: /mnt/c0db2385-9960-4dc5-b781-ef647f7ecae7 raw-size: 931.51 GiB
size: 915.83 GiB (98.32%) used: 138.62 GiB (15.1%) fs: ext4 dev: /dev/sda
maj-min: 8:0 label: N/A uuid: c0db2385-9960-4dc5-b781-ef647f7ecae7
ID-6: /mnt/c630bd8b-ed03-4a60-9ffd-89c476873f3d raw-size: 186.26 GiB
size: 182.28 GiB (97.86%) used: 32.63 GiB (17.9%) fs: ext4
dev: /dev/nvme0n1p4 maj-min: 259:4 label: Linux Data 1
uuid: c630bd8b-ed03-4a60-9ffd-89c476873f3d
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 1.46 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Device-1: 1-4:2 info: Fresco Logic Generic Billboard Device type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 1d5c:7102 class-ID: 1100
Hub-4: 3-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 045b:0209 class-ID: 0900
Hub-5: 3-2.1:4 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
Device-1: 3-2.3:5 info: Logitech Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 3-2.4:6 info: Logitech Keyboard K120 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c31c class-ID: 0300
Device-3: 3-3:7 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 4-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 chip-ID: 045b:0210 class-ID: 0900
Hub-8: 4-2.1:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 313 Uptime: 13m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1159
libs: 323 tools: pamac Shell: Zsh v: 5.9 running-in: xfce4-terminal
inxi: 3.3.27
