To give a rough sketch about my setup
Before enabling coolbits:
I have 2 monitors connected to my motherboard and use prime-run to get applications running on dedicated gpu.
After enabling coolbits:
When I rebooted to get the configurations working, I have 2 monitors showing a dark gray color. I turn of my computer and reconnect my cables to the dedicated gpu. Everything works now.
The problem:
Now my dedicated gpu is always running in p0 state and is consuming 35 W at idle. Which is a lot for just looking at webpages.
What I would like to do is somehow get my integrated gpu working again and use prime-run for dedicated gpu.
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=06ffbbc2-bb6e-4eb9-a9ab-e091dea2915f ro quiet udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX Z390-F GAMING v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 1502 date: 02/21/2020
Device-1: hidpp_battery_0 model: Logitech M705 serial: <filter> charge: 70%
rechargeable: yes status: Discharging
RAM: total: 31.27 GiB used: 4.38 GiB (14.0%)
Info: 8-Core model: Intel Core i9-9900K bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: C (12)
microcode: DE cache: L2: 16 MiB bogomips: 115232
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 801 8: 800 9: 800 10: 800 11: 801 12: 800 13: 800
14: 800 15: 800 16: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep
smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: Gigabyte driver: nvidia
v: 460.56 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1e82
class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 3280x1080 s-dpi: 90 s-size: 926x301mm (36.5x11.9")
s-diag: 974mm (38.3")
Monitor-1: DP-0 res: 1920x1080 dpi: 90 size: 544x303mm (21.4x11.9")
diag: 623mm (24.5")
Monitor-2: HDMI-0 res: 1360x768 hz: 60 dpi: 54 size: 640x360mm (25.2x14.2")
diag: 734mm (28.9")
OpenGL: renderer: GeForce RTX 2080/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Message: No Bluetooth data was found.
Message: No LVM data was found.
Local Storage: total: 2.05 TiB used: 512.87 GiB (24.5%)
model: WDS250G3X0C-00SJG0 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 111110WD temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZRZ-00Z5HB0
rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24D5MT rev: 1.00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 232.59 GiB size: 227.94 GiB (98.00%)
used: 86.4 GiB (37.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 06ffbbc2-bb6e-4eb9-a9ab-e091dea2915f
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: AAA1-8F62
ID-3: /home/<filter>/HDD raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 426.47 GiB (23.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: HDD
uuid: 753b6ec0-ec23-4580-8b68-261b2c28b937
ID-4: /run/timeshift/backup raw-size: 232.59 GiB size: <superuser required>
used: <superuser required> fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-6.4:4 info: ASUSTek AURA MOTHERBOARD type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:18a3 class-ID: 0300 serial: <filter>
Device-2: 1-9:3 info: ASUSTek ROG Claymore Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0b05:184d class-ID: 0300
Hub-3: 1-10:5 info: Microchip (formerly SMSC) USB2734 ports: 5 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2734 class-ID: 0900
Device-1: 1-10.4:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-10.5:7 info: Microchip (formerly SMSC) Hub Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip-ID: 0424:274c class-ID: 0300
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-5: 2-10:2 info: Microchip (formerly SMSC) USB5734 ports: 5 rev: 3.1
speed: 5 Gb/s chip-ID: 0424:5734 class-ID: 0900
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 43%
Processes: 323 Uptime: 1h 00m wakeups: 6 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1322
lib: 435 Shell: Bash v: 5.1.0 running-in: terminator inxi: 3.3.03
I also used timeshift before enabling coolbits so if you need information from before I can try to retrieve it.
If you require more information I will try to get it as fast as possible.
