GMate8
21 November 2021 12:33
1
It takes less than a minute to install Appimagelauncher and be good to go.
kisun
21 November 2021 17:46
3
Please not. I like it that I can fast install what I need … not (like in Windows) to uninstall things I will never use after fresh installation.
It’s preinstalled in Manjaro KDE Full ISO
GMate8
22 November 2021 09:58
5
C’mon. Manjaro already comes preinstalled with bunch of software. Couldn’t we help newbies with these things? I know, I can install it. But a newbie don’t.
GMate8
22 November 2021 09:59
6
There is the minimal version for you
Falav
22 November 2021 10:12
7
“Newbies” will tend to use rather Snaps or Flatpaks than Appimages in my opinion.
Zesko
22 November 2021 10:46
8
When you update new version of any app through AppImage, but AppImage always recreates the same icon of the app to the directory ~/.local/share/icons/hicolor/XXX .
AppImage does not delete many duplicates of icon automatically after uninstall or update any app, but You should manually delete them.
It is the known issue:
opened 03:56PM - 07 Apr 21 UTC
needs verification
upstream bug
Hello there! Thanks for your interest in making AppImageLauncher better. P… lease fill in as much information as possible about your bug so that we can help you directly and don't have to play the good old information ping pong.
See also: https://www.chiark.greenend.org.uk/~sgtatham/bugs.html
**Describe the bug**
AppImageLauncher does not remove desktop icons in `~/.local/share/icons/hicolor`
**Expected behavior**
The program should completely remove desktop icons.
**To Reproduce**
Steps to reproduce the behavior:
1.Integrate an appimage
2.Remove it
3.Go to `~/.local/share/icons/hicolor`
4.See the icon file that refers to the "uninstalled" application.
**System, software, and AppImage information**
-OS: Linux
-Distribution: Manjaro
-Desktop Environment: GNOME
-AppImage: Any
**AppImageLauncher version installed:**
-AppImageLauncher on Manjaro (preinstalled)
GMate8
22 November 2021 13:02
10
Not really. See if someone comes from Windows. They will go to the software’s website, and they will probably download a .deb or .appimage file.
GMate8
22 November 2021 13:03
11
Yes, like every software, they have problems too. Pamac often freezes. As Pamac, I guess this too, will be soon fixed.
