Hello, I am trying to install Surfshark VPN
Can someone tell me the steps on how to do it.
P.S. I am new to manjaro linux.
That’s an AUR package, so you’ll have to build it.
pamac build surfshark-vpn
… or, alternatively…
pamac install yay && yay -S surfshark-vpn
To do it manually…
I have several SurfShark OpenVPN connections defined and they work as expected. Just follow those steps with the caveat that they are typically written for Debian distros, so adjustments will be needed.
Hello Aragorn,
I was able to install it but it is not letting me connect.
Do you know how I can use surfshark on terminal because when I do ‘sudo surfshark-vpn attack’ it says an error has occurred.
I’m sorry, no, I cannot help you with that. I can only tell you how to install it.
