When I launched GOG Galaxy to download The Witcher 3 my main monitor went from 120 Hz to 60 Hz and my 3rd monitor stopped getting signal and no longer works even with different cable. I don’t know what does the Witcher 3 installer sets that disabled 3 monitor setup or change desktop resolution.
My 3 monitor setup is borked now thanks to running this installer. Any clues appreciated, Please help
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
