Hi,
I’m trying to install manjaro guest with multiple monitors on linux mint host.
The manjaro ISO installs perfectly as a guest and supports one monitor but not more than one. I believe that spice support on the guest is required to do this according to
https://wiki.archlinux.org/title/QEMU#Preparing_an_Arch_Linux_guest
Looking at my fresh install I notice that required package
spice-vdagent version 0.21.0-1
is already installed
but
xf86-video-qxl
is not there is however
xf86-video-vmware
I have tried installing xf86-video-qxl version
0.1.5.r16.g52c421c-1
and rebooting but i just get a blank screen.
In fact it seem to be a constant flickering black screen.
If you ctrl-alt-F1,2, 3
You briefly see a text login prompt.
So I cannot then login then to check any logs.
lspci | grep VGA
00:02.0 VGA compatible controller: Red Hat, Inc. QXL paravirtual graphic card (rev 04)
FYI guest manjaro reports:
sudo lshw -c video 1 ✘ 3s
*-display
description: VGA compatible controller
product: QXL paravirtual graphic card
vendor: Red Hat, Inc.
physical id: 2
bus info: pci@0000:00:02.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: vga_controller rom
configuration: driver=qxl latency=0
resources: irq:11 memory:f4000000-f7ffffff memory:f8000000-fbffffff memory:fc0b4000-fc0b5fff ioport:c0c0(size=32) memory:c0000-dffff
Before trying a new driver the driver reported is
modinfo -F filename lshw -c video | awk '/configuration: driver/{print $2}' | cut -d= -f2
/lib/modules/5.13.15-1-MANJARO/kernel/drivers/gpu/drm/qxl/qxl.ko.xz
Hope someone can help please
I would really like to have a proper play with manjaro.
I did install manjaro on my new system and had to give up due to windows guest not working with qemu and reverted to my safe standy distro linux mint but I cannot let go - I have to keep trying
Regards,
Michael
